Kubota Excavator KX121-3 55001-69999 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX121-3 Excavator
Serial Number: 55001-69999
Number of Pages: 315 Pages
Accesorios / Accessories
Soporte Brazo De Oscilacion / Swing Bracket
Brazo Principal / Boom
Cub.Cilindro (Brazo Pr.) / Cylinder Cover(Boom)
Brazo / Arm
Brazo (Telescopico) / Arm(Telescopic)
Articulacion Del Cazo / Bucket Link
Articul.Cazo (Telescopica) / Bucket Link(Telescopic)
Cazo / Bucket
Hoja / Blade
Caja De La Bomba De Aceite / Pump Housing
Bomba Hidr.Y Componentes / Hydraulic Pump(Comp.Parts)
Motor Acc.Y Componentes (1) / Drive Moter(Comp.Parts)(1)
Motor Acc.Y Componentes (2) / Drive Moter(Comp.Parts)(2)
Motor De Rotac.Y Componentes (1) / Swivel Motor(Comp.Parts)(1)
Motor De Rotac.Y Componentes (2) / Swivel Motor(Comp.Parts)(2)
Junta Giratoria / Rotary Joint
Tanque De Aceite / Oil Tank
Cilind.Brazo Prin. (Componentes)(No.S.-00075) / Boom Cylinder(Comp.Parts)(S.No.-00075)
Cilind.Brazo Prin. (Componentes)(No.S.00076-00314) / Boom Cylinder(Comp.Parts)(S.No.00076-00314)
Cilind.Brazo Prin. (Componentes)(No.S.00315-) / Boom Cylinder(Comp.Parts)(S.No.00315-)
Cilindro Brazo (Componentes)(No.S.-00075) / Arm Cylinder(Comp.Parts)(S.No.-00075)
Cilindro Brazo (Componentes)(No.S.00076-00314) / Arm Cylinder(Comp.Parts)(S.No.00076-00314)
Cilindro Brazo (Componentes)(No.S.00315-) / Arm Cylinder(Comp.Parts)(S.No.00315-)
Cil.Brazo Telesc. (Componentes) / Arm Cylinder Telescopic(Comp.Parts)
Cilind.De Cazo (Componentes)(No.S.-00314) / Bucket Cylinder(Comp.Parts)(S.No.-00314)
Cilind.De Cazo (Componentes)(No.S.00315-) / Bucket Cylinder(Comp.Parts)(S.No.00315-)
Cil.Cazo Telesc. (Componentes) / Bucket Cylinder Telescopic(Comp.Parts)
Cilind.Hoja (Componentes)(No.S.-00314) / Blade Cylinder(Comp.Parts)(S.No.-00314)
Cilind.Hoja (Componentes)(No.S.00315-) / Blade Cylinder(Comp.Parts)(S.No.00315-)
Cil.Brazo Oscil. (Componentes) / Swing Cylinder(Comp.Parts)
Pal.Acel(No.S.-50205) / Accel Lever(S.No.-50205)
Conductos Del Combustible / Fuel Piping
Filtro Comb.(Componentes) / Fuel Filter(Comp.Parts)
Tanque De Combustible / Fuel Tank
Palanca Ctrol (Lado Izdo.) / Control Lever(Lever Lh)
Valv.Aux.(Componentes) Li / Pilot Valve(Component Parts) Lh
Palanca Ctrol (Lado Dcho.) / Control Lever(Lever Rh)
Valv.Aux.(Componentes) Ld / Pilot Valve(Component Parts) Rh
Pal.Ctrol (Trasl.Izda.) 1 / Control Lever(Travel Lh)1
Pal.Ctrol (Trasl.Izda.) 2 / Control Lever(Travel Lh)2
Pal.Ctrol (Trasl.Dcha.) 1 / Control Lever(Travel Rh)1
Pal.Ctrol (Trasl.Dcha.) 2 / Control Lever(Travel Rh)2
Trasl. De Palanca De Paro / Stop Lever Travel
Pedal De Trasl.De Control / Control Travel Pedal
Palanca Control (Seguridad) / Control Lever(Safety Lock Lever)
Ped.Ctrol (Giro/Oscil.1) / Control Pedal(Swivel/Swing Change 1)
Ped.Ctrol (Giro/Oscil.2) / Control Pedal(Swivel/Swing Change 2)
Palanca De Control (Hoja) / Control Lever(Blade)
Pedal (S/P) / Pedal(S/P)
Valvula De Control(1) / Control Valve(1)
Valvula De Control(2) / Control Valve(2)
Valvula De Control(3) / Control Valve(3)
Valvula De Control(4) / Control Valve(4)
Valv.Control (Componentes) / Control Valve(Comp.Parts)
Seccion De La Bobina (Admision) / Spool Section(Inlet)
Seccion De La Bobina(Rotacion) / Spool Section(Swivel)
Seccion De La Bobina (Trasl.Izda.) / Spool Section(Travel Lh)
Seccion De La Bobina(Trasl.Dcha.) / Spool Section(Travel Rh)
Seccion De La Bobina (Hoja) / Spool Section(Blade)
Seccion De La Bobina (Brazo) / Spool Section(Arm)
Seccion De La Bobina(Trasl.Recta) / Spool Section(Boom)
Seccion De La Bobina (Cazo) / Spool Section(Bucket)
Seccion De La Bobina(Oscilacion) / Spool Section(Swing)
Seccion De La Bobina (S/P) / Spool Section(S/P)
Valvula De Recambio / Change Valve
Valvula De Recambio (Componentes) / Change Valve(Component Parts)
Cabina (Esponja) / Cabin(Sponge)
Cabina (Ventanilla 1) / Cabin(Window 1)
Cabina (Ventanilla 2) / Cabin(Window 2)
Cabina (Puerta) / Cabin(Door)
Cabina (Motor Limpiaparab.) / Cabin(Wiper Motor)
Cabina (Accesorios) / Cabin(Accessories)
Cabina (Calefaccion) / Cabin(Heater)
Cabina (Calefaccion)(A/C) / Cabin(Heater)(Air Condition)
Cabina(A/C 1) / Cabin(Air Condition 1)
Cabina(A/C 2) / Cabin(Air Condition 2)
Cabina(A/C 3) / Cabin(Air Condition 3)
Cabina(A/C 4) / Cabin(Air Condition 4)
Bateria(No.S.-50250) / Battery(S.No.-50250)
Bateria(No.S.50251-) / Battery(S.No.50251-)
Temp. Boc. Rele (No.S.-50205) / Timer Horn(S.No.-50205)
Temp Boc Rel Ai (No.S.50206-) / Timer Horn(S.No.50206-)
Interr.Ymed.(No.S.-50205) / Switch And Meter(S.No.-50205)
Interr.Y Med.(No.S.50206-) / Switch And Meter(S.No.50206-)
Luces / Light
Cableado Electrico / Electrical Wiring
Cableado Electrico(A/C) / Electrical Wiring(Air Condition)
Etiqueta / Label
Bastidor De Rotacion / Swivel Frame
Estructura De Arco / Arch Frame
Cojinete De Rotacion / Swivel Bearing
Soporte Del Asiento / Seat Support
Soporte Del Asiento(A/C) / Seat Support(Air Condition)
Peldano / Step
Peldano(A/C) / Step(Air Condition)
Cubierta (Lado Izdo.) / Cover(Lh)
Cubierta (Lado Dcho.) / Cover(Rh)
Capot (Lado Izdo.) / Bonnet(Lh)
Capot (Lado Izdo.)(A/C) / Bonnet(Lh)(Air Condition)
Capot (Lado Dcho.) / Bonnet(Rh)
Capot (Posterior) / Bonnet(Back)
Esponja / Sponge
Peso / Weight
Asiento / Seat
Conductos De Aceite (Suminis.) / Oil Piping(Delivery)
Conductos De Aceite (Cazo 1) / Oil Piping(Bucket)
Conductos De Aceite (S/P) / Oil Piping(S/P)
Conductos De Aceite (Succion) / Oil Piping(Suction)
Conductos De Aceite (Retorno) / Oil Piping(Return)
Conductos De Aceite (Enf) (No.S.55564-) / Oil Piping(Oil Cooler)
Conductos De Aceite (Func.Izdo.) / Oil Piping(Operation Lh)
Conductos De Aceite (Func.Dcho.) / Oil Piping(Operation Rh)
Conductos De Aceite (Trasl.Izda.) / Oil Piping(Travel Lh)
Conductos De Aceite (Trasl.Dcha.) / Oil Piping(Travel Rh)
Conductos De Aceite (Rotacion 1) / Oil Piping(Swivel)
Conductos De Aceite (Oscilacion) / Oil Piping(Swing)
Conductos De Aceite (Brazo Pr.1) / Oil Piping(Boom)
Conductos De Aceite (Brazo 1) / Oil Piping(Arm)
Conductos De Aceite (Hoja) / Oil Piping(Blade)
Mordaza (Conductos Aceite) / Clamp(Oil Piping)
Maintenance Parts
Carter / Crankcase
Carter De Aceite / Oil Pan
Culata / Cylinder Head
Tapa De La Culata / Head Cover
Soporte Del Motor / Engine Bracket
Cojinete Del Ciguenal / Main Bearing Case
Arbol Levas Y Eje Vel.Dir. / Camshaft And Idle Gear Shaft
Piston Y Ciguenal / Piston And Crankshaft
Volante Motor / Flywheel
Arbol Levas Comb. Eje Reg. / Fuel Camshaft Governor Shaft
Palanca De Paro Del Motor / Engine Stop Lever
Bomba De Inyeccion / Injection Pump
Placa De Control De Veloc. / Speed Control Plate
Motor De Arranque / Starter
Motor Arranq.(Componentes) / Starter(Comp.Parts)
Alternador Y Polea / Alternator And Pulley
Alternador (Componentes) / Alternator(Comp.Parts)
Brida De Agua Y Termostato / Water Flange And Thermostat
Bomba De Agua / Water Pump
Conducto De Agua / Water Pipe
Valvula Y Balancin / Valve And Rocker Arm
Colector De Escape / Exhaust Manifold
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Juego De Juntas Superior / Gasket Kit Upper
Juego De Juntas Inferior / Gasket Kit Lower
Chasis Del Montacargas / Track Frame
Rodillo / Idler
Rodillo Inferior / Track Roller
Oruga / Crawler
