Kubota Excavator KX41-2ALPHA -70001 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX41-2ALPHA Excavator
Serial Number: -70001
Number of Pages: 293 Pages
Air Cleaner Inlet Manifold
Crankcase
Oil Pan
Piston And Crankshaft
Main Bearing Case
Camshaft
Valve And Rocer Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Water Flange
Water Pipe
Flywheel Starter
Starter (Component Parts)
Alternator (Component Parts)
Battery
Timer Horn
Switch Meter
Electrical Wiring
Muffler Exhaust Manifold
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Arm (Telescopic)
Bucket Link
Bucket Link (Telecopic)
Bucket
Blade (Standard)
Blade (Variable)
Nozzle Holder Glow Plug
Nozzle Holder (Component Parts)
Speed Control Plate
Stop Solenoid
Governor
Fuel Camshaft
Accel Lever
Fuel Piping
Pump Housing
Gear Pump And Component Parts
Drive Motor And Comp. Parts (1) (Standard)
Drive Motor And Comp.Parts (2) (Standard)
Drive Motor And Comp. Parts (1) (Variable)
Drive Motor And Comp.Parts (2) (Variable)
Swivel Motor And Component Parts
Rotary Joint (Std Truck Frame)
Rotary Joint (Var. Truck Frame)
Oil Tank
Control Valve
Control Valve (Component Parts)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Travel Rh)
Spool Section (Travel Straight)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (Spacer)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (Swivel)
Supply Unit
Valve Flange
Valve Flange (Variable)
Control Lever (Frame)
Control Lever (Lever Lh)
Control Lever (Lever Rh)
Pilot Valve (Component Parts)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh) (Standard)
Oil Piping (Travel Lh) (Variable)
Oil Piping (Travel Rh) (Standard)
Oil Piping (Travel Rh) (Variable)
Oil Piping (Swivel/Swing) / Oil Piping (Swivel/Swing)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Boom 2) Telescopic
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Bucket 2)(Telescop)
Oil Piping (Blade) (Standard)
Oil Piping (Blade) (Variable)
Oil Piping (Cylinder) (Variable)
Oil Piping (Clamp)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Telescopic Cylinder (Component Parts)
Bucket Cylinder And Component Parts
Bucket Cylinder And Comp. Parts (Telescop)
Blade Cylinder And Comp. Parts (Standard)
Blade Cylinder And Comp. Parts (Variable)
Swing Cylinder And Component Parts
Canopy (2-Post)
Canopy (4-Post)
Cabin (Front Window)
Cabin (Window)
Cabin (Door)
Cabin (Sponge)
Cabin (Rubber Seal)
Instrument Panel
Seat (Bracket)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label
Swivel Frame
Arch Frame
Step
Cover (Left)
Bonnet
Sponge (1)
Sponge (2)
Weight
Weight (Telescopic)
Track Frame (Standard)
Track Frame (Variable)
Truck Cylinder And Comp. Parts
Idler (Standard)
Idler (Variable)
Track Roller (Standard)
Track Roller (Variable)
Crawler
Crankcase
Oil Pan
Main Bearing Case
Camshaft
Valve And Rocer Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Water Flange
Water Pipe
Flywheel Starter
Battery
Timer Horn
Switch Meter
Electrical Wiring
Swing Bracket
Boom
Arm
Arm (Telescopic)
Bucket Link
Bucket
Blade (Standard)
Blade (Variable)
Speed Control Plate
Stop Solenoid
Governor
Fuel Camshaft
Accel Lever
Fuel Piping
Pump Housing
Oil Tank
Control Valve
Spool Section (Arm)
Supply Unit
Valve Flange
Oil Piping (Return)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Clamp)
Canopy (2-Post)
Canopy (4-Post)
Cabin (Window)
Cabin (Door)
Cabin (Sponge)
Cabin (Rubber Seal)
Instrument Panel
Seat (Bracket)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label
Swivel Frame
Arch Frame
Step
Cover (Left)
Bonnet
Sponge (1)
Sponge (2)
Weight
Weight (Telescopic)
Idler (Standard)
Idler (Variable)
Crawler
