Kubota Excavator KX080-3 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX080-3 Excavator
Number of Pages: 625 Pages
Frequently Used Items
Maintenance Parts
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Varilla De Nivbl Y Guia / Dipstick And Guide
Volante / Flywheel
Bomba Carcasa / Pump Housing
Bifurcacion Palanca(Regulador) / Fork Lever(Governor)
Regulador Ajuste Tornillo / Governor Adjusting Bolt
Dinamo / Dynamo
Dinamo[Componente Piezas] / Dynamo [Component Parts]
Motor De Arranque / Starter
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Motor Parada Sistema / Engine Stop System
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Autimatico Ocioso Motor / Auto Idle Motor
Combustible Tubos / Fuel Piping
Separador[Componente Piezas] / Separator [Component Parts]
Combustible Suministro Bomba / Fuel Supply Pump
Rele Y Claxon / Relay And Horn
Conmutador Y Metro / Switch And Meter
Luz [Excepto Tipo Doble Aguilon] / Light [Except Two-Piece Boom Type]
Luz [Tipo Doble Aguilon] / Light [Two-Piece Boom Type]
Electrico Cablead [Excepto Tipo Doble Aguilon] / Electrical Wiring [Except Two-Piece Boom Type]
Electrico Cablead [Tipo Doble Aguilon] / Electrical Wiring [Two-Piece Boom Type]
Rele / Relay
Piston Bomba 1 [Componente Piezas] / Piston Pump 1 [Component Parts]
Piston Bomba 2 [Componente Piezas] / Piston Pump 2 [Component Parts]
Piston Bomba 3 [Componente Piezas] / Piston Pump 3 [Component Parts]
Accionar Motor / Drive Motor
Accionar Motor 1 [Componente Piezas] / Drive Motor 1 [Component Parts]
Accionar Motor 2 [Componente Piezas] / Drive Motor 2 [Component Parts]
Accionar Motor 3 [Componente Piezas] / Drive Motor 3 [Component Parts]
Girar Motor / Swivel Motor
Girar Motor 1 [Componente Piezas] / Swivel Motor 1 [Component Parts]
Girar Motor 2 [Componente Piezas] / Swivel Motor 2 [Component Parts]
Girar Motor 3 [Componente Piezas] / Swivel Motor 3 [Component Parts]
Rotativo Junta / Rotary Joint
Aceite Deposito(Deposito) / Oil Tank(Tank)
Aceite Deposito(Filtro) / Oil Tank(Filter)
Aceite Deposito(Placa) / Oil Tank(Plate)
Aceite Filtro / Oil Filter
Control Valvula 1 [Excepto Tipo Doble Aguilon] / Control Valve 1 [Except Two-Piece Boom Type]
Control Valvula 1 [Tipo Doble Aguilon] / Control Valve 1 [Two-Piece Boom Type]
Control Valvula 2 [Excepto Tipo Doble Aguilon] / Control Valve 2 [Except Two-Piece Boom Type]
Control Valvula 2 [Tipo Doble Aguilon] / Control Valve 2 [Two-Piece Boom Type]
Control Valvula 3 [Excepto Tipo Doble Aguilon] / Control Valve 3 [Except Two-Piece Boom Type]
Control Valvula 3 [Tipo Doble Aguilon] / Control Valve 3 [Two-Piece Boom Type]
Control Valvula 4 [Excepto Tipo Doble Aguilon] / Control Valve 4 [Except Two-Piece Boom Type]
Control Valvula 4 [Tipo Doble Aguilon] / Control Valve 4 [Two-Piece Boom Type]
Control Valvula 5 / Control Valve 5
Control Valvula 6 / Control Valve 6
Control Valvula 7 / Control Valve 7
Control Valvula [Componente Piezas] [Tipo Doble Aguilon] / Control Valve [Component Parts] [Except Two-Piece Boom Type]
Control Valvula [Componente Piezas] [Excepto Tipo Doble Aguilon] / Control Valve [Component Parts] [Two-Piece Boom Type]
Corredera Seccion(Doble Aguilon) [Tipo Doble Aguilon] / Spool Section(Two-Piece Boom) [Two-Piece Boom Type]
Corredera Seccion(Oscilacion) / Spool Section(Swing)
Corredera Seccion(Aguilon) / Spool Section(B00m)
Corredera Seccion(Servicio Piezas 1) / Spool Section(S/P 1)
Corredera Seccion(Cubo) / Spool Section(Bucket)
Corredera Seccion(Brazo) / Spool Section(Arm)
Corredera Seccion(Devolver) / Spool Section(Return)
Corredera Seccion(Recorrido Independencia) / Spool Section(Travel Independence)
Corredera Seccion(Recorrido Derecho) / Spool Section(Travel Rh)
Corredera Seccion(Recorrido Izquierdo) / Spool Section(Travel Lh)
Corredera Seccion(Confluencia) / Spool Section(Confluence)
Corredera Seccion(Servicio Piezas 2) / Spool Section(S/P 2)
Corredera Seccion(Lamina) / Spool Section(Blade)
Corredera Seccion(Girar) / Spool Section(Swivel)
Corredera Seccion(Desviacion) / Spool Section(Bypass)
Descargador Valvula 1 / Unload Valve 1
Descargador Valvula 1 [Componente Piezas] / Unload Valve 1 [Component Parts]
Descargador Valvula 2 / Unload Valve 2
Descargador Valvula 2 [Componente Piezas] / Unload Valve 2 [Component Parts]
3manera Valvula / 3way Valve
Girar Lanzadera Valvula / Swivel Shuttle Valve
Girar Lanzadera Valvula [Componente Piezas] / Swivel Shuttle Valve [Component Parts]
Golpe Absorbente Valvula [Excepto Tipo Doble Aguilon] / Shock Absorber Valve [Except Two-Piece Boom Type]
Golpe Absorbente Valvula [Tipo Doble Aguilon] / Shock Absorber Valve [Two-Piece Boom Type]
Golpe Absorbente Valvula [Componente Piezas] / Shock Absorber Valve [Component Parts]
Piloto Valvula(Lamina) / Pilot Valve(Blade)
Piloto Valvula(Lamina) [Componente Piezas] / Pilot Valve(Blade) [Component Parts]
Piloto Valvula(Oscilacion) / Pilot Valve(Swing)
Piloto Valvula(Oscilacion) [Componente Piezas] / Pilot Valve(Swing) [Component Parts]
Piloto Valvula(Recorrido) / Pilot Valve(Travel)
Piloto Valvula(Recorrido) [Componente Piezas] / Pilot Valve(Travel) [Component Parts]
Piloto Valvula(Aguilon) [Tipo Doble Aguilon] / Pilot Valve(Boom) [Two-Piece Boom Type]
Piloto Valvula(Aguilon) [Componente Piezas] [Tipo Doble Aguilon] / Pilot Valve(Boom) [Component Parts] [Two-Piece Boom Type]
Magnetico Valvula / Magnetic Valve
Magnetico Valvula [Componente Piezas] / Magnetic Valve [Component Parts]
Sostenendo Valvula 1 [Excepto Tipo Doble Aguilon] / Holding Valve 1 [Except Two-Piece Boom Type]
Sostenendo Valvula 1 [Tipo Doble Aguilon] / Holding Valve 1 [Two-Piece Boom Type]
Sostenendo Valvula 1 [Componente Piezas] / Holding Valve 1 [Component Parts]
Sostenendo Valvula 2 [Tipo Doble Aguilon] / Holding Valve 2 [Two-Piece Boom Type]
Sostenendo Valvula 2 [Componente Piezas] [Tipo Doble Aguilon] / Holding Valve 2 [Component Parts] [Two-Piece Boom Type]
Piloto Puerto Bloque / Pilot Port Block
Rele Racor / Relay Adapter
Conjunt Bloque / Assembly Block
Control Palanca(Palanca Izquierdo) / Control Lever(Lever Lh)
Ploto Valvula(Iz) [Componente Piezas] / Pilot Valve(Lh) [Component Parts]
Control Palanca(Palanca Derecho) / Control Lever(Lever Rh)
Ploto Valvula(Dr) [Componente Piezas] / Pilot Valve(Rh) [Component Parts]
Control Palanca(Recorrido) / Control Lever(Travel)
Aguilon Oscilacion Pedal / Boom Swing Pedal
Aguilon Control Pedal [Tipo Doble Aguilon] / Boom Control Pedal [Two-Piece Boom Type]
Control Palanca(Seguridad Cerradura Palanca) / Control Lever(Safety Lock Lever)
Control Palanca(Lamina) / Control Lever(Blade)
Aceite Tubos(Asupiracion) / Oil Piping(Suction)
Aceite Tubos(Entrega 1) / Oil Piping(Delivery 1)
Aceite Tubos(Entrega 2) / Oil Piping(Delivery 2)
Aceite Tubos(Devolver) / Oil Piping(Return)
Aceite Tubos(Aceite Refrigerador) / Oil Piping(Oil Cooler)
Aceite Tubos(Control Izquierdo) / Oil Piping(Control Lh)
Aceite Tubos(Control Derecho) / Oil Piping(Control Rh)
Aceite Tubos(Piloto) [Excepto Tipo Doble Aguilon] / Oil Piping(Pilot) [Except Two-Piece Boom Type]
Aceite Tubos(Piloto) [Tipo Doble Aguilon] / Oil Piping(Pilot) [Two-Piece Boom Type]
Aceite Tubos(Recorrido Izquierdo) / Oil Piping(Travel Lh)
Aceite Tubos(Recorrido Derecho) / Oil Piping(Travel Rh)
Aceite Tubos(Girar) / Oil Piping(Swivel)
Aceite Tubos(Piloto Puerto) / Oil Piping(Pilot Port)
Aceite Tubos(Oscilacion) / Oil Piping(Swing)
Aceite Tubos(Aguilon 1) / Oil Piping(Boom 1)
Aceite Tubos(Aguilon 2) / Oil Piping(Boom 2)
Aceite Tubos(Aguilon 3) [Tipo Doble Aguilon] / Oil Piping(Boom 3) [Two-Piece Boom Type]
Aceite Tubos(Aguilon 4) [Tipo Doble Aguilon] / Oil Piping(Boom 4) [Two-Piece Boom Type]
Aceite Tubos(Brazo 1) / Oil Piping(Arm 1)
Aceite Tubos(Brazo 2) [Excepto Tipo Doble Aguilon] / Oil Piping(Arm 2) [Except Two-Piece Boom Type]
Aceite Tubos(Brazo 2) [Tipo Doble Aguilon] / Oil Piping(Arm 2) [Two-Piece Boom Type]
Aceite Tubos(Cubo 1) / Oil Piping(Bucket 1)
Aceite Tubos(Cubo 2) [Excepto Tipo Doble Aguilon] / Oil Piping(Bucket 2) [Except Two-Piece Boom Type]
Aceite Tubos(Cubo 2) [Tipo Doble Aguilon] / Oil Piping(Bucket 2) [Two-Piece Boom Type]
Aceite Tubos(Cubo 3) [Tipo Doble Aguilon] / Oil Piping(Bucket 3) [Two-Piece Boom Type]
Aceite Tubos(Lamina 1) / Oil Piping(Blade 1)
Aceite Tubos(Lamina 2) / Oil Piping(Blade 2)
Aceite Tubos(Abrazadera) / Oil Piping(Clamp)
Aceite Tubos(Servicio Piezas 1) / Oil Piping(S/P 1)
Aceite Tubos(Servicio Piezas 2) [Excepto Tipo Doble Aguilon] / Oil Piping(S/P 2) [Except Two-Piece Boom Type]
Aceite Tubos(Servicio Piezas 2) [Tipo Doble Aguilon] / Oil Piping(S/P 2) [Two-Piece Boom Type]
Aceite Tubos(Servicio Piezas 3) [Excepto Tipo Doble Aguilon] / Oil Piping(S/P 3) [Except Two-Piece Boom Type]
Aceite Tubos(Servicio Piezas 3) [Tipo Doble Aguilon] / Oil Piping(S/P 3) [Two-Piece Boom Type]
Aceite Tubos(Servicio Piezas 4) / Oil Piping(S/P 4)
Kit Pinza (Con Raccordo) [Opcion] / Clamp Kit(With Quick-Coupler) [Option]
Kit Pinza(Senza Raccordo) [Opcion] / Clamp Kit(Without Quick-Coupler) [Option]
Raccordo(Kit Pinza P.) [Opcion] / Quick-Coupler(Clamp Kit P.) [Option]
Kit S/P 1 [Opcion] / Kit S/P 1 [Option]
Kit Gap [Opcion] / Kit Gap [For Kuk] [Option]
Kit Gap [Opcion] / Kit Gap [Option]
Kit Kbd [Opcion] / Kit Kbd [Option]
Valvole..D''Ar.Aut.(Avambrac) [Opcion] / Pipe-Break Valve/Arm [Option]
Valv.D'ar.Aut.(Lama) / Pipe-Break Valve/Dozer [Option]
Cazo (No Acoplador) [Opcion] / Bucket [Option]
Benna, Raccordo [Opcion] / Bucket,Quick-Coupler [Option]
Acoplador [Opcion] / Quick-Coupler [Option]
Kit Black Box [Opcion] / Kit Black Box [Option]
Recorrido Alarma Kit [Opcion] / Travel Alarm Kit [Option]
Lamina Kit [Opcion] / Blade Kit [Option]
Tractor Sobure Orugas(Hierro Tractor Sobure Orugas) [Opcion] / Crawler(Iron Crawler) [Option]
Juego Giogrip [Opcion] / Kit Giogrip [Option]
Operador Protector [Opcion] / Operator Guard Kit [Option]
Aguilon Cilindro Y Componente Piezas / Boom Cylinder And Component Parts
Aguilon Cilindro Y Componente Piezas(Iz) [Tipo Doble Aguilon] / Boom Cylinder And Component Parts(Lh) [Two-Piece Boom Type]
Aguilon Cilindro Y Componente Piezas(Dr) [Tipo Doble Aguilon] / Boom Cylinder And Component Parts(Rh) [Two-Piece Boom Type]
Brazo Cilindro Y Componente Piezas / Arm Cylinder And Component Parts
Cubo Cilindro Y Componente Piezas / Bucket Cylinder And Component Parts
Lamina Cilindro Y Componente Piezas / Blade Cylinder And Component Parts
Oscilacion Cilindro Y Componente Piezas / Swing Cylinder And Component Parts
Oscilacion Soporte / Swing Bracket
Aguilon [Excepto Tipo Doble Aguilon] / Boom [Except Two-Piece Boom Type]
Doble Aguilon 1 [Tipo Doble Aguilon] / Two-Piece Boom 1 [Two-Piece Boom Type]
Doble Aguilon 2 [Tipo Doble Aguilon] / Two-Piece Boom 2 [Two-Piece Boom Type]
Cilindro Cubierta(Aguilon) / Cylinder Cover(Boom)
Brazo / Arm
Cubo Vinculo / Bucket Link
Lamina / Blade
Tren De Orugas Bastidor / Track Frame
Rueda Loca / Idler
Tren De Orugas Rodillo / Track Roller
Tractor Sobure Orugas(Caucho Tractor Sobure Orugas) / Crawler(Rubber Crawler)
Girar Bastidor / Swivel Frame
Arco Bastidor / Arch Frame
Girar Rodamiento / Swivel Bearing
Peldano [Excepto Tipo Doble Aguilon] / Step [Except Two-Piece Boom Type]
Peldano [Tipo Doble Aguilon] / Step [Two-Piece Boom Type]
Cubierta(Izquierdo) / Cover(Lh)
Cubierta(Derecho) / Cover(Rh)
Cubierta(Deposito) / Cover(Tank)
Cubierta(Adelante) / Cover(Front)
Cubierta(Centro) / Cover(Center)
Cubierta(Arco Bastidor) / Cover(Arch Flame)
Capo(Derecho) / Bonnet(Rh)
Capo (Trasero) / Bonnet(Rear)
Esponja 1 / Sponge 1
Esponja 2 / Sponge 2
Esponja 3 / Sponge 3
Banqueta / Cushion
Peso 1(Estandar) / Weight 1(Standard)
Peso 1(Pesado) / Weight 1(Heavy)
Peso 2 [Tipo Doble Aguilon] / Weight 2 [Two-Piece Boom Type]
Hoja / Seat
Asiento [Componente Piezas] / Seat [Component Parts]
Cabina(Carroceria) / Cabin(Body)
Cabina(Puerta) / Cabin(Door)
Cabina(Puerta Cerradura) / Cabin(Door Lock)
Cabina(Ventana) / Cabin(Window)
Cabina(Frente De La Ventana Superior) / Cabin(Window Front Upper)
Cabina(Frente De La Ventana Bajar) / Cabin(Window Front Lower)
Cabina(Frente De La Ventana Cerradura) / Cabin(Window Front Rock)
Cabina(Esponja) / Cabin(Sponge)
Cabina(Revestimiento) / Cabin(Trim)
Cabina(Panel) / Cabin(Panel)
Cabina(Limpiaparabrisas Motor) / Cabin(Wiper Motor)
Cabina(Electrico Cableado) / Cabin(Electrical Wiring)
Cabina(Calentador) / Cabin(Heater)
Cabina(Desescarchador) / Cabin(Defroster)
Cabina(Aire Acondicionado 1) / Cabin(Air Conditioner 1)
Cabina(Aire Acondicionado 2) / Cabin(Air Conditioner 2)
Cabina(Aire Acondicionado 3) / Cabin(Air Conditioner 3)
Cabina(Aire Acondicionado 4) / Cabin(Air Conditioner 4)
Etiqueta [Excepto Tipo Doble Aguilon] / Label [Except Two-Piece Boom Type]
Etiqueta [Tipo Doble Aguilon] / Label [Two-Piece Boom Type]
Accesorios / Accessories
