Kubota Excavator KX101-3 55001-69999 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Excavator
Model: Kubota KX101-3 Excavator
Serial Number: 55001-69999
Number of Pages: 170 Pages
Content
Levier De Commende (Levier De Verrouillage) / Control Lever(Safety Loc K Lever)
Pedale De Commande (Pivot/Change De Osc.1) / Control Pedal(Swivel/Swin G Change 1)
Pedale De Commande (Pivot/Change De Osc.2) / Control Pedal(Swivel/Swin G Change 2)
Moteur De Voyage(Parties Comp.)(1) / Drive Moter And Componen T Parts(1)
Moteur De Voyage(Parties Comp.)(2) / Drive Moter And Componen T Parts(2)
Moteur De Bascule(Parties Comp.) / Swivel Motor And Component Parts(1)
Moteur De Bascule(Parties Comp.) / Swivel Motor And Component Parts(2)
Bkida0217 >> Kx101-3 [S/N;55001~69999]
Accessoires / Accessor Ies
Tube(Succ Ion) / Oil Piping(Suction)
Tube(Deli Vrance) / Oil Piping(Delivery)
Tube(Reto Ur 1) / Oil Piping(Return 1)
Tube(Reto Ur 2) / Oil Piping(Return 2)
Tube(Refr Oidisseur)(S.No.<=55563) / Oil Piping(Oil Cooler)(S .No.<=55563)
Tube(Refr Oidisseur)(S.No.>=55564) / Oil Piping(Oil Cooler)(S .No.>=55564)
Oil Pipin G(Operation Lh) / Oil Piping(Operation Lh)
Oil Pipin G(Operation Rh) / Oil Piping(Operation Rh)
Tube(Depl Acement Gauche) / Oil Piping(Travel Lh)
Tube(Depl Acemunt Droite) / Oil Piping(Travel Rh)
Tube(Pivo T 1) / Oil Piping(Swivel 1)
Tube(Bala Ncement) / Oil Piping(Swing)
Tube(Flec H 1) / Oil Piping(Boom 1)
Tube(Bras 1) / Oil Piping(Arm 1)
Tube(Gode T 1) / Oil Piping(Bucket 1)
Tube(Lame ) / Oil Piping(Blade)
Brid(Tube ) / Clamp(Oil Piping)
Tube(S/P) / Oil Piping(S/P)
Levier De Commande (Deplacement G.) 1 / Control Lever(Travel Lh) 1
Levier De Commande (Deplacement G.) 2 / Control Lever(Travel Lh) 2
Levier De Commande (Deplacement Dr.) 1 / Control Lever(Travel Rh) 1
Levier De Commande (Deplacement Dr.) 2 / Control Lever(Travel Rh) 2
Pedale De Commande De Vitesse D Evolution / Control Travel Pedal
Levier De Commande (Lame) / Control Lever(Blade)
Pedale(S/P) / Peda L(S/P)
Soupape De Control E / Control Valve
Soupape De Control E(Parties Comp.) / Control Valve(Component Parts)
Section De Tiroir( Pivot) / Spool Section(Swivel)
Section De Tiroir( Balancement) / Spool Section(Swing)
Section De Tiroir( Lame) / Spool Section(Blade)
Section De Tiroir( Fleche) / Spool Section(Boom) 1
Section De Tiroir( S/P) / Spool Section(S/P)
Section De Tiroir( Bras) / Spool Section(Arm)
Section De Tiroir( Deplacement G.) / Spool Section(Travel Lh)
Section De Tiroir( Deplacement D.) / Spool Section(Travel Rh)
Section De Tiroir( Fleche) / Spool Section(Boom) 2
Section De Tiroir( Fleche) / Spool Section(Boom) 3
Section De Tiroir( Godet) / Spool Section(Bucket)
Alimentation / Sup Ply Unit
Alimentation(Parti Es Comp.) / Supply Unit(Component Parts)
Changement Soupape / Change Valve
Levier De Commande (Levier Gauche) / Control Lever(Lever Lh)
Soupape De Pilote( Parties Comp.) G. / Pilot Valve(Component Parts) Lh
Levier De Commande (Levier Droite) / Control Lever(Lever Rh)
Soupape De Pilote( Parties Comp.) Dr. / Pilot Valve(Component Parts) R H
Fleche Cylindre(Parties Comp .) / Boom Cylinder And Component Parts
Bras Cylindre(Parties Comp.) / Arm Cylinder And Component Parts
Bras Cylindre.Telescopque(Pa Rties Comp.) / Arm Cylinder.Telescopic(Comp.Parts)
Godet Cyliendre(Parties Comp .) / Bucket Cylinder And Component Parts
Godet Cyliendre.Telescopque( Parties Comp.) / Bucket Cylinder.Telescopic(Comp.Pa Rts)
Lame Cylindre(Parties Comp.) / Blade Cylinder And Component Parts
Balancement Cylindre(Parties Comp.) / Swing Cylinder And Component Parts
Batterie / Battery
Batterie / Battery
Temporisat Eur Avertisseur Relais Ai / Timer Horn Relay Ai
Interrupte Ur Metre / Switch And Meter
Lampe / Li Ght
Faisceau D E Cables / Electrical Wiring
Bloc Moteur / Crankcase
Carter D Huile / Oil Pan
Culasse / Cylinder Head
Carter De Distribution / Gear Ca Se
Couvre-Culasse / Head Cover
Console De Moteur / Engine Brack Et
Paliers De Vilebrequin / Main Be Aring Case
Piston Et Vilebrequin / Piston A Nd Crankshaft
Volant Moteur / Flywheel
Arbre A Cames De Carb. / Fuel Ca Mshaft
Levier D Arret Du Moteur / Engin E Stop Lever
Pompe D Injection / Injection Pu Mp
Regulateur De Vitesses / Governo R
Plaque De Vitesse-Controle / Spe Ed Control Plate
Porte-Injecteur Et Bougie De Pre Chauffage / Nozzle Holder And Glow Plug
Demarreur / Starter
Demarreur(Parties Comp.) / Start Er(Component Parts)
Alternateur / Alternator And Pul Ley
Alternateur(Parties Comp.) / Alt Ernator(Component Parts)
Bride A Eau Et Thermostat / Wate R Flange And Thermostat
Pompe A Eau / Water Pump
Tuyau D Eau / Water Pipe
Radiateur / Radiator
Collecteur D Admission & D Echap Pement / Inlet Manifold Exhaust Manifold
Filtre A Air / Air Cleaner
Silencieux / Muffler
Support Ba Lancement / Swing Bracket
Fleche / B Oom
Couvercle De Cylindre(Fleche) / Cylinder Cover(Boom)
Bras / Arm
Bras / Arm
Bras(Teles Copique) / Arm(Telescopic)
Maillon De Godet / Bucket Link
Maillon De Godet(Telescopique) / Bucket Link(Telescopic)
Godet / Bu Cket
Lame / Bla De
Levier D Accelerateur( S.No.<=55563) / Accel Lever(S.No.<=55563)
Tuyautage De Carburant / Fuel Piping
Filtre A Carburant(Par Ties Comp.) / Fuel Filter(Component Parts)
Etiquette / Label
Auvent / Canopy
Cabine (Glace 1) / Cabin(Window 1)
Cabine (Glace 2) / Cabin(Window 2)
Cabine (Porte) / Cabin(Door)
Cabine (Moteur Essuie-Glace) / Cabin(Wiper Motor)
Cabin( Accessories) / Cabin(Accessories)
Cabine (Chauffage) / Cabin(Heater)
Pieces De Maintenance / Maintenance Parts
Carter De Pompe / Pump Housing
Reservoir D Huile / Oil Tank
Chassis Pivot / Swiv El Frame
Chassis De Capote / Arch Frame
Roulement De Bascule / Swivel Bearing
Support De Siege / S Eat Support
Marche / Step
Couvercle(Gauche) / Cover(Lh)
Couvercle(Droite) / Cover(Rh)
Capot(Gauge) / Bonne T(Lh)
Capot(Droite) / Bonn Et(Rh)
Capot(Arriere) / Bon Net(Back)
Eponge / Sponge(1)
Eponge / Sponge(2)
Eponge / Sponge(2)
Contrepoids / Weight
Contrepoids Telescop Ique / Weight Telescopic
Siege / Seat
Cadre De Piste / Track Frame
Intermediaire / Idler
Galet De Chenille / Tr Ack Roller
Chenille / Crawler
Hydrauliqu E Pompe(Parties Comp.)(S.No.<=55563) / Hydraulic Pu Mp And Component Parts(S.No.<=55553)
Hydrauliqu E Pompe(Parties Comp.)(S.No.>=55564) / Hydraulic Pu Mp And Component Parts(S.No.>=55554)
