Kubota Excavator KX41H Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX41H Excavator
Number of Pages: 255 Pages
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Air Cleaner Inlet Manifold Except [Kta]
Air Cleaner Inlet Manifold [Kta]
Muffler Exhaust Manifold
Nozzle Holder Glow Plug
Nozzle Holder (Component Parts)
Speed Control Plate
Speed Control Plate
Stop Solenoid
Governor
Injection Pump Camshaft (1)
Injection Pump (Component Parts)
Injection Pump Camshaft (2)
Accel Lever
Fuel Piping
Water Flange
Water Pipe
Flywheel Starter
Starter (Component Parts)
Dynamo Except [Kta]
Dynamo [Kta]
Dynamo (Component Parts)
Battery
Regulator Horn
Switch Meter
Electrical Wiring
Pump Housing
Gear Pump & Component Parts
Drive Motor & Component Parts
Swivel Motor & Component Parts
Rotary Joint
Oil Tank
Control Valve (1) Except [Kta]
Control Valve (1) [Kta]
Control Valve (1) (Component Parts)
Spool Section (Bucket)
Spool Section (Boom)
Spool Section (Travel Rh)
Spool Section
Spool Section (Arm)
Spool Section (Travel Lh)
Spool Section (S/P) / Spool Section (S/P)
Control Valve (3)
Control Valve (3) (Component Parts)
Spool Section (Swivel)
Spool Section (Swing)
Spool Section (Blade)
Control Lever (Frame)
Control Lever (Box Lh)
Control Lever (Lever Lh-1)
Control Lever (Lever Lh-2)
Control Lever (Box Rh)
Control Lever (Lever Rh-1)
Control Lever (Lever Rh-2)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Third Line)
Oil Piping (Suction Delivery)
Oil Piping (Hydraulic Port)
Oil Piping (Return C/V Tank) Except [Kta] / Oil Piping (Return C/V Tank) Except [Kta]
Oil Piping (Return C/V Tank) [Kta] / Oil Piping (Return C/V Tank) [Kta]
Oil Piping (Oil Cooler) Except [Kta]
Oil Piping (Oil Cooler) [Kta]
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel) Except [Kta]
Oil Piping (Swivel) [Kta]
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Oil Piping (Cushion)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder & Component Parts
Arm Cylinder & Component Parts
Bucket Cylinder & Component Parts
Blade Cylinder & Component Parts
Swing Cylinder & Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Truck Frame
Idler
Truck Roller
Crawler
Swivel Frame
Swivel Bearing
Floor Plate
Bonnet
Sponge (1) [Ke Kdg Kuk]
Sponge (1) [Ktc Kcl Kta]
Sponge (2)
Weight
Canopy [Ke Kdg Kuk]
Canopy (Rops) [Ktc Kcl Kta]
Instrument Panel
Seat [Ke Kdg Kuk] Except [Costa-Rica Ecuador Turkishref]
Seat [Ktc Kcl Kta] [Costa-Rica Ecuador Turkishref]
Light
Label [Ke Kdg Kuk]
Label [Ktc Kcl Kta]
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Speed Control Plate
Speed Control Plate
Stop Solenoid
Governor
Accel Lever
Fuel Piping
Water Flange
Water Pipe
Flywheel Starter
Dynamo Except [Kta]
Dynamo [Kta]
Battery
Regulator Horn
Switch Meter
Electrical Wiring
Pump Housing
Rotary Joint
Oil Tank
Spool Section
Spool Section (Arm)
Control Valve (3)
Oil Piping (Swing)
Oil Piping (Boom)
Oil Piping (Arm)
Oil Piping (Bucket)
Oil Piping (Blade)
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Truck Frame
Idler
Truck Roller
Crawler
Swivel Frame
Swivel Bearing
Floor Plate
Bonnet
Sponge (2)
Weight
Canopy [Ke Kdg Kuk]
Instrument Panel
Light
Label [Ke Kdg Kuk]
Label [Ktc Kcl Kta]
