Kubota Excavator KX101-3ALPHA3 -85001 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Excavator
Model: Kubota KX101-3ALPHA3 Excavator
Serial Number: -85001
Number of Pages: 213 Pages
Content
Pedale De C Ommande (Pivot/ Change De Osc. 1) / Control Pedal ( Swivel/ Swing Change 1)
Pedale De C Ommande (Pivot/ Change De Osc. 2) / Control Pedal ( Swivel/ Swing Change 2)
Mot Eur De Voyage (Parties Comp.) (1) / Drive Moter And Component Parts (1)
Mot Eur De Bascule (Parties Comp.) (1) / Swivel Motor A Nd Component Parts (1)
Mot Eur De Bascule (Parties Comp.) (2) / Swivel Motor A Nd Component Parts (2)
Mo Teur De Voyage (Parties Comp.) (2) / Drive Moter An D Component Parts (2)
Soupape De Controle (Parties Comp.) / Control Valve (Compon Ent Parts)
Soupape Dechargement (Parties Comp.) / Unload Valve (Compon Ent Parts)
Soupape De Pilote (Parties Comp.) G. / Pilot Valve (Compone Nt Parts) Lh
Soupape De Pilote (Parties Comp.) Dr. / Pilot Valve (Compon Ent Parts) Rh
Levier D E Commande (Deplacement, G.) 1 / Control Lever (Tra Vel Lh) 1
Levier D E Commande (Deplacement, G.) 2 / Control Lever (Tra Vel Lh) 2
Levier D E Commande (Deplacement Dr.) 1 / Control Lever (Tra Vel Rh) 1
Levier De C Ommende (Levier De Verrouillage) / Control Lever (S Afety Lock Lever)
Pis Ton, Pompe (Parties Comp.) / Piston Pump (Component Parts)
Bkida5054 >> Kx101-3alpha3 [S/N;>=85001]
Accessoires / Access Ories
Support Balancement / Swing Bracket
Fleche / Boom
Fleche / Boom
Couvercl E De Cylindre (Fleche) / Cylinder Cover (Boom)
Bras / A Rm
Maillon De Godet / Bucket Link
Godet / Bucket
Lame / B Lade
Lame / B Lade
Cadre De Piste / Truck Frame
Intermediaire / Idler
Galet De Cheni Lle / Track Roller
Chenille / Cra Wler
Tube (Succio N) / Oil Piping (Suction)
Tube (Delivr Ance) / Oil Piping (Delivery)
Tube (Retour 1) / Oil Piping (Return 1)
Tube (Retour 2) / Oil Piping (Return 2)
Tube (Refroi Disseur) / Oil Piping (Oil Cooler)
Tube (Operat Ion G) / Oil Piping (Operation Lh)
Tube (Operat Ion D) / Oil Piping (Operation Rh)
Tube (Deplac Ement Gauche) / Oil Piping (Travel Lh)
Tube (Deplac Emunt Droite) / Oil Piping (Travel Rh)
Tube (Pivot) / Oil Piping (Swivel)
Tube (Balanc Ement) / Oil Piping (Swing)
Tube (Flech) / Oil Piping (Boom)
Tube (Bras) / Oil Piping (Arm)
Tube (Godet) / Oil Piping (Bucket)
Tube (Lame) / Oil Piping (Blade)
Tube (Attach E) / Oil Piping (Clamp)
Tube (S/P 1) / Oil Piping (S/P 1)
Tube (S/P 2) / Oil Piping (S/P 2)
Moteur De Rale Nt. En Auto / Auto Idle Motor
Tuyautage De C Arburant / Fuel Piping
Séparateur D'e Au (Parties Comp.) / Moist Separator (Component Par Ts)
Reservoir Carb . / Fuel Tank
Chassis Pivot / S Wivel Frame
Chassis De Capote / Arch Frame
Roulement De Basc Ule / Swivel Bearing
Marche / Step
Marche / Step
Fleche Cylindre (Parties C Omp.) / Boom Cylinder And Component Parts
Bras Cylindre (Parties Com P.) / Arm Cylinder And Component Parts
Godet Cylindre (Parties Co Mp.) / Bucket Cylinder And Component Parts
Lame Cylindre (Parties Com P.) / Blade Cylinder And Component Parts
Balancement Cylindre (Part Ies Comp.) / Swing Cylinder And Component Parts
Distribu Teur Hydraulique / Control Valve
Section De Tiroir (Admission) / Spool Section (Inlet)
Section De Tiroir (Pivot) / Spool Section (Swivel)
Section De Tiroir (Balancement) / Spool Section (Swing)
Section De Tiroir (Lame) / Spool Section (Blade)
Section De Tiroir (S/P) / Spool Section (S/P)
Section De Tiroir (Bras) / Spool Section (Arm)
Section De Tiroir (Deplacement G.) / Spool Section (Travel Lh)
Section De Tiroir (Deplacement D.) / Spool Section (Travel Rh)
Section De Tiroir (Fleche) / Spool Section (Boom)
Section De Tiroir (Godet) / Spool Section (Bucket)
Section De Tiroir (Vidange) / Spool Section (Outlet)
Soupape Dechargement / Unload Valve
Changeme Nt Soupape / Change Valve
Soupape (Sp) / Valve (Sp)
Levier D E Commande (Levier Gauche) / Control Lever (Lever L H)
Levier D E Commande (Levier Droite) / Control Lever (Rh)
Tempor Isateur, Avertisseur / Timer And Horn
Interr Upteur, Metre / Switch And Meter
Lampe / Light
Faisce Au Electrique / Wire Harness
Auvent / Canopy
Cabine (Eponge) / Cabin (Sponge)
Cabine (Glace 1) / Cabin (Window 1)
Cabine (Glace 2) / Cabin (Window 2)
Cabine (Porte) / Cabin (Door)
Cabine (Moteur, Essuie-Glace) / Cabin (Wiper Motor)
Cabin (Accessori Es) / Cabin (Accessories)
Cabine (Chauffag E) / Cabin (Heater)
Etiquette / Label
Etiquette / Label
Etiquette / Label
Couv Ercle (Gauche) / Cover (Lh)
Couv Ercle (Droite) / Cover (Rh)
Capo T (Gauge) / Bonnet (Lh)
Capo T (Droite) / Bonnet (Rh)
Capo T (Arriere) / Bonnet (Back)
Epon Ge (1) / Sponge (1)
Epon Ge (2) / Sponge (2)
Cont Repoids / Weight
Sieg E / Seat
Sieg E / Seat
Levier De C Ommande (Deplacement Dr.) 2 / Control Lever (Travel Rh) 2
Levier De C Ommande (Lame) / Control Lever (Blade)
Bloc Moteur / Crankcase
Culasse / Cylinder Head
Kit D'accouplements Rapides [O Ption] / Gear Case
Console De Moteur / Engine Bra Cket
Paliers De Principal / Main Be Aring Case
Arbre A Cames Et Arbre De Pign On Intermediaire / Camshaft And Idle Gear Shaft
Pistons Et Vilebrequin / Pisto N And Crankshaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carb. / Fuel Camshaft And Governor Shaft
Levier D Arret Du Moteur / Eng Ine Stop Lever
Regulateur De Vitesses / Gover Nor
Porte-Injecteur Et Bougie De P Rechauffage / Nozzle Holder And Glow Plug
Alternateur Complet / Alternat Or
Alternateur (Parties Comp.) / Alternator (Component Parts)
Lanceur / Starter
Demarreur (Parties Comp.) / St Arter (Component Parts)
Kit D'accouplements Rapides [O Ption] / Water Flange And Thermostat
Pompe A Eau / Water Pump
Radiateur / Radiator
Tuyau D'eau / Water Pipe
Soupapes Culbuteurs / Valve A Nd Rocker Arm
Collecteur D'echappement / Exh Aust Manifold
Filter A Air / Air Cleaner
Silencieux / Muffler
Refroidisseur D'huile / Oil Co Oler
Jeu De Joints, Superior / Gask Et Kit, Upper
Jeu De Joints, Inferior / Gask Et Kit, Lower
Clapet D'ar.Aut./Fleche / Pipe -Break Valve/Boom
Clapet D'ar.Aut./Bras / Pipe-B Reak Valve/Arm
Clapet D'ar.Aut./Lame / Pipe-B Reak Valve/Dozer
Systeme D'avertissement / Warn Ing System
Kit Pince (Sans Coupleur) / Cl Amp Kit (Without Quick-Coupler)
Kit D'accouplements A Face Pla Ne / Kit Flat-Face Coupler
Kit D'accouplements Rapides / Kit Plug-In Coupler
Kit D'accouplements Filetés / Kit Screw-Type Coupler
Godet, Coupleur / Bucket, Quic K-Coupler
Gap-Kit 2 / Gap-Kit 2
Kit Couvercle Bas / Kit Cover Bottom
Sp2 Kit, Base / Sp2 Kit Base
Sp2 Ens.Fleche / Sp2 Kit Boom
Retromatic Attache Rapide Séri E13 / Retromatic Qc-Series13
Kit Marteau Hydraulique / Kit Hydraulic Breaker
Kit Black Box / Kit Black Box
Palier - Km205 / Mounting Brac Kets - Km205
Kit Attache Rapide Hydraulique (Cabine) / Kit Quick Coupler Hydraulic(Cabin)
Attache Rapide Hydraulique / Q Uick Coupler Hydraulic
Palier - Km200 / Mounting Brac Kets - Km200
Piec Es De Maintenance / Maintenance Parts
Car Ter De Pompe / Pump Housing
Joi Nt Rotatif / Rotary Joint
Res Ervoir D'huile / Oil Tank
