Kubota Excavator KX41-2 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX41-2 Excavator
Region: Australia
Number of Pages: 288 Pages
Basic Engine _ Crankcase
Basic Engine _ Oil Pan
Basic Engine _ Piston,Crankshaft
Basic Engine _ Main Bearing Case
Basic Engine _ Camshaft
Basic Engine _ Cylinder Head
Basic Engine _ Valve And Rocker Arm
Basic Engine _ Head Cover
Basic Engine _ Gear Case
Basic Engine _ Engine Bracket
Basic Engine _ Air Cleaner,Inlet Manifold
Air Intake System _ Muffler,Exhaust Manifold
Exhaust System _ Nozzle Holder,Glow Plug
Fuel System _ Nozzle Holder [Component Parts]
Fuel System _ Speed Control Plate
Fuel System _ Stop Solenoid
Fuel System _ Governor
Fuel System _ Injection Pump
Fuel System _ Fuel Camshaft
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter [Component Parts]
Fuel System _ Fuel Tank
Fuel System _ Water Flange
Cooling System _ Water Pump
Cooling System _ Radiator
Cooling System _ Water Pipe
Cooling System _ Flywheel,Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Battery
Electrical System _ Timer,Horn
Electrical System _ Switch,Meter
Electrical System _ Pump Housing
Hydraulic System _ Gear Pump And Component Parts
Hydraulic System _ Hydraulic Pump And Component Parts
Hydraulic System _ S040-1 Drive Motor And Component Parts (1)
Hydraulic System _ S040-2 Drive Motor And Component Parts (2)
Hydraulic System _ Swivel Motor And Component Parts
Hydraulic System _ Rotary Joint
Hydraulic System _ Oil Tank
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ Spool Section (Boom)
Hydraulic System _ Spool Section (Bucket)
Hydraulic System _ Spool Section (Travl Rh)
Hydraulic System _ Spool Section (Travel Straight)
Hydraulic System _ Spool Section (S_P)
Hydraulic System _ Spool Section (Travel Lh)
Hydraulic System _ Spool Section (Arm)
Hydraulic System _ Spool Section (Spacer)
Hydraulic System _ Spool Section (Swing)
Hydraulic System _ Spool Section (Blade)
Hydraulic System _ Spool Section (Swivel)
Hydraulic System _ Change Valve
Hydraulic System _ Change Valve [Component Parts]
Hydraulic System _ S059-1 Multi Valve ## S.No.A_=11363
Hydraulic System _ S059-2 Tpss Valve ## S.No.A1364_=
Hydraulic System _ S060-1 Multi Valve [Component Parts] ## [Ktc Kcl]S.No.A_=11363
Hydraulic System _ S060-2 Tpss Valve [Component Parts] ## [Ktc Kcl]S.No.A_=11364
Hydraulic System _ Control Lever (Frame)
Hydraulic System _ Control Lever (Lever Lh)
Hydraulic System _ Control Lever (Lever Rh)
Hydraulic System _ Pilot Valve [Component Parts]
Hydraulic System _ Control Lever (Travel Lh)
Hydraulic System _ Control Lever (Travel Rh)
Hydraulic System _ Control Travel Pedal
Hydraulic System _ Control Lever (Safety Lock Lever)
Hydraulic System _ Control Pedal (Swivel_Swing Change)
Hydraulic System _ S070-1 Control Lever (Tpss) ## [Ktc Kcl]S.No.A_=11363
Hydraulic System _ S070-2 Control Lever (Tpss) ## [Ktc Kcl]S.No.A_=11364
Hydraulic System _ Control Lever (Blade)
Hydraulic System _ Control Lever (S_P 1)
Hydraulic System _ Control Lever (S_P 2)
Hydraulic System _ Oil Piping (Suction,Delivery)
Hydraulic System _ Oil Piping (Oil Return)
Hydraulic System _ Oil Piping (Oil Cooler)
Hydraulic System _ Oil Piping (Travel Lh)
Hydraulic System _ Oil Piping (Travel Rh)
Hydraulic System _ Oil Piping (Swivel 1)
Hydraulic System _ Oil Piping (Swivel 2)
Hydraulic System _ Oil Piping (Swing)
Hydraulic System _ Oil Piping (Look)
Hydraulic System _ S083-1 Oil Piping (Boom 1)
Hydraulic System _ S083-2 Oil Piping (Boom 1) ## S.No.A_=11363
Hydraulic System _ S083-3 Oil Piping (Boom 1) ## S.No.A_=11364
Hydraulic System _ Oil Piping (Boom 2)
Hydraulic System _ S085-1 Oil Piping (Arm 1)
Hydraulic System _ S085-2 Oil Piping (Arm 1) ## S.No.A_=11363
Hydraulic System _ S085-3 Oil Piping (Arm 1) ## S.No.A_=11364
Hydraulic System _ Oil Piping (Arm 2)
Hydraulic System _ Oil Piping (Bucket 1)
Hydraulic System _ Oil Piping (Bucket 2)
Hydraulic System _ Oil Piping (Blade)
Hydraulic System _ Oil Piping (Clamp)
Hydraulic System _ Oil Piping (S_P)
Hydraulic System _ Boom Cylinder And Component Parts
Hydraulic System _ Arm Cylinder And Component Parts
Hydraulic System _ Bucket Cylinder And Component Parts
Hydraulic System _ Blade Cylinder And Component Parts
Hydraulic System _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Front Attachments _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Step
Swivel Frame _ Cover (Left)
Swivel Frame _ Bonnet
Swivel Frame _ Sponge (1)
Swivel Frame _ Sponge (2)
Swivel Frame _ Weight
Swivel Frame _ Canopy
Operator's Platform _ Instrument Panel
Operator's Platform _ Seat
Operator's Platform _ Light
Operator's Platform _ Label
Operator's Platform _ Accessories
Accessories _ Weight Kit
Accessories _ Label Kit
Region: Australia
Track Frame _ Idler
Swivel Frame _ Step
