Kubota Excavator KX101 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX101 Excavator
Number of Pages: 305 Pages
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Stop Lever
Engine Bracket
Air Cleaner Inlet Manifold / Air Cleaner Inlet Manifold
Air Cleaner Inlet Manifold [Kta]
Muffler Exhaust Manifold
Nozzle Holder Glow Plug
Nozzle Holder (Component Parts)
Speed Control Plate
Governor
Injection Pump Camshaft (1)
Injection Pump (Component Parts)
Injection Pump Camshaft (2)
Engine Stop Lever
Accel Lever
Fuel Piping
Water Flange
Water Pipe
Flywheel Starter
Starter (Component Parts)
Dynamo
Dynamo (Component Parts)
Battery
Regulator Horn
Switch Meter
Electrical Wiring
Pump Housing
Gear Pump & Component Parts
Hydraulic Pump & Component Parts
Drive Motor & Component Parts 1
Drive Motor & Component Parts 2
Swivel Motor & Component Parts
Rotary Joint
Oil Tank
Control Valve (1)
Control Valve (1) (Component Parts)
Spool Section (Travel Rh)
Switch Meter
Spool Section (Boom)
Spool Section (Bucket)
Spool Section
Spool Section (Travel Speed 2nd)
Spool Section (Travel Lh)
Spool Section (Arm)
Spool Section (S/P) / Spool Section (S/P)
Spacer Section
Control Valve (3)
Control Valve (3) (Component Parts)
Spool Section (Swivel)
Spool Section (Swing)
Spool Section (Blade)
Change Valve
Control Lever (Frame)
Control Lever (Box Lh)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Box Rh)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Third Line)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Unload Valve) (Component Parts)
Oil Piping (Return)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel / Swing) / Oil Piping (Swivel / Swing)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Confluence)
Oil Piping (Cushion)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder & Component Parts
Arm Cylinder & Component Parts
Bucket Cylinder & Component Parts
Blade Cylinder & Component Parts
Swing Cylinder & Component Parts
Swing Bracket
Boom
Cylinder Cover (Boom)
Arm
Bucket Link
Bucket
Blade
Truck Frame
Idler
Truck Roller
Crawler
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Floor Plate (1)
Floor Plate (2)
Bonnet
Sponge (1) [Ke Kdg Kuk M.E.]
Sponge (1) [Ktc Kcl Kta]
Sponge (2)
Sponge (3) [Ke Kdg Kuk M.E.]
Sponge (3) [Ktc Kcl Kta]
Weight
Canopy [M.E.]
Canopy (Rops) [Ktc Kcl Kta]
Cabin (Body) [Ke Kdg Kuk]
Cabin (Body) [Ktc Kcl Kta]
Cabin (Door) [Ke Kdg Kuk]
Cabin (Door) [Ktc/Kcl/Kta] / Cabin (Door) [Ktc/Kcl/Kta]
Cabin (Front Window) [Ke Kdg Kuk]
Cabin (Front Window) [Ktc Kcl Kta]
Cabin (Window) [Ke Kdg Kuk]
Cabin (Window) [Ktc Kcl Kta]
Cabin (Sponge) [Ke Kdg Kuk]
Cabin (Sponge) [Ktc Kcl Kta]
Instrument Panel
Seat [Ke Kdg Kuk]
Seat [Ke Kdg Kuk]
Seat [Ktc Kcl M.E. Kta]
Cabin (Electrical)
Cabin (Wiper Motor)
Cabin (Defroster)
Cabin (Heater)
Light
Label [Ke Kdg Kuk M.E.]
Label [Ktc Kcl Kta]
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Stop Lever
Engine Bracket
Speed Control Plate
Governor
Engine Stop Lever
Accel Lever
Fuel Piping
Water Flange
Water Pipe
Flywheel Starter
Dynamo
Battery
Regulator Horn
Switch Meter
Electrical Wiring
Pump Housing
Rotary Joint
Oil Tank
Control Valve (1)
Switch Meter
Spool Section
Spool Section (Arm)
Spacer Section
Control Valve (3)
Change Valve
Oil Piping (Return)
Oil Piping (Swivel)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 2)
Oil Piping (Blade)
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Truck Frame
Idler
Truck Roller
Crawler
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Floor Plate (1)
Floor Plate (2)
Bonnet
Sponge (2)
Weight
Canopy [M.E.]
Instrument Panel
Seat [Ke Kdg Kuk]
Seat [Ke Kdg Kuk]
Cabin (Electrical)
Cabin (Wiper Motor)
Cabin (Defroster)
Cabin (Heater)
Light
Label [Ktc Kcl Kta]
