Kubota Excavator KX101 -55001 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX101 Excavator
Serial Number: -55001
Number of Pages: 296 Pages
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Stop Lever
Engine Bracket
Water Flange
Water Pipe
Flywheel Starter
Dynamo
Battery
Regulator Horn
Switch Meter
Electrical Wiring
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Nozzle Holder Glow Plug
Speed Control Plate
Governor
Accel Lever
Fuel Piping
Pump Housing
Rotary Joint
Oil Tank
Control Valve (1)
Spool Section
Spacer Section
Control Valve (3)
Change Valve
Change Valve
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Arm 2)
Oil Piping (Blade)
Cabin (Door)
Cabin (Window)
Cabin (Sponge)
Cabin (Light)
Cabin (Heater)
Light
Label
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Floor Plate (1)
Floor Plate (2)
Bonnet
Sponge (1)
Sponge (2)
Sponge (3)
Weight
Truck Frame
Cabin (Heater)
Idler
Truck Roller
Crawler
Spool Section (Travel Speed 2nd)
Spool Section (S/P) / Spool Section (S/P)
Blade Cylinder & Component Parts
Swing Cylinder & Component Parts
Cylinder Cover (Boom)
Air Cleaner Inlet Manifold
Muffler Exhaust Manifold
Cabin (Electrical)
Control Valve (3) (Component Parts)
Cabin (Electrical)
Cabin (Front Window)
Cabin (Rubber Seal)
Cabin (Wiper Motor)
Instrument Panel
Nozzle Holder (Component Parts)
Injection Pump Camshaft (1)
Injection Pump (Component Parts)
Injection Pump Camshaft (2)
Starter (Component Parts)
Spool Section (Swivel)
Dynamo (Component Parts)
Gear Pump & Component Parts
Hydraulic Pump & Component Parts
Drive Motor & Component Parts 1
Drive Motor & Component Parts 2
Swivel Motor & Component Parts
Control Valve (1) (Component Parts)
Spool Section (Travel Rh)
Spool Section (Boom)
Spool Section (Swing)
Spool Section (Bucket)
Spool Section (Blade)
Control Lever (Frame)
Control Lever (Box Lh)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Box Rh)
Spool Section (Travel Lh)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Oil Piping (Third Line)
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Unload Valve) (Component Parts)
Oil Piping (Return C/V Tank) / Oil Piping (Return C/V Tank)
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel / Swing) / Oil Piping (Swivel / Swing)
Oil Piping (Swivel)
Spool Section (Arm)
Oil Piping (Swivel)
Oil Piping (Boom 1)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 1)
Oil Piping (Arm 1)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Confluence)
Oil Piping (Cushion)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder & Component Parts
Arm Cylinder & Component Parts
Valve Rocker Arm
Bucket Cylinder & Component Parts
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Cylinder Head Cover
Gear Case
Engine Stop Lever
Engine Bracket
Water Flange
Water Pipe
Flywheel Starter
Dynamo
Battery
Regulator Horn
Switch Meter
Electrical Wiring
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Speed Control Plate
Governor
Accel Lever
Fuel Piping
Pump Housing
Rotary Joint
Oil Tank
Control Valve (1)
Spool Section
Spacer Section
Control Valve (3)
Change Valve
Change Valve
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Arm 2)
Oil Piping (Blade)
Cabin (Door)
Cabin (Window)
Cabin (Sponge)
Cabin (Light)
Cabin (Heater)
Light
Label
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Floor Plate (1)
Floor Plate (2)
Bonnet
Sponge (1)
Sponge (2)
Sponge (3)
Weight
Truck Frame
Cabin (Heater)
Idler
Truck Roller
Crawler
Cabin (Electrical)
Cabin (Electrical)
Cabin (Rubber Seal)
Cabin (Wiper Motor)
Instrument Panel
Oil Piping (Swivel)
Spool Section (Arm)
Oil Piping (Swivel)
Oil Piping (Boom 1)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Oil Piping (Arm 1)
Oil Piping (Arm 1)
Valve Rocker Arm
