Kubota Excavator KX61-2 55001-59999 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX61-2 Excavator
Serial Number: 55001-59999
Number of Pages: 289 Pages
Air Cleaner Inlet Manifold
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve And Rocker Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Water Flange
Water Pipe
Flywheel Starter
Starter Component Parts
Alternator Component Parts
Battery
Timer Horn
Switch Meter
Electrical Wiring
Muffler Exhaust Manifold
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Nozzle Holder Glow Plug
Nozzle Holder Component Parts
Speed Control Plate
Stop Solenoid
Governor
Injection Pump Component Parts
Fuel Camshaft
Accel Lever
Fuel Piping (S.No.;<=56170)
Fuel Piping (S.No.;>=56171)
Fuel Filter Component Parts (S.No.;<=56170)
Pump Housing
Gear Pump
Hydraulic Pump And Component Parts
Drive Motor And Component Parts (1) (S.No.;<=55050)
Drive Motor And Component Parts (2) (S.No.;<=55050)
Drive Motor And Comp. Parts (1) (S.No.;>=55051)
Drive Motor And Comp. Parts (2) (S.No.;>=55051)
Swivel Motor And Component Parts (S.No.;<=55658)
Swivel Motor Component Parts (S.No.;>=55659)
Rotary Joint
Oil Tank
Control Valve
Control Valve Component Parts
Spool Section (Bucket)
Spool Section (Boom 1)
Spool Section (Travel Rh)
Spool Section (Travel Lh)
Spool Section (Boom 2)
Spool Section (Arm)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Straight)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (Swivel)
Change Valve
Change Valve Component Parts
Valve Flange (S.No.;<=55961)
Valve Flange (S.No.;>=55962)
Control Lever (Frame)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Suction)
Oil Piping (Delivery) (No.S.;<=55337)
Oil Piping (Delivery) (No.S.;>=55338)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel / Swing) / Oil Piping (Swivel / Swing)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (Boom 2)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Canopy
Cabin (Front Window) Cabin No.;<=5021539
Cabin (Front Window) Kdg Cabin No.;>=5021540
Front Window (Kuk/Ke Cab.No.;>=5021540) (S.No.;<=55674) / Front Window (Kuk/Ke Cab.No.;>=5021540) (S.No.;<=55674)
Cabin (Window) Cabin No.;<=5016515
Cabin (Window) Cabin No.;5016516 To 5021539
Cabin (Window) Cabin No.;>=5021540
Cabin (Door) Cabin No.;<=5016515
Cabin (Door) Cabin No.;5016516 To 5021539
Cabin (Door) Cabin No.;>=5021540
Cabin (Sponge)
Cabin (Rubber Seal)
Instrument Panel
Seat (Bracket)
Seat (Kuk - S.No.;<=55849 / Ke - S.No.;<=55831) / Seat (Kuk - S.No.;<=55849 / Ke - S.No.;<=55831)
Seat (Kdg / Kuk / Ke) / Seat (Kdg / Kuk / Ke)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label
Swivel Frame
Swivel Bearing
Seat Support
Step
Cover (Left)
Cover (Tank)
Bonnet
Sponge (1)
Sponge (2)
Weight
Track Frame
Idler
Track Roller (S.No.;<=56256)
Track Roller (S.No.;>=56257)
Crawler
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Cylinder Head Cover
Gear Case
Engine Bracket
Water Flange
Water Pipe
Flywheel Starter
Battery
Timer Horn
Switch Meter
Electrical Wiring
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Speed Control Plate
Stop Solenoid
Governor
Fuel Camshaft
Accel Lever
Pump Housing
Gear Pump
Rotary Joint
Oil Tank
Control Valve
Spool Section (Arm)
Change Valve
Oil Piping (Return)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (Boom 2)
Canopy
Cabin (Sponge)
Cabin (Rubber Seal)
Instrument Panel
Seat (Bracket)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label
Swivel Frame
Swivel Bearing
Seat Support
Step
Cover (Left)
Cover (Tank)
Bonnet
Sponge (1)
Sponge (2)
Weight
Track Frame
Idler
Crawler
