Kubota Excavator KX080-3 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX080-3 Excavator
Region: Australia
Number of Pages: 432 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Dipstick And Guide
Engine _ Engine Bracket
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Pump Housing
Engine _ Fork Lever(Governor)
Engine _ Governor Adjusting Bolt
Engine _ Dynamo
Engine _ Dynamo [Component Parts]
Engine _ Starter
Engine _ Starter [Component Parts]
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Cooling Water System _ Water Pump
Cooling Water System _ Water Pipe
Cooling Water System _ Fan
Cooling Water System _ Reserve Tank
Cooling Water System _ Radiator
Cooling Water System _ Oil Cooler
Fuel System _ Engine Stop System
Fuel System _ Auto Idle Motor
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter [Component Parts]
Fuel System _ Separator [Component Parts]
Fuel System _ Fuel Tank
Fuel System _ Fuel Supply Pump
Electrical System _ Battery
Electrical System _ Travel Alarm
Electrical System _ Relay And Horn
Electrical System _ Switch And Meter
Electrical System _ Light
Electrical System _ Electrical Wiring 1
Electrical System _ Electrical Wiring 2
Electrical System _ Electrical Wiring 3
Pump_Motor System _ Pump Housing
Pump_Motor System _ Piston Pump 1 [Component Parts]
Pump_Motor System _ Piston Pump 2 [Component Parts]
Pump_Motor System _ Piston Pump 3 [Component Parts]
Pump_Motor System _ Drive Motor
Pump_Motor System _ Drive Motor 1 [Component Parts]
Pump_Motor System _ Drive Motor 2 [Component Parts]
Pump_Motor System _ Drive Motor 3 [Component Parts]
Pump_Motor System _ Swivel Motor
Pump_Motor System _ Swivel Motor 1 [Component Parts]
Pump_Motor System _ Swivel Motor 2 [Component Parts]
Pump_Motor System _ Swivel Motor 3 [Component Parts]
Pump_Motor System _ Rotary Joint
Pump_Motor System _ Oil Tank(Tank)
Pump_Motor System _ Oil Tank(Filter)
Pump_Motor System _ Oil Tank(Plate)
Pump_Motor System _ Oil Filter
Control Valve _ Control Valve 1
Control Valve _ Control Valve 2
Control Valve _ Control Valve 3
Control Valve _ Control Valve 4
Control Valve _ Control Valve 5
Control Valve _ Control Valve 6
Control Valve _ Control Valve 7
Control Valve _ Control Valve [Component Parts]
Control Valve _ Spool Section(Swing)
Control Valve _ Spool Section(B00m)
Control Valve _ Spool Section(S_P 1)
Control Valve _ Spool Section(Bucket)
Control Valve _ Spool Section(Arm)
Control Valve _ Spool Section(Return)
Control Valve _ Spool Section(Travel Independence)
Control Valve _ Spool Section(Travel Rh)
Control Valve _ Spool Section(Travel Lh)
Control Valve _ Spool Section(Confluence)
Control Valve _ Spool Section(S_P 2)
Control Valve _ Spool Section(Blade)
Control Valve _ Spool Section(Swivel)
Control Valve _ Spool Section(Bypass)
Control Valve _ Unload Valve 1
Control Valve _ Unload Valve 1 [Component Parts]
Control Valve _ Unload Valve 2
Control Valve _ Unload Valve 2 [Component Parts]
Control Valve _ 3way Valve
Control Valve _ Swivel Shuttle Valve
Control Valve _ Swivel Shuttle Valve [Component Parts]
Control Valve _ Shock Absorber Valve
Control Valve _ Shock Absorber Valve [Component Parts]
Control Valve _ Pilot Valve(Blade)
Control Valve _ Pilot Valve(Blade) [Component Parts]
Control Valve _ Pilot Valve(Swing)
Control Valve _ Pilot Valve(Swing) [Component Parts]
Control Valve _ Pilot Valve(Travel)
Control Valve _ Pilot Valve(Travel) [Component Parts]
Control Valve _ Magnetic Valve
Control Valve _ Magnetic Valve [Component Parts]
Control Valve _ Holding Valve
Control Valve _ Holding Valve [Component Parts]
Control Valve _ Pilot Port Block
Control Valve _ Assembly Block
Control Valve _ Multi Valve
Control Lever _ Control Lever(Lever Lh)
Control Lever _ Pilot Valve(Lh) [Component Parts]
Control Lever _ Control Lever(Lever Rh)
Control Lever _ Pilot Valve(Rh) [Component Parts]
Control Lever _ Control Lever(Travel)
Control Lever _ Boom Swing Pedal
Control Lever _ Control Lever(Safety Lock Lever)
Control Lever _ Tpss Lever
Control Lever _ Control Lever(Blade)
Oil Piping _ Oil Piping(Suction)
Oil Piping _ Oil Piping(Delivery 1)
Oil Piping _ Oil Piping(Delivery 2)
Oil Piping _ Oil Piping(Return)
Oil Piping _ Oil Piping(Oil Cooler)
Oil Piping _ Oil Piping(Control Lh)
Oil Piping _ Oil Piping(Control Rh)
Oil Piping _ Oil Piping(Pilot)
Oil Piping _ Oil Piping(Travel Lh)
Oil Piping _ Oil Piping(Travel Rh)
Oil Piping _ Oil Piping(Swivel)
Oil Piping _ Oil Piping(Pilot Port)
Oil Piping _ Oil Piping(Swing)
Oil Piping _ Oil Piping(Boom 1)
Oil Piping _ Oil Piping(Boom 2)
Oil Piping _ Oil Piping(Arm 1)
Oil Piping _ Oil Piping(Arm 2)
Oil Piping _ Oil Piping(Bucket 1)
Oil Piping _ Oil Piping(Bucket 2)
Oil Piping _ Oil Piping(Blade 1)
Oil Piping _ Oil Piping(Blade 2)
Oil Piping _ Oil Piping(Clamp)
Oil Piping _ Oil Piping(S_P 1)
Oil Piping _ Oil Piping(S_P 2)
Oil Piping _ Oil Piping(S_P 3)
Oil Piping _ Oil Piping(S_P 4)
Cylinder _ Boom Cylinder And Component Parts
Cylinder _ Arm Cylinder And Component Parts
Cylinder _ Bucket Cylinder And Component Parts
Cylinder _ Blade Cylinder And Component Parts
Cylinder _ Swing Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover(Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler(Rubber Crawler)
Swivel Frame _ Swivel Frame
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
Hood_Bonnet _ Cover(Lh)
Hood_Bonnet _ Cover(Rh)
Hood_Bonnet _ Cover(Tank)
Hood_Bonnet _ Cover(Front)
Hood_Bonnet _ Cover(Center)
Hood_Bonnet _ Cover(Arch Flame)
Hood_Bonnet _ Bonnet(Rh)
Hood_Bonnet _ Bonnet(Rear)
Hood_Bonnet _ Rearview Mirror
Hood_Bonnet _ Sponge 1
Hood_Bonnet _ Sponge 2
Hood_Bonnet _ Sponge 3
Hood_Bonnet _ Cushion
Hood_Bonnet _ Weight
Hood_Bonnet _ Seat
Hood_Bonnet _ Seat [Component Parts]
Cabin _ Cabin(Body)
Cabin _ Cabin(Door)
Cabin _ Cabin(Door Lock)
Cabin _ Cabin(Window)
Cabin _ Cabin(Window Front Upper)
Cabin _ Cabin(Window Front Lower)
Cabin _ Cabin(Window Front Rock)
Cabin _ Cabin(Sponge)
Cabin _ Cabin(Trim)
Cabin _ Cabin(Panel)
Cabin _ Cabin(Wiper Motor)
Cabin _ Cabin(Electrical Wiring)
Cabin _ Cabin(Heater)
Cabin _ Cabin(Defroster)
Cabin _ Cabin(Air Conditioner 1)
Cabin _ Cabin(Air Conditioner 2)
Cabin _ Cabin(Air Conditioner 3)
Cabin _ Cabin(Air Conditioner 4)
Labels _ Label 1
Labels _ Label 2
Labels _ Label 3
Accessories _ Accessories
Option _ Blade Kit [Option]
Option _ Crawler(Iron Crawler) [Option]
Region: Australia
Engine _ Crank Case
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Head Cover
Engine _ Flywheel
Engine _ Governor
Engine _ Dynamo
Engine _ Starter
Engine _ Muffler
Track Frame _ Idler
Swivel Frame _ Step
Hood_Bonnet _ Seat
Cabin _ Cabin(Body)
Cabin _ Cabin(Door)
Cabin _ Cabin(Trim)
Labels _ Label 1
Labels _ Label 2
Labels _ Label 3
