Kubota Excavator KX080-3 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Excavator
Model: Kubota KX080-3 Excavator
Number of Pages: 381 Pages
Frequently U Sed Items / Frequently Used Items
Pieces De Ma Intenance / Maintenance Parts
Bloc Moteur / Crank Case
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Kit D'accouplements Rapides [Option] / Gear Case
Couvre-Culasse / Head Cover
Console De Moteur / Engine Bracket
Arbre A Cames Et Arbre De Pignon Intermediaire / C Amshaft And Idle Gear Shaft
Volant Du Moteur / Flywheel
Carter De Pompe / Pump Housing
Levier A Fourche(Regulateur De Vitesses) / Fork Le Ver(Governor)
Vis De Reglage De Vitesse / Governor Adjusting Bol T
Dynamo / Dynamo
Dynamo [Parties Composantes] / Dynamo [Component P Arts]
Lanceur / Starter
Lanceur / Starter
Demarreur [Parties Composantes] / Starter [Compone Nt Parts]
Kit D'accouplements Rapides [Option] / Water Flang E And Thermostat
Filter A Air / Air Cleaner
Silencieux / Muffler
Dispositif D' Arret Du Moteur / Engine Stop System
Pompe A Eau / Water P Ump
Tuyau D'eau / Water P Ipe
Ventilateur / Fan
Ventilateur / Fan
Vase D'expansion / Re Serve Tank
Radiateur / Radiator
Refroidissement / Oil Cooler
Moteur De Ralentisseur En Auto / A Uto Idle Motor
Tuyautage De Carburant / Fuel Pipi Ng
Filtre A Carburant [Parties Compos Antes] / Fuel Filter [Component Parts]
Reservoir Carb. / Fuel Tank
Pompe D'alimentation Provision / F Uel Supply Pump
Batterie / Battery
Batterie / Battery
Relais Et Avertisseur / Re Lay And Horn
Interrupteur,Metre / Switc H And Meter
Lampe [Excepte Fleche Type A Piece Duele] / Light [Except Two-Piece Boom Type ]
Lampe [Fleche Type A Piece Duele] / Light [Two-Piece Boom Type]
Faisceau De Cables [Except E Fleche Type A Piece Duele] / Electrical Wiring [E Xcept Two-Piece Boom Type]
Faisceau De Cables [Fleche Type A Piece Duele] / Electrical Wiring [Two-Piece Boom Type]
Faisceau Electrique / Elec Trical Wiring
Relais / Relay
Pompe De Pistons 1 [Pa Rties Composantes] / Piston Pump 1 [Component Parts ]
Pompe De Pistons 2 [Pa Rties Composantes] / Piston Pump 2 [Component Parts ]
Pompe De Pistons 3 [Pa Rties Composantes] / Piston Pump 3 [Component Parts ]
Moteur De Voyage / Dri Ve Motor
Moteur De Voyage 1 [Pa Rties Composantes] / Drive Motor 1 [Component Parts ]
Moteur De Voyage 2 [Pa Rties Composantes] / Drive Motor 2 [Component Parts ]
Moteur De Voyage 3 [Pa Rties Composantes] / Drive Motor 3 [Component Parts ]
Moteur De Bascule / Sw Ivel Motor
Moteur De Bascule 1 [P Arties Composantes] / Swivel Motor 1 [Component Par Ts]
Moteur De Bascule 2 [P Arties Composantes] / Swivel Motor 2 [Component Par Ts]
Moteur De Bascule 3 [P Arties Composantes] / Swivel Motor 3 [Component Par Ts]
Joint Rotatif / Rotary Joint
Reservoir D'huile(Filt Re) / Oil Tank(Filter)
Reservoir D'huile(Plaq Ue) / Oil Tank(Plate)
Filtre D'huile / Oil F Ilter
Soupape De Controle 1 [Excepte Fleche Type A Piece Duele] / Control Valve 1 [Except Two- Piece Boom Type]
Soupape De Controle 1 [Fleche Type A Piece Duele] / Control Valve 1 [Two-Piece Boom Type ]
Soupape De Controle 2 [Excepte Fleche Type A Piece Duele] / Control Valve 2 [Except Two- Piece Boom Type]
Soupape De Controle 2 [Fleche Type A Piece Duele] / Control Valve 2 [Two-Piece Boom Type ]
Soupape De Controle 3 [Excepte Fleche Type A Piece Duele] / Control Valve 3 [Except Two- Piece Boom Type]
Soupape De Controle 3 [Fleche Type A Piece Duele] / Control Valve 3 [Two-Piece Boom Type ]
Soupape De Controle 4 [Excepte Fleche Type A Piece Duele] / Control Valve 4 [Except Two- Piece Boom Type]
Soupape De Controle 4 [Fleche Type A Piece Duele] / Control Valve 4 [Two-Piece Boom Type ]
Soupape De Controle 5 / Control Valve 5
Soupape De Controle 7 / Control Valve 7
Soupape De Cont. [Parties Comp.] [Exc Epte Fleche Type A Piece Duele] / Control Valve [Co Mponent Parts] [Except Two-Piece Boom Type]
Soupape De Controle [Parties Composan Tes] [Fleche Type A Piece Duele] / Control Valve [C Omponent Parts] [Two-Piece Boom Type]
Section De Tiroir(Fleche A Piece Duel E) [Fleche Type A Piece Duele] / Spool Section(Two- Piece Boom) [Two-Piece Boom Type]
Section De Tiroir(Balancement) / Spoo L Section(Swing)
Section De Tiroir(Fleche) / Spool Sec Tion(B00m)
Section De Tiroir(S/P 1) / Spool Sect Ion(S/P 1)
Section De Tiroir(Godet) / Spool Sect Ion(Bucket)
Section De Tiroir(Bras) / Spool Secti On(Arm)
Section De Tiroir(Retour) / Spool Sec Tion(Return)
Section De Tiroir(Deplacement Indepen Dance) / Spool Section(Travel Independence)
Section De Tiroir(Deplacement Droite) / Spool Section(Travel Rh)
Section De Tiroir(Deplacement Gauche) / Spool Section(Travel Lh)
Section De Tiroir(Confluent) / Spool Section(Confluence)
Section De Tiroir(S/P 2) / Spool Sect Ion(S/P 2)
Section De Tiroir(Lame) / Spool Secti On(Blade)
Section De Tiroir(Pivot) / Spool Sect Ion(Swivel)
Section De Tiroir(Derivation) / Spool Section(Bypass)
Soupape De Decharge 1 / Unload Valve 1
Soupape De Decharge 1 [Parties Compos Antes] / Unload Valve 1 [Component Parts]
Soupape De Decharge 2 / Unload Valve 2
Soupape De Dechaege 2 [Parties Compos Antes] / Unload Valve 2 [Component Parts]
Soupape De 3chemin / 3way Valve
Soupape De Pivot Navette / Swivel Shu Ttle Valve
Soupape De Pivot Navette [Parties Com Posantes] / Swivel Shuttle Valve [Component Parts]
Soupape De Amortisseur [Excepte Flech E Type A Piece Duele] / Shock Absorber Valve [Excep T Two-Piece Boom Type]
Soupape De Amortisseur [Fleche Type A Piece Duele] / Shock Absorber Valve [Two-Piece Boo M Type]
Soupape De Amortisseur [Parties Compo Santes] / Shock Absorber Valve [Component Parts]
Soupape De Pilote(Lame) / Pilot Valve (Blade)
Soupape De Pilote(Lame) [Parties Comp Osantes] / Pilot Valve(Blade) [Component Parts]
Soupape De Pilote(Balancement) / Pilo T Valve(Swing)
Soupape De Pilote(Balancement) [Parti Es Composantes] / Pilot Valve(Swing) [Component Par Ts]
Soupape De Pilote(Deplacement) / Pilo T Valve(Travel)
Soupape De Pilote(Deplacement) [Parti Es Composantes] / Pilot Valve(Travel) [Component Pa Rts]
Soupape De Pilote(Fleche) [Fleche Typ E A Piece Duele] / Pilot Valve(Boom) [Two-Piece Boo M Type]
Soupape De Pilote(Fleche) [Parties Co Mp.] [Fleche Type A Piece Duele] / Pilot Valve(Boom ) [Component Parts] [Two-Piece Boom Type]
Soupape De Aimantee / Magnetic Valve
Soupape De Aimantee [Parties Composan Tes] / Magnetic Valve [Component Parts]
Soupape De Tenir 1 [Excepte Fleche Ty Pe A Piece Duele] / Holding Valve 1 [Except Two-Pie Ce Boom Type]
Soupape De Tenir 1 [Fleche Type A Pie Ce Duele] / Holding Valve 1 [Two-Piece Boom Type]
Soupape De Tenir 1 [Parties Composant Es] / Holding Valve 1 [Component Parts]
Soupape De Tenir 2 [Fleche Type A Pie Ce Duele] / Holding Valve 2 [Two-Piece Boom Type]
Soupape De Tenir 2 [Parties Composant Es] [Fleche Type A Piece Duele] / Holding Valve 2 [ Component Parts] [Two-Piece Boom Type]
Bloc De Pilote Orifice / Pilot Port B Lock
Adaptateur De Relais / Relay Adapter
Bloc De Assemblee / Assembly Block
Levier De Commande(Levier Gauch E) / Control Lever(Lever Lh)
Soupape De Pilote(Gauche) [Part Ies Composantes] / Pilot Valve(Lh) [Component Parts ]
Levier De Commande(Levier Droit E) / Control Lever(Lever Rh)
Soupape De Pilote(Droite) [Part Ies Composantes] / Pilot Valve(Rh) [Component Parts ]
Levier De Commande(Deplacement) / Control Lever(Travel)
Pedale De Fleche Balancement / Boom Swing Pedal
Pedale De Controle Soupape [Fle Che Type A Piece Duele] / Boom Control Pedal [Two-P Iece Boom Type]
Levier De Commende(Levier De Ve Rrouillage) / Control Lever(Safety Lock Lever)
Levier De Commande(Lame) / Cont Rol Lever(Blade)
Tube(Succion) / Oil Piping(Suctio N)
Tube(Delivrance 1) / Oil Piping(D Elivery 1)
Tube(Delivrance 2) / Oil Piping(D Elivery 2)
Tube(Retour) / Oil Piping(Return)
Tube(Refroidisseur) / Oil Piping( Oil Cooler)
Tube(Commande Droite) / Oil Pipin G(Control Rh)
Tube(Pilote) [Excepte Fleche Type A Piece Duele] / Oil Piping(Pilot) [Except Two-Pie Ce Boom Type]
Tube(Pilote) [Fleche Type A Piece Duele] / Oil Piping(Pilot) [Two-Piece Boom Type]
Tube(Deplacement Gauche) / Oil Pi Ping(Travel Lh)
Tube(Deplacement Droite) / Oil Pi Ping(Travel Rh)
Tube(Pivot) / Oil Piping(Swivel)
Tube(Pilote Orifice) / Oil Piping (Pilot Port)
Tube(Balancement) / Oil Piping(Sw Ing)
Tube(Fleche 1) / Oil Piping(Boom 1)
Tube(Fleche 2) / Oil Piping(Boom 2)
Tube(Fleche 3) [Fleche Type A Pie Ce Duele] / Oil Piping(Boom 3) [Two-Piece Boom Type ]
Tube(Fleche 4) [Fleche Type A Pie Ce Duele] / Oil Piping(Boom 4) [Two-Piece Boom Type ]
Tube(Bras 1) / Oil Piping(Arm 1)
Tube(Bras 2) [Excepte Fleche Type A Piece Duele] / Oil Piping(Arm 2) [Except Two-Pie Ce Boom Type]
Tube(Bras 2) [Fleche Type A Piece Duele] / Oil Piping(Arm 2) [Two-Piece Boom Type]
Tube(Godet 1) / Oil Piping(Bucket 1)
Tube(Godet 2) [Excepte Fleche Typ E A Piece Duele] / Oil Piping(Bucket 2) [Except Two -Piece Boom Type]
Tube(Godet 2) [Fleche Type A Piec E Duele] / Oil Piping(Bucket 2) [Two-Piece Boom Typ E]
Tube(Godet 3) [Fleche Type A Piec E Duele] / Oil Piping(Bucket 3) [Two-Piece Boom Typ E]
Tube(Lame 1) / Oil Piping(Blade 1 )
Tube(Lame 2) / Oil Piping(Blade 2 )
Tube(Attache) / Oil Piping(Clamp)
Tube(S/P 1) / Oil Piping(S/P 1)
Tubu(S/P 2) [Excepte Fleche Type A Piece Duele] / Oil Piping(S/P 2) [Except Two-Piec E Boom Type]
Tubu(S/P 2) [Fleche Type A Piece Duele] / Oil Piping(S/P 2) [Two-Piece Boom Type]
Tube(S/P 3) [Excepte Fleche Type A Piece Duele] / Oil Piping(S/P 3) [Except Two-Piec E Boom Type]
Tube(S/P 3) [Fleche Type A Piece Duele] / Oil Piping(S/P 3) [Two-Piece Boom Type]
Tube(S/P 4) / Oil Piping(S/P 4)
Kit Pince(Avec Coupleur) [Option] / Clamp Kit(With Quick-Coupler) [Option]
Kit Pince(Sans Coupleur) [Option] / Clamp Kit(With Out Quick-Coupler) [Option]
Coupleur(Kit Pince P.) [Option] / Quick-Coupler(Cl Amp Kit P.) [Option]
Kit S/P 1 [Option] / Kit S/P 1 [Option]
Kit Gap [Pourle Kuk] [Option] / Kit Gap [For Kuk] [Option]
Kit Gap [Option] / Kit Gap [Option]
Kit Kbd [Option] / Kit Kbd [Option]
Clapet D'ar.Aut./Bras [Option] / Pipe-Break Valve/ Arm [Option]
Clapet D'ar.Aut./Lame [Option] / Pipe-Break Valve/ Dozer [Option]
Godet [Option] / Bucket [Option]
Coupleur [Option] / Quick-Coupler [Option]
Kit Black Box [Option] / Kit Black Box [Option]
Jeu De Deplacement Alarme [Option] / Travel Alarm Kit [Option]
Jeu De Lame [Option] / Blade Kit [Option]
Chenille(Fer Chenille) [Option] / Crawler(Iron Cra Wler) [Option]
Kit Giogrip [Option] / Kit Giogrip [Option]
Operateur Garde [Option] / Operator Guard Kit [Opt Ion]
Fleche Cylindre Et Parties Composantes / Boom Cylinder And Component Parts
Fleche Cylindre Et Parties Comp.(Gauche) [Flec He Type A Piece Duele] / Boom Cylinder And Componen T Parts(Lh) [Two-Piece Boom Type]
Fleche Cylindre Et Parties Comp.(Droite) [Flec He Type A Piece Duele] / Boom Cylinder And Componen T Parts(Rh) [Two-Piece Boom Type]
Bras Cylindre Et Parties Composantes / Arm Cyl Inder And Component Parts
Godet Cyliendre Et Parties Composantes / Bucke T Cylinder And Component Parts
Lame Cylindre Et Parties Composantes / Blade C Ylinder And Component Parts
Balancement Cylindre Et Parties Composantes / Swing Cylinder And Component Parts
Support Balancement / Swing Bracket
Fleche [Excepte Fleche Type A Piece Duele] / Boom [Except Two-Piece Boom Type]
Fleche A Piece Duele 1 [Flec He Type A Piece Duele] / Two-Piece Boom 1 [Two-Piec E Boom Type]
Fleche A Piece Duele 2 [Flec He Type A Piece Duele] / Two-Piece Boom 2 [Two-Piec E Boom Type]
Couvercle De Cylindre(Fleche ) / Cylinder Cover(Boom)
Bras / Arm
Bras / Arm
Maillon De Godet / Bucket Li Nk
Lame / Blade
Lame / Blade
Cadre De Piste / Track Frame
Intermediaire / Idler
Galet De Chenille / Track Roller
Chenille(Caoutchouc Chenille) / Cr Awler(Rubber Crawler)
Chassis Pivot / Swivel Frame
Chassis De Capote / Arch Frame
Roulement De Bascule / Swivel Bearing
Support De Seige / Seat Support
Marche [Excepte Fleche Type A Piece D Uele] / Step [Except Two-Piece Boom Type]
Marche [Fleche Type A Piece Duele] / Step [Two-Piece Boom Type]
Couvercle(Gauche) / Cover(Lh)
Couvercle(Droite) / Cover(Rh)
Couvercle(Avant) / Cover(Front)
Couvercle(Centre) / Cover(Center)
Couvercle(Chassis De Capote) / Cover(Arch Flam E)
Capot(Droite) / Bonnet(Rh)
Capot (Arriere) / Bonnet(Rear)
Retroviseur / Rearview Mirror
Eponge 1 / Sponge 1
Eponge 2 / Sponge 2
Eponge 2 / Sponge 2
Eponge 3 / Sponge 3
Eponge 3 / Sponge 3
Eponge 3 / Sponge 3
Coussin / Cushion
Contrepoids 1(Standard) / Weight 1(Standard)
Contrepoids 1(Lourd) / Weight 1(Heavy)
Contrepoids 2 [Fleche Type A Piece Duele] / We Ight 2 [Two-Piece Boom Type]
Siege / Seat
Siege [Parties Composantes] / Seat [Component Parts]
Cabin(Corps) / Cabin(Body)
Cabin(Porte) / Cabin(Door)
Cabin(Verrouillage De Porte) / Cabin(Door Lock)
Cabin(Glace) / Cabin(Window)
Cabin(Glace Avant Superieur) / Cabin(Window Front U Pper)
Cabin(Glace Avant Inferieur) / Cabin(Window Front L Ower)
Cabin(Glace Avant Support) / Cabin(Window Front Roc K)
Cabin(Eponge) / Cabin(Sponge)
Cabin(Equilibrage) / Cabin(Trim)
Cabin(Panneau) / Cabin(Panel)
Cabin(Moteur,Essuie-Glace) / Cabin(Wiper Motor)
Cabin(Faisceau De Cables) / Cabin(Electrical Wiring )
Cabin(Chauffage) / Cabin(Heater)
Cabin(Degivreur) / Cabin(Defroster)
Cabin(Air Conditionneur 1) / Cabin(Air Conditioner 1)
Cabin(Air Conditionneur 2) / Cabin(Air Conditioner 2)
Cabin(Air Conditionneur 3) / Cabin(Air Conditioner 3)
Cabin(Air Conditionneur 4) / Cabin(Air Conditioner 4)
Etiquette [Excepte Fleche Type A Piece Duele] / Label [Except Two-Piece Boom Type]
Etiquette [Fleche Type A Piece Duele] / Label [Two-Piece Boom Type]
Accessoires / Acces Sories
Dynamo / Dynamo
Lanceur / Starter
Lanceur / Starter
Ventilateur / Fan
Ventilateur / Fan
Batterie / Battery
Batterie / Battery
Relais / Relay
Bras / Arm
Bras / Arm
Lame / Blade
Lame / Blade
Eponge 1 / Sponge 1
Eponge 2 / Sponge 2
Eponge 2 / Sponge 2
Eponge 3 / Sponge 3
Eponge 3 / Sponge 3
Eponge 3 / Sponge 3
Coussin / Cushion
Siege / Seat
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
