Kubota Excavator KX61-2 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX61-2 Excavator
Region: Australia
Number of Pages: 328 Pages
Basic Engine _ Crankcase ## # Rev.Mar.15 '01
Basic Engine _ Oil Pan ## # Rev.Mar.15 '01
Basic Engine _ Piston,Crankshaft ## # Rev.Mar.15 '01
Basic Engine _ Main Bearing Case
Basic Engine _ Camshaft
Basic Engine _ Cylinder Head ## # Rev.Mar.15 '01
Basic Engine _ Valve And Rocker Arm
Basic Engine _ Head Cover
Basic Engine _ Gear Case
Basic Engine _ Engine Bracket
Air Intake System _ Air Cleaner,Inlet Manifold ## # Rev.Mar.15 '01
Exhaust System _ Muffler,Exhaust Manifold
Fuel System _ Nozzle Holder,Glow Plug ## # Rev.Mar.15 '01
Fuel System _ Nozzle Holder [Component Parts]
Fuel System _ Speed Control Plate ## # Rev.Mar.15 '01
Fuel System _ Stop Solenoid ## # Rev.Mar.15 '01
Fuel System _ Governor ## # Rev.Mar.15 '01
Fuel System _ Injection Pump
Fuel System _ Fuel Camshaft
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter [Component Parts]
Fuel System _ Fuel Tank
Cooling System _ Water Flange ## # Rev.Mar.15 '01
Cooling System _ Water Pump
Cooling System _ Radiator
Cooling System _ Water Pipe
Electrical System _ Flywheel,Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Battery ## # Rev.Mar.15 '01
Electrical System _ Timer,Horn
Electrical System _ Switch,Meter
Electrical System _ Light
Hydraulic System _ Pump Housing
Hydraulic System _ Piston Pump And Component Parts
Hydraulic System _ Hydraulic Pump And Component Parts
Hydraulic System _ S041-1 Drive Motor And Component Parts ## # Rev.Mar.15 '01
Hydraulic System _ S041-2 Drive Motor And Component Parts ## # Rev.Mar.15 '01
Hydraulic System _ S042-1 Swivel Motor Component Parts ## #S.No.A_=11866 Rev.Mar.15 '01
Hydraulic System _ S042-2 Swivel Motor Component Parts ## #S.No.A_=11867 Rev.Mar.15 '01
Hydraulic System _ Rotary Joint
Hydraulic System _ Oil Tank
Hydraulic System _ Control Valve ## # Rev.Mar.15 '01
Hydraulic System _ Control Valve [Component Parts] ## # Rev.Mar.15 '01
Hydraulic System _ S047-1 Spool Section (Bucket_Swivel)
Hydraulic System _ S047-2 Spool Section (Boom 1)
Hydraulic System _ S047-3 Spool Section (Travel Rh)
Hydraulic System _ S047-4 Spool Section (Travel Lh)
Hydraulic System _ S047-5 Spool Section (Boom 2)
Hydraulic System _ S047-6 Spool Section (Arm)
Hydraulic System _ S047-7 Spool Section (S_P) ## # Rev.Mar.15 '01
Hydraulic System _ S047-8 Spool Section (Travel Straight)
Hydraulic System _ S047-9 Spool Section (Swing_Blade)
Hydraulic System _ Change Valve ## # Rev.Mar.15 '01
Hydraulic System _ Change Valve [Component Parts] ## # Rev.Mar.15 '01
Hydraulic System _ S050-1 Multi Valve ## S.No.A_=11605
Hydraulic System _ S050-2 Tpss Valve ## S.No.A_=11606
Hydraulic System _ S051-1 Multi Valve [Component Parts] ## [Ktc Kcl]S.No.A_=11605
Hydraulic System _ S051-2 Tpss Valve [Component Parts] ## [Ktc Kcl]S.No.A_=11606
Hydraulic System _ Control Lever (Frame)
Hydraulic System _ Control Lever (Lever Lh)
Hydraulic System _ Control Lever (Lever Rh)
Hydraulic System _ Pilot Valve [Component Parts]
Hydraulic System _ Control Lever (Travel Lh) ## # Rev.Mar.15 '01
Hydraulic System _ Control Lever (Travel Rh) ## # Rev.Mar.15 '01
Hydraulic System _ Control Travel Pedal
Hydraulic System _ Control Lever (Safety Lock Lever)
Hydraulic System _ Control Pedal (Swivel_Swing Change)
Hydraulic System _ S061-1 Control Lever (Tpss) ## [Ktc Kcl]S.No.A_=11605
Hydraulic System _ S061-2 Control Lever (Tpss) ## [Ktc Kcl]S.No.A_=11606
Hydraulic System _ Control Lever (Blade)
Hydraulic System _ Control Lever (S_P 1) ## # Rev.Mar.15 '01
Hydraulic System _ Control Lever (S_P 2)
Hydraulic System _ Oil Piping (Suction)
Hydraulic System _ Oil Piping (Delivery)
Hydraulic System _ Oil Piping (Return)
Hydraulic System _ Oil Piping (Oil Cooler)
Hydraulic System _ Oil Piping (Travel Lh) ## # Rev.Mar.15 '01
Hydraulic System _ Oil Piping (Travel Rh) ## # Rev.Mar.15 '01
Hydraulic System _ S071-1 Oil Piping (Swivel 1)
Hydraulic System _ S071-2 Oil Piping (Swivel 1) ## S.No.A_=11605
Hydraulic System _ S071-3 Oil Piping (Swivel 1) ## S.No.A_=11606
Hydraulic System _ Oil Piping (Swivel 2) ## # Rev.Mar.15 '01
Hydraulic System _ Oil Piping (Swing) ## # Rev.Mar.15 '01
Hydraulic System _ Oil Piping (Lock) ## # Rev.Mar.15 '01
Hydraulic System _ S075-1 Oil Piping (Boom 1)
Hydraulic System _ S075-2 Oil Piping (Boom 1) ## S.No.A_=11605
Hydraulic System _ S075-3 Oil Piping (Boom 1) ## S.No.A_=11606
Hydraulic System _ Oil Piping (Boom 2)
Hydraulic System _ S077-1 Oil Piping (Arm 1)
Hydraulic System _ S077-2 Oil Piping (Arm 1) ## S.No.A_=11605
Hydraulic System _ S077-3 Oil Piping (Arm 1) ## S.No.A_=11606
Hydraulic System _ Oil Piping (Arm 2)
Hydraulic System _ S079-1 Oil Piping (Bucket 1) ## S.No.A_=11605
Hydraulic System _ S079-2 Oil Piping (Bucket 1) ## [Kta]S.No.A_=10001,[Ktc Kcl]S.No.A_=11606
Hydraulic System _ Oil Piping (Bucket 2)
Hydraulic System _ Oil Piping (Blade) ## # Rev.Mar.15 '01
Hydraulic System _ Oil Piping (Clamp) ## # Rev.Mar.15 '01
Hydraulic System _ Oil Piping (S_P) ## # Rev.Mar.15 '01
Hydraulic System _ Boom Cylinder And Component Parts
Hydraulic System _ Arm Cylinder And Component Parts
Hydraulic System _ Bucket Cylinder And Component Parts
Hydraulic System _ Blade Cylinder And Component Parts
Hydraulic System _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket ## # Rev.Mar.15 '01
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ S092-1 Arm
Front Attachments _ S092-2 Arm (Telescopic)
Front Attachments _ S092-3 Telescopic Cylinder [Comonent Parts]
Front Attachments _ S093-1 Bucket Link
Front Attachments _ S093-2 Bucket Link (Telescopic)
Front Attachments _ Bucket ## # Rev.Mar.15 '01
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller ## # Rev.Mar.15 '01
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Swivel Bearing ## # Rev.Mar.15 '01
Swivel Frame _ Seat Support ## # Rev.Mar.15 '01
Swivel Frame _ S103-1 Step ## # Rev.Mar.15 '01
Swivel Frame _ S103-2 Step ## # Rev.Mar.15 '01
Swivel Frame _ Cover (Left)
Swivel Frame _ Cover (Tank) ## # Rev.Mar.15 '01
Swivel Frame _ Instrument Panel
Swivel Frame _ Bonnet
Swivel Frame _ Sponge (1)
Swivel Frame _ Sponge (2)
Swivel Frame _ S110-1 Weight
Swivel Frame _ S110-2 Weight (Telescopic) ## # Rev.Mar.15 '01
Operator's Platform _ Seat
Operator's Platform _ Canopy ## # Rev.Mar.15 '01
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Sponge)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Cabin (Defroster)
Operator's Platform _ Label
Accessories _ Accessories
Accessories _ Weight Kit
Accessories _ Label Kit
Region: Australia
Track Frame _ Idler
