Kubota Excavator KX41-2 S Series Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX41-2 S Series Excavator
Region: Australia
Number of Pages: 283 Pages
Basic Engine _ Crankcase
Basic Engine _ Oil Pan
Basic Engine _ Piston,Crankshaft
Basic Engine _ Main Bearing Case
Basic Engine _ Camshaft
Basic Engine _ Cylinder Head
Basic Engine _ Valve And Rocker Arm
Basic Engine _ Head Cover
Basic Engine _ Gear Case
Basic Engine _ Engine Bracket
Air Intake System _ Air Cleaner,Inlet Manifold
Exhaust System _ Muffler,Exhaust Manifold
Fuel System _ Nozzle Holder,Glow Plug
Fuel System _ Nozzle Holder [Component Parts]
Fuel System _ Speed Control Plate
Fuel System _ Stop Solenoid
Fuel System _ Governor
Fuel System _ Injection Pump
Fuel System _ Fuel Camshaft
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter [Component Parts]
Fuel System _ Fuel Tank
Cooling System _ Water Flange
Cooling System _ Water Pump
Cooling System _ Radiator
Cooling System _ Water Pipe
Electrical System _ Flywheel,Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Battery
Electrical System _ Timer,Horn
Electrical System _ Switch,Meter
Electrical System _ Light
Hydraulic System _ Electrical Wiring
Hydraulic System _ Pump Housing
Hydraulic System _ Grar Pump And Component Parts
Hydraulic System _ Hydraulic Pump And Component Parts
Hydraulic System _ S041-1 Drive Motor And Component Parts (1)
Hydraulic System _ S041-2 Drive Motor And Component Parts (2)
Hydraulic System _ Swivel Motor And Component Parts
Hydraulic System _ S043-1 Rotary Joint
Hydraulic System _ S043-2 Rotary Joint [Kx41-2v]
Hydraulic System _ Oil Tank
Hydraulic System _ S045-1 Control Valve
Hydraulic System _ S045-2 Control Valve [Kx41-2v]
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ Spool Section (Boom)
Hydraulic System _ Spool Section (Bucket)
Hydraulic System _ Spool Section (Travl Rh)
Hydraulic System _ Spool Section (Travel Straight)
Hydraulic System _ Spool Section (S_P)
Hydraulic System _ Spool Section (Travel Lh)
Hydraulic System _ Spool Section (Arm)
Hydraulic System _ Spool Section (Spacer_Swing)
Hydraulic System _ Spool Section (Blade)
Hydraulic System _ Spool Section (Swivel)
Hydraulic System _ Unloader Valve
Hydraulic System _ Unloader Valve [Component Parts]
Hydraulic System _ Tpss Valve
Hydraulic System _ Tpss Valve [Component Parts]
Hydraulic System _ Change Valve [Kx41-2v]
Hydraulic System _ Change Valve [Component Parts] [Kx41-2v]
Hydraulic System _ Control Lever (Frame)
Hydraulic System _ Control Lever (Lever Lh)
Hydraulic System _ Control Lever (Lever Rh)
Hydraulic System _ Pilot Valve [Component Parts]
Hydraulic System _ Control Lever (Travel Lh)
Hydraulic System _ Control Lever (Travel Rh)
Hydraulic System _ Control Travel Pedal
Hydraulic System _ Control Lever (Safety Lock Lever)
Hydraulic System _ Control Pedal (Swivel_Swing Change)
Hydraulic System _ Control Lever (Tpss)
Hydraulic System _ Control Lever (Blade)
Hydraulic System _ Control Lever (S_P 1)
Hydraulic System _ Control Lever (S_P 2)
Hydraulic System _ Oil Piping (Suction,Delivery)
Hydraulic System _ Oil Piping (Oil Return)
Hydraulic System _ Oil Piping (Oil Cooler)
Hydraulic System _ S079-1 Oil Piping (Travel Lh)
Hydraulic System _ S079-2 Oil Piping (Travel Lh) [Kx41-2v]
Hydraulic System _ S080-1 Oil Piping (Travel Rh)
Hydraulic System _ S080-2 Oil Piping (Travel Rh) [Kx41-2v]
Hydraulic System _ Oil Piping (Swivel 1)
Hydraulic System _ Oil Piping (Swivel 2)
Hydraulic System _ Oil Piping (Swing)
Hydraulic System _ Oil Piping (Look)
Hydraulic System _ Oil Piping (Boom 1)
Hydraulic System _ Oil Piping (Boom 2)
Hydraulic System _ Oil Piping (Arm 1)
Hydraulic System _ Oil Piping (Arm 2)
Hydraulic System _ Oil Piping (Bucket 1)
Hydraulic System _ Oil Piping (Bucket 2)
Hydraulic System _ S091-1 Oil Piping (Blade)
Hydraulic System _ S091-2 Oil Piping (Blade) [Kx41-2v]
Hydraulic System _ Oil Piping (Track) [Kx41-2v]
Hydraulic System _ Oil Piping (Clamp)
Hydraulic System _ Oil Piping (S_P)
Hydraulic System _ Boom Cylinder And Component Parts
Hydraulic System _ Arm Cylinder And Component Parts
Hydraulic System _ Bucket Cylinder And Component Parts ## S.No._=21340
Hydraulic System _ S097-1 Bucket Cylinder And Component Parts ## S.No._=21341
Hydraulic System _ S098-1 Blade Cylinder And Component Parts
Hydraulic System _ S098-2 Blade Cylinder And Component Parts [Kx41-2v] ## S.No._=21340
Hydraulic System _ S098-3 Blade Cylinder And Component Parts [Kx41-2v] ## S.No._=21341
Hydraulic System _ Swing Cylinder And Component Parts
Front Attachments _ Track Cylinder And Component Parts [Kx41-2v]
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Track Frame _ S107-1 Blade
Track Frame _ S107-2 Blade [Kx41-2v]
Track Frame _ S108-1 Track Frame
Track Frame _ S108-2 Track Frame [Kx41-2v]
Track Frame _ S109-1 Idler
Track Frame _ S109-2 Idler [Kx41-2v]
Track Frame _ S110-1 Track Roller
Track Frame _ S110-2 Track Roller [Kx41-2v]
Swivel Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Step
Swivel Frame _ Cover (Left)
Swivel Frame _ Bonnet
Swivel Frame _ Sponge (1)
Swivel Frame _ Sponge (2)
Operator's Platform _ Weight
Operator's Platform _ Canopy
Operator's Platform _ Instrument Panel
Operator's Platform _ Seat
Operator's Platform _ Label
Accessories _ Accessories
Accessories _ Weight Kit [Option]
Accessories _ Label Kit [Option]
