702,019
Kubota Excavator KX121-2 Parts Manual
Type of Machine: Excavator
Model: Kubota KX121-2 Excavator
Number of Pages: 309 Pages
Instructions For Parts Books
All Product Index
Crankcase
Oil Pan
Piston And Crankshaft
Main Bearing Case
Camshaft
Valve And Rocker Arm
Cylinder Head Cover
Gear Case
Nozzle Holder And Glow Plug
Speed Control Plate
Engine Stop Lever
Governor
Injection Pump [Component Parts]
Fuel Camshaft
Water Flange
Flywheel,Starter
Starter [Component Parts]
Alternator [Component Parts]
Engine Bracket
Air Cleaner,Inlet Manifold
Muffler,Exhaust Manifold
Accel Lever
Fuel Piping
Fuel Filter [Component Parts]
Water Pipe
Battery
Timer,Horn
Switch,Meter
Electrical Wiring
Pump Housing
Piston Pump And Component Parts
Hydraulic Pump And Component Parts
Drive Motor And Component Parts (1)
Drive Motor And Component Parts (2)
Swivel Motor And Component Parts
Rotary Joint
Oil Tank
Control Valve
Control Valve [Component Parts]
Spool Section (Bucket-Swivel)
Spool Section (Boom)
Spool Section (Travel Rh)
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (S-P)
Spool Section (Travel Straight)
Spool Section (Swing-Blade)
Change Valve
Change Valve [Component Parts]
Multi Valve
Tpss Valve
Multi Valve [Component Parts]
Tpss Valve [Component Parts]
Control Lever (Frame)
Control Lever (Lever Lh)
Control Lever (Lever Rh)
Pilot Valve [Component Parts]
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel-Swing Change)
Control Lever (Tpss)
Control Lever (Blade)
Control Lever (S-P 1)
Control Lever (S-P 2)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel 1)
Oil Piping (Swivel 2)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Clamp)
Oil Piping (S-P)
Boom Cylinder And Component Parts
Arm Cylinder And Component Parts
Bucket Cylinder And Component Parts
Blade Cylinder And Component Parts
Swing Cylinder And Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Track Frame
Idler
Track Roller
Crawler
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Seat Support
Step
Cover (Left)
Cover (Tank)
Bonnet
Sponge (1)
Sponge (2)
Weight
Canopy
Cabin (Body)
Cabin (Door)
Cabin (Window 1)
Cabin (Window 2)
Cabin (Sponge)
Cabin (Partition Plate)
Instrument Panel
Cabin (Electrical Wiring)
Cabin (Wiper Motor)
Cabin (Heater)
Cabin (Defroster)
Light
Label
Weight Kit [Option]
Label Kit [Option]
