Kubota Excavator KX61-2 S Series Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX61-2 S Series Excavator
Region: Australia
Number of Pages: 314 Pages
Basic Engine _ Crankcase [D1105-Ebh-6]
Basic Engine _ Crankcase [D1105-E2-Bh-6] ## D1105-E2-Bh-6
Basic Engine _ Oil Pan
Basic Engine _ Piston,Crankshaft
Basic Engine _ Main Bearing Case
Basic Engine _ Camshaft
Basic Engine _ Cylinder Head
Basic Engine _ Valve And Rocker Arm
Basic Engine _ Head Cover [D1105-Ebh-6]
Basic Engine _ Head Cover [D1105-E2-Bh-6] ## D1105-E2-Bh-6
Basic Engine _ Gear Case
Basic Engine _ Engine Bracket
Air Intake System _ Air Cleaner,Inlet Manifold
Exhaust System _ Muffler,Exhaust Manifold
Fuel System _ Nozzle Holder,Glow Plug
Fuel System _ Nozzle Holder [Component Parts]
Fuel System _ Speed Control Plate
Fuel System _ Stop Solenoid
Fuel System _ Governor ## S.No._=Xz0500
Fuel System _ Governor ## S.No._=Ya0001
Fuel System _ Injection Pump
Fuel System _ Fuel Camshaft
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter [Component Parts]
Fuel System _ Fuel Tank
Cooling System _ Water Flange
Cooling System _ Water Pump
Cooling System _ Radiator
Cooling System _ Water Pipe
Electrical System _ Flywheel,Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Battery
Electrical System _ Timer,Horn
Electrical System _ Switch,Meter
Electrical System _ Light
Hydraulic System _ Pump Housing
Hydraulic System _ Piston Pump And Component Parts
Hydraulic System _ Hydraulic Pump And Component Parts
Hydraulic System _ Drive Motor And Component Parts (1)
Hydraulic System _ Drive Motor And Component Parts (2)
Hydraulic System _ Swivel Motor Component Parts
Hydraulic System _ Rotary Joint
Hydraulic System _ Oil Tank
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ Spool Section (Bucket)
Hydraulic System _ Spool Section (Boom 1)
Hydraulic System _ Spool Section (Travel Rh)
Hydraulic System _ Spool Section (Travel Lh)
Hydraulic System _ Spool Section (Boom 2)
Hydraulic System _ Spool Section (Arm)
Hydraulic System _ Spool Section (S_P)
Hydraulic System _ Spool Section (Travel Straight)
Hydraulic System _ Spool Section (Swing)
Hydraulic System _ Spool Section (Blade)
Hydraulic System _ Spool Section (Swivel)
Hydraulic System _ Change Valve
Hydraulic System _ Change Valve [Component Parts]
Hydraulic System _ TPSS Valve
Hydraulic System _ TPSS Valve [Component Parts]
Hydraulic System _ Control Lever (Frame)
Hydraulic System _ Control Lever (Lever Lh)
Hydraulic System _ Control Lever (Lever Rh)
Hydraulic System _ Pilot Valve [Component Parts]
Hydraulic System _ Control Lever (Travel Lh)
Hydraulic System _ Control Lever (Travel Rh)
Hydraulic System _ Control Travel Pedal
Hydraulic System _ Control Lever (Safety Lock Lever)
Hydraulic System _ Control Pedal (Swivel_Swing Change)
Hydraulic System _ Control Lever (TPSS)
Hydraulic System _ Control Lever (Blade)
Hydraulic System _ Control Lever (S_P 1)
Hydraulic System _ Control Lever (S_P 2)
Hydraulic System _ Oil Piping (Suction)
Hydraulic System _ Oil Piping (Delivery)
Hydraulic System _ Oil Piping (Return)
Hydraulic System _ Oil Piping (Oil Cooler)
Hydraulic System _ Oil Piping (Travel Lh)
Hydraulic System _ Oil Piping (Travel Rh)
Hydraulic System _ Oil Piping (Swivel 1)
Hydraulic System _ Oil Piping (Swivel 2)
Hydraulic System _ Oil Piping (Swing)
Hydraulic System _ Oil Piping (Lock)
Hydraulic System _ Oil Piping (Boom 1)
Hydraulic System _ Oil Piping (Boom 2)
Hydraulic System _ Oil Piping (Arm 1)
Hydraulic System _ Oil Piping (Arm 2)
Hydraulic System _ Oil Piping (Bucket 1)
Hydraulic System _ Oil Piping (Bucket 2)
Hydraulic System _ Oil Piping (Bucket 2) (Telescopic)
Hydraulic System _ Oil Piping (Blade)
Hydraulic System _ Oil Piping (Clamp)
Hydraulic System _ Oil Piping (S_P)
Hydraulic System _ Boom Cylinder And Component Parts
Hydraulic System _ Arm Cylinder And Component Parts
Hydraulic System _ Bucket Cylinder And Component Parts
Hydraulic System _ Bucket Cylinder And Component Parts(Telscopic)
Hydraulic System _ Blade Cylinder And Component Parts
Hydraulic System _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Arm (Telescopic)
Front Attachments _ Telescopic Cylinder [Component Parts]
Front Attachments _ Bucket Link
Front Attachments _ Bucket Link (Telescopic)
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
Swivel Frame _ Cover (Left)
Swivel Frame _ Cover (Tank)
Swivel Frame _ Instrument Panel
Swivel Frame _ Bonnet
Swivel Frame _ Sponge (1)
Swivel Frame _ Sponge (2)
Swivel Frame _ Weight
Swivel Frame _ Weight (Telescopic)
Operator's Platform _ Seat
Operator's Platform _ Canopy
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Sponge)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Cabin (Defroster)
Operator's Platform _ Label
Accessories _ Accessories
Accessories _ Weight Kit [Option]
Accessories _ Label Kit [Option]
Option _ Travel Alarm Kit 1 [Option]
Option _ Travel Alarm Kit 2 [Option]
