Kubota Excavator KX101 50001-55000 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX101 Excavator
Serial Number: 50001-55000
Number of Pages: 279 Pages
Crankcase
Oil Pan
Piston Crankshaft
Main Bearing Case
Camshaft
Valve Rocker Arm
Gear Case
Engine Stop Lever
Engine Bracket
Water Flange
Water Pipe
Dynamo
Battery
Switch Meter
Swing Bracket
Boom
Arm
Bucket Link
Bucket
Blade
Speed Control Plate
Governor
Accel Lever
Fuel Piping
Pump Housing
Rotary Joint
Oil Tank
Spool Section
Spacer Section
Change Valve
Light
Label
Swivel Frame
Swivel Gear Case
Swivel Gear
Swivel Bearing
Floor Plate (1)
Floor Plate (2)
Bonnet
Sponge (1)
Sponge (2)
Sponge (3)
Weight
Truck Frame
Idler
Truck Roller
Crawler
Spool Section (Travel Speed 2nd)
Control Valve (3)
Blade Cylinder & Component Parts
Swing Cylinder & Component Parts
Cylinder Cover (Boom)
Air Cleaner Inlet Manifold
Muffler Exhaust Manifold
Cabin (Body)
Control Valve (3)
Cabin (Body)
Cabin (Door)
Cabin (Front Window)
Cabin (Window)
Cabin (Sponge)
Control Valve (3) (Component Parts)
Cabin (Wiper Motor)
Cabin (Defroster)
Cabin (Electrical)
Cabin (Heater)
Nozzle Holder Glow Plug
Instrument Panel
Nozzle Holder (Component Parts)
Injection Pump Camshaft (1)
Injection Pump (Component Parts)
Injection Pump Camshaft (2)
Spool Section (Swivel)
Flywheel Starter
Starter (Component Parts)
Dynamo (Component Parts)
Regulator Horn
Electrical Wiring
Gear Pump & Component Parts
Hydraulic Pump & Component Parts
Drive Motor & Component Parts 1
Drive Motor & Component Parts 2
Spool Section (Swing)
Swivel Motor & Component Parts
Control Valve (1)
Control Valve (1) (Component Parts)
Spool Section (Travel Rh)
Spool Section (Boom)
Spool Section (Bucket)
Spool Section (Blade)
Spool Section (Travel Lh)
Control Lever (Frame)
Control Lever (Box Lh)
Control Lever (Lever Lh)
Pilot Valve (Component Parts)
Control Lever (Box Rh)
Control Lever (Lever Rh)
Control Lever (Travel Lh)
Control Lever (Travel Rh)
Control Travel Pedal
Control Lever (Safety Lock Lever)
Control Pedal (Swivel/Swing Change) / Control Pedal (Swivel/Swing Change)
Control Lever (Blade)
Control Lever (S/P) / Control Lever (S/P)
Cylinder Head Cover
Oil Piping (Suction)
Oil Piping (Delivery)
Oil Piping (Unload Valve) (Component Parts)
Oil Piping (Return C/V Tank) / Oil Piping (Return C/V Tank)
Cylinder Head Cover
Oil Piping (Oil Cooler)
Oil Piping (Travel Lh)
Oil Piping (Travel Rh)
Oil Piping (Swivel / Swing) / Oil Piping (Swivel / Swing)
Oil Piping (Swivel)
Spool Section (Arm)
Oil Piping (Swing)
Oil Piping (Lock)
Oil Piping (Boom 1)
Oil Piping (Boom 2)
Oil Piping (Arm 1)
Spool Section (S/P) / Spool Section (S/P)
Oil Piping (Arm 2)
Oil Piping (Bucket 1)
Oil Piping (Bucket 2)
Oil Piping (Blade)
Oil Piping (Confluence)
Oil Piping (Cushion)
Oil Piping (S/P) / Oil Piping (S/P)
Boom Cylinder & Component Parts
Arm Cylinder & Component Parts
Bucket Cylinder & Component Parts
