702,019
Kubota Excavator KX101 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX101 Excavator
Region: Australia
Number of Pages: 306 Pages
Basic Engine _ Crankcase
Basic Engine _ Oil Pan
Basic Engine _ Piston Crankshaft
Basic Engine _ Main Bearing Case
Basic Engine _ Camshaft
Basic Engine _ Cylinder Head
Basic Engine _ Valve Rocker Arm
Basic Engine _ Cylinder Head Cover
Basic Engine _ Gear Case
Basic Engine _ Engine Stop Lever
Basic Engine _ Engine Bracket
Air Intake System _ Air Cleaner Inlet Manifold
Air Intake System _ Air Cleaner Inlet Manifold [Kta] ## S.No.;_=11741
Exhaust System _ Muffler Exhaust Manifold
Fuel System _ Nozzle Holder Glow Plug
Fuel System _ Nozzle Holder (Component Parts)
Fuel System _ Speed Control Plate
Fuel System _ Governor
Fuel System _ Injection Pump Camshaft (1)
Fuel System _ Injection Pump (Component Parts)
Fuel System _ Injection Pump Camshaft (2)
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Tank
Cooling System _ Water Flange
Cooling System _ Water Pump
Cooling System _ Radiator
Cooling System _ Water Pipe
Electrical System _ Flywheel Starter
Electrical System _ Starter (Component Parts) ## S.No.;_=15605
Electrical System _ Starter (Component Parts) ## S.No.;_=15606
Electrical System _ Dynamo
Electrical System _ Dynamo (Component Parts)
Electrical System _ Battery
Electrical System _ Regulator Horn
Electrical System _ Switch Meter
Hydraulic System _ Pump Housing
Hydraulic System _ Gear Pump & Component Parts
Hydraulic System _ Hydraulic Pump & Component Parts
Hydraulic System _ Drive Motor & Component Parts 1
Hydraulic System _ Drive Motor & Component Parts 2
Hydraulic System _ Swivel Motor & Component Parts
Hydraulic System _ Rotary Joint
Hydraulic System _ Oil Tank
Hydraulic System _ Control Valve (1)
Hydraulic System _ Control Valve (1) (Component Parts)
Hydraulic System _ Spool Section (Travel Rh)
Hydraulic System _ Spool Section (Boom)
Hydraulic System _ Spool Section (Bucket)
Hydraulic System _ Spool Section (Travel Speed 2nd)
Hydraulic System _ Spool Section (Travel Lh)
Hydraulic System _ Spool Section (Arm)
Hydraulic System _ Spool Section (S_P)
Hydraulic System _ Spacer Section
Hydraulic System _ Control Valve (3)
Hydraulic System _ Control Valve (3) (Component Parts)
Hydraulic System _ Spool Section (Swivel)
Hydraulic System _ Spool Section (Swing)
Hydraulic System _ Spool Section (Blade)
Hydraulic System _ Change Valve
Hydraulic System _ Control Lever (Frame)
Hydraulic System _ Control Lever (Box Lh)
Hydraulic System _ Control Lever (Lever Lh)
Hydraulic System _ Pilot Valve (Component Parts)
Hydraulic System _ Control Lever (Box Rh)
Hydraulic System _ Control Lever (Lever Rh)
Hydraulic System _ Control Lever (Travel Lh)
Hydraulic System _ Control Lever (Travel Rh)
Hydraulic System _ Control Travel Pedal
Hydraulic System _ Control Lever (Safety Lock Lever)
Hydraulic System _ Control Pedal (Swivel_Swing Change)
Hydraulic System _ Control Lever (Blade)
Hydraulic System _ Control Lever (S_P)
Hydraulic System _ Oil Piping (Third Line)
Hydraulic System _ Oil Piping (Suction)
Hydraulic System _ Oil Piping (Delivery)
Hydraulic System _ Oil Piping (Unload Valve) (Component Parts)
Hydraulic System _ Oil Piping (Return)
Hydraulic System _ Oil Piping (Oil Cooler) ## S.No.;_=11014
Hydraulic System _ Oil Piping (Oil Cooler) ## S.No.;_=11015
Hydraulic System _ Oil Piping (Travel Lh)
Hydraulic System _ Oil Piping (Travel Rh)
Hydraulic System _ Oil Piping (Swivel _ Swing)
Hydraulic System _ Oil Piping (Swivel)
Hydraulic System _ Oil Piping (Swing)
Hydraulic System _ Oil Piping (Lock)
Hydraulic System _ Oil Piping (Boom 1)
Hydraulic System _ Oil Piping (Boom 2)
Hydraulic System _ Oil Piping (Arm 1)
Hydraulic System _ Oil Piping (Arm 2)
Hydraulic System _ Oil Piping (Bucket 1)
Hydraulic System _ Oil Piping (Bucket 2)
Hydraulic System _ Oil Piping (Blade)
Hydraulic System _ Oil Piping (Confluence)
Hydraulic System _ Oil Piping (Cushion)
Hydraulic System _ Oil Piping (S_P)
Hydraulic System _ Boom Cylinder & Component Parts
Hydraulic System _ Arm Cylinder & Component Parts
Hydraulic System _ Bucket Cylinder & Component Parts
Hydraulic System _ Blade Cylinder & Component Parts
Hydraulic System _ Swing Cylinder & Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Truck Frame _ Truck Frame
Truck Frame _ Idler
Truck Frame _ Truck Roller
Truck Frame _ Crawler
Swivel Frame _ Swivel Frame
Swivel Frame _ Swivel Gear Case
Swivel Frame _ Swivel Bearing
Swivel Frame _ Floor Plate (1)
Swivel Frame _ Floor Plate (2)
Swivel Frame _ Bonnet
Swivel Frame _ Sponge (1) [Ke Kdg Kuk M.E.]
Swivel Frame _ Sponge (1) [Ktc Kcl Kta]
Swivel Frame _ Sponge (2)
Swivel Frame _ Sponge (3) [Ke Kdg Kuk M.E.]
Swivel Frame _ Sponge (3) [Ktc Kcl Kta]
Swivel Frame _ Weight
Operator's Platform _ Canopy [M.E.]
Operator's Platform _ Canopy (Rops) [Ktc Kcl Kta]
Operator's Platform _ Cabin (Body) [Ke Kdg Kuk]
Operator's Platform _ Cabin (Body) [Ktc Kcl Kta]
Operator's Platform _ Cabin (Door) [Ke Kdg Kuk]
Operator's Platform _ Cabin (Door) [Ktc_Kcl_Kta]
Operator's Platform _ Cabin (Front Window) [Ke Kdg Kuk]
Operator's Platform _ Cabin (Front Window) [Ktc Kcl Kta]
Operator's Platform _ Cabin (Window) [Ke Kdg Kuk]
Operator's Platform _ Cabin (Window) [Ktc Kcl Kta]
Operator's Platform _ Cabin (Sponge) [Ke Kdg Kuk]
Operator's Platform _ Cabin (Sponge) [Ktc Kcl Kta]
Operator's Platform _ Instrument Panel
Operator's Platform _ Seat [Ke Kdg Kuk] ## S.No.;_=11366
Operator's Platform _ Seat [Ke Kdg Kuk] ## S.No.;_=11367
Operator's Platform _ Seat [Ktc Kcl M.E. Kta]
Operator's Platform _ Cabin (Electrical)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Defroster)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Light
Operator's Platform _ Label [Ke Kdg Kuk M.E.]
Operator's Platform _ Label [Ktc Kcl Kta]
Accessories _ Accessories
