Kubota Excavator KX161-2 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX161-2 Excavator
Number of Pages: 305 Pages
Crankcase
Oil Pan
Piston And Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Air Cleaner Inlet Manifold
Muffler Exhaust Manifold
Nozzle Holder Glow Plug
Speed Control Plate
Engine Stop Lever
Governor
Injection Pump (Component Parts)
Fuel Camshaft
Accel Lever
Fuel Piping
Fuel Filter (Component Parts)
Water Flange
Water Pipe
Flywheel Starter
Starter (Component Parts)
Alternator (Component Parts)
Battery
Timer Horn
Switch Meter
Electrical Wiring
Pump Housing
Piston Pump And Component Parts
Hydraulic Pump And Component Parts
Drive Motor And Component Parts
Swivel Motor And Component Parts
Rotary Joint
Oil Tank
Control Valve (S.No.;<=50907)
Control Valve (S.No.;>=50908)
Control Valve (Component Parts)
Spool Section (Bucket)
Spool Section (Boom 1)
Spool Section (Travel Rh)
Spool Section (Travel Lh)
Spool Section (Boom 2)
Spool Section (Arm)
Spool Section (S/P) / Spool Section (S/P)
Spool Section (Travel Straight)
Spool Section (Swing)
Spool Section (Blade)
Spool Section (Swivel)
Change Valve
Change Valve (Component Parts)
Valve Flange
Control Lever (Frame)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Lever (Blade)
Control Lever (S/P 1) / Control Lever (S/P 1)
Control Lever (S/P 2) (S.No.;<=50502) / Control Lever (S/P 2) (S.No.;<=50502)
Control Lever (S/P 2) (S.No.;>=50503) / Control Lever (S/P 2) (S.No.;>=50503)
Oil Piping (Suction)
Oil Piping (Delivery) W/O Accumulator / Oil Piping (Delivery) W/O Accumulator
Oil Piping (Delivery) Accumulator (S.No.;<=50807)
Oil Piping (Delivery) Accumulator (S.No.;>=50908)
Oil Piping (Return)
Oil Piping (Oil Cooler) (S.No.;<=50592)
Oil Piping (Oil Cooler) (S.No.;>=50593)
Oil Piping (Travel Lh) (S.No.;<=50907)
Oil Piping (Travel Lh) (S.No.;>=50908)
Oil Piping (Travel Rh) (S.No.;<=50907)
Oil Piping (Travel Rh) (S.No.;>=50908)
Oil Piping (Swivel / Swing) / Oil Piping (Swivel / Swing)
Oil Piping (Swivel) (S.No.;<=50907)
Oil Piping (Swivel) (S.No.;>=50908)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2) (S.No.;<=50907)
Oil Piping (Boom 2) (S.No.;>=50908)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Swing)
Oil Piping (Blade) (S.No.;<=50907)
Oil Piping (Blade) (S.No.;>=50908)
Oil Piping (Clamp)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Track Frame
Idler
Track Roller (Rubber Crawler) (S.No.;<=50651)
Track Roller (Rubber Crawler) (S.No.;>=50652)
Track Roller (Iron Crawler) (S.No.;<=50851)
Crawler (S.No.;<=50907)
Crawler (S.No.;>=50908)
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Seat Support
Step
Track Frame
Cover (1)
Cover (2)
Bonnet
Sponge (1)
Sponge (2)
Weight
Cabin (Front Window) (Kdg) Cabin No.;<=5021539
Cabin (Front Window) Kdg Cabin No.;>=5021540
Front Window (Kuk/Ke Cab.No.;>=5021540) (S.No.;<=00851) / Front Window (Kuk/Ke Cab.No.;>=5021540) (S.No.;<=00851)
Cabin (Window) Cabin No.;<=5016515
Cabin (Window) Cabin No.;5016516 To 5021539
Cabin (Window) Cabin No.;>=5021540
Cabin (Door) Cabin No.;<=5016515
Cabin (Door) Cabin No.;5016516 To 5021539
Cabin (Door) Cabin No.;>=5021540
Cabin (Sponge)
Cabin (Rubber Seal)
Cabin (Partition Plate) (S.No.;>=50556)
Instrument Panel
Swivel Gear Case
Seat (Bracket)
Seat (Kuk - S.No.;<=1065 / Ke - S.No.;<=1063) / Seat (Kuk - S.No.;<=1065 / Ke - S.No.;<=1063)
Seat (Kdg / Kuk / Ke) / Seat (Kdg / Kuk / Ke)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label
Crankcase
Oil Pan
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Bracket
Speed Control Plate
Engine Stop Lever
Governor
Fuel Camshaft
Accel Lever
Fuel Piping
Water Flange
Water Pipe
Flywheel Starter
Battery
Timer Horn
Switch Meter
Electrical Wiring
Pump Housing
Rotary Joint
Oil Tank
Spool Section (Arm)
Change Valve
Valve Flange
Oil Piping (Return)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Swing)
Oil Piping (Clamp)
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Track Frame
Idler
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Seat Support
Step
Track Frame
Cover (1)
Cover (2)
Bonnet
Sponge (1)
Sponge (2)
Weight
Cabin (Sponge)
Cabin (Rubber Seal)
Instrument Panel
Swivel Gear Case
Seat (Bracket)
Cabin (Wiper Motor)
Cabin (Heater)
Light
Label
