Kubota Excavator KX121-2 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX121-2 Excavator
Region: Australia
Number of Pages: 313 Pages
Basic Engine _ Crankcase
Basic Engine _ Oil Pan
Basic Engine _ Piston And Crankshaft
Basic Engine _ Main Bearing Case
Basic Engine _ Camshaft
Basic Engine _ Cylinder Head
Basic Engine _ Valve And Rocker Arm
Basic Engine _ Cylinder Head Cover
Basic Engine _ Gear Case
Basic Engine _ Engine Bracket
Air Intake System _ Air Cleaner Inlet Manifold
Exhaust System _ Muffler,Exhaust Manifold
Fuel System _ Nozzle Holder And Glow Plug
Fuel System _ Speed Control Plate
Fuel System _ Engine Stop Lever
Fuel System _ Governor
Fuel System _ Injection Pump ## S.No.;_=239681
Fuel System _ Fuel Camshaft
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter [Component Parts]
Fuel System _ Fuel Tank
Cooling System _ Water Flange
Cooling System _ Water Pump
Cooling System _ Radiator
Cooling System _ Water Pipe
Electrical System _ Flywheel,Starter
Electrical System _ Starter [Component Parts]
Electrical System _ Alternator
Electrical System _ Alternator [Component Parts]
Electrical System _ Battery
Electrical System _ Timer,Horn
Electrical System _ Switch,Meter
Hydraulic System _ Pump Housing
Hydraulic System _ Piston Pump And Component Parts
Hydraulic System _ Hydraulic Pump And Component Parts
Hydraulic System _ S039-1 Drive Motor And Component Parts (1)
Hydraulic System _ S039-2 Drive Motor And Component Parts (2)
Hydraulic System _ Swivel Motor And Component Parts
Hydraulic System _ Rotary Joint
Hydraulic System _ Oil Tank
Hydraulic System _ Control Valve
Hydraulic System _ Control Valve [Component Parts]
Hydraulic System _ S045-1 Spool Section (Bucket_Swivel)
Hydraulic System _ S045-2 Spool Section (Boom)
Hydraulic System _ S045-3 Spool Section (Travel Rh)
Hydraulic System _ S045-4 Spool Section (Travel Lh)
Hydraulic System _ S045-5 Spool Section (Arm)
Hydraulic System _ S045-6 Spool Section (S_P)
Hydraulic System _ S045-7 Spool Section (Travel Straight)
Hydraulic System _ S045-8 Spool Section (Swing_Blade)
Hydraulic System _ Change Valve
Hydraulic System _ Change Valve [Component Parts]
Hydraulic System _ S048-1 Multi Valve ## S.No.A_=10429
Hydraulic System _ S048-2 TPSS Valve ## S.No.A_=10430
Hydraulic System _ S049-1 Multi Valve [Component Parts] ## S.No.A_=10429
Hydraulic System _ S049-2 TPSS Valve [Component Parts] ## S.No.A_=10430
Hydraulic System _ Control Lever (Frame)
Hydraulic System _ Control Lever (Lever Lh)
Hydraulic System _ Control Lever (Lever Rh)
Hydraulic System _ Pilot Valve [Component Parts]
Hydraulic System _ Control Lever (Travel Lh)
Hydraulic System _ Control Lever (Travel Rh)
Hydraulic System _ Control Travel Pedal
Hydraulic System _ Control Lever (Safety Lock Lever)
Hydraulic System _ Control Pedal (Swivel_Swing Change)
Hydraulic System _ S059-1 Control Lever (TPSS) ## S.No.A_=10429
Hydraulic System _ S059-2 Control Lever (TPSS) ## S.No.A_=10430
Hydraulic System _ Control Lever (Blade)
Hydraulic System _ Control Lever (S_P 1)
Hydraulic System _ Control Lever (S_P 2)
Hydraulic System _ Oil Piping (Suction)
Hydraulic System _ Oil Piping (Delivery)
Hydraulic System _ Oil Piping (Return)
Hydraulic System _ Oil Piping (Oil Cooler)
Hydraulic System _ Oil Piping (Travel Lh)
Hydraulic System _ Oil Piping (Travel Rh)
Hydraulic System _ S069-1 Oil Piping (Swivel 1) ## S.No.A_=10429
Hydraulic System _ S069-2 Oil Piping (Swivel 1) ## S.No.A_=10430
Hydraulic System _ Oil Piping (Swivel 2) ## # Rev.Mar.5 '01
Hydraulic System _ Oil Piping (Swing)
Hydraulic System _ Oil Piping (Lock)
Hydraulic System _ S073-1 Oil Piping (Boom 1) ## S.No.A_=10429
Hydraulic System _ S073-2 Oil Piping (Boom 1) ## S.No.A_=10430
Hydraulic System _ Oil Piping (Boom 2)
Hydraulic System _ S075-1 Oil Piping (Arm 1) ## S.No.A_=10429
Hydraulic System _ S075-2 Oil Piping (Arm 1) ## S.No.A_=10430
Hydraulic System _ Oil Piping (Arm 2)
Hydraulic System _ S077-1 Oil Piping (Bucket 1) ## S.No.A_=10429
Hydraulic System _ S077-2 Oil Piping (Bucket 1) ## S.No.A_=10430
Hydraulic System _ Oil Piping (Bucket 2)
Hydraulic System _ Oil Piping (Blade)
Hydraulic System _ Oil Piping (Clamp) ## # Rev.Mar.5 '01
Hydraulic System _ Oil Piping (S_P)
Hydraulic System _ Boom Cylinder And Component Parts
Hydraulic System _ Arm Cylinder And Component Parts
Hydraulic System _ Bucket Cylinder And Component Parts
Hydraulic System _ Blade Cylinder And Component Parts
Hydraulic System _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Swivel Gear Case
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
Swivel Frame _ Cover (Left)
Swivel Frame _ Cover (Tank)
Swivel Frame _ Bonnet
Swivel Frame _ Sponge (1)
Swivel Frame _ Sponge (2)
Swivel Frame _ Weight
Operator's Platform _ Canopy
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Sponge)
Operator's Platform _ Cabin (Partition Plate) ## S.No.A_=10430
Operator's Platform _ Instrument Panel
Operator's Platform _ Seat
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Cabin (Defroster)
Operator's Platform _ Light
Operator's Platform _ Label
Accessories _ Accessories
Accessories _ Weight Kit [Option]
Accessories _ Label Kit [Option]
Region: Australia
Track Frame _ Idler
Swivel Frame _ Step
