Kubota Excavator KX41-2 55001-69999 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX41-2 Excavator
Serial Number: 55001-69999
Number of Pages: 281 Pages
Air Cleaner Inlet Manifold
Crankcase
Oil Pan
Piston And Crankshaft
Main Bearing Case
Camshaft
Valve And Rocker
Cylinder Head Cover
Gear Case
Engine Bracket
Water Flange
Water Pipe
Flywheel Starter
Starter [Component Parts]
Alternator [Component Parts]
Battery
Timer Horn
Switch Meter
Electrical Wiring
Muffler Exhaust Manifold
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Arm (Telescopic)
Bucket Link
Bucket Link (Telecopic)
Bucket
Blade
Nozzle Holder Glow Plug
Nozzle Holder [Component Parts]
Speed Control Plate
Stop Solenoid
Governor
Injection Pump [Component Parts]
Fuel Camshaft
Accel Lever
Fuel Piping
Tuel Filter [Component Parts]
Pump Housing
Gear Pump And Component Parts (S.No.;<=56862)
Gear Pump And Component Parts (S.No.;>=56863)
Huhydraulic Pump And Component Parts
Drive Motor And Component Parts (1)
Drive Motor And Component Parts (2)
Swivel Motor And Component Parts
Rotaty Joint
Oil Tank
Control Valve (S.No.;<=56816)
Control Valve (S.No.;<=56817)
Control Valve [Component Parts]
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Travel Rh)
Spool Section (Travel Straight)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (Spacer)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (Swivel)
Change Valve
Change Valve [Component Parts]
Valve Flange
Control Lever (Frame)
Control Lever (Lever Lh)
Control Lever (Lever Rh)
Pilot Valve (Component Parts)
Control Lever (Trave Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Suction)
Oil Piping (Delivery) (S.No.;<=56003)
Oil Piping (Delivery) (S.No.;>=56004)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel/Swing) / Oil Piping (Swivel/Swing)
Oil Pipint (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Boom 2) Telescopic
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Telescopic Cylinder (Component Parts)
Bucket Cylinder And Component Parts
Blake Cylinder And Component Parts
Swing Cylinder And Component Parts
Canopy
Cabin (Front Window) (Kdg)
Cabin (Front Window) (Ke/Kuk) / Cabin (Front Window) (Ke/Kuk)
Cabin (Window)
Cabin (Door)
Cabin (Sponge)
Cabin (Rubber Seal)
Instrument Panel
Seat (Bracket)
Seat (Kuk/Ke) / Seat (Kuk/Ke)
Canopy
Seat (Kdg/Kuk/Ke) / Seat (Kdg/Kuk/Ke)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label
Swivel Frame
Arch Frame
Swivel Braring
Step
Cover (Left)
Bonnet
Sponge (1)
Sponge (2)
Weight (S.No.;<=55713)
Weight (S.No.;>=55714)
Weight (Telescopic)
Track Frame
Idler
Track Roller
Crawler
Cabin (Rubber Seal)
