Kubota Excavator KX057-4 80001- Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX057-4 Excavator
Serial Number: 80001-
Number of Pages: 597 Pages
Artículos De Uso Frecuente / Frequently Used Items
Piezas De Mantenimiento / Maintenance Parts
Bloque Motor / Crank Case
Engrase La Cacerola / Oil Pan
Varilla De Nivel / Dipstick And Guide
Culata Cubierta / Head Cover
Piston Y Ciguenal / Piston And Crankshaft
Volante / Flywheel
Unidad De La Bomba De Inyeccion / Injection Pump Unit
Cubierta De La Bomba De Inyeccion / Injection Pump Housing
Inyeccion Bomba / Injection Pump
Combustible Arbol De Levas / Fuel Camshaft
Bifurcacion Palanca (Regulador) / Fork Lever (Governor)
Restriccion Que Ajusta El Perno / Restriction Adjusting Bolt
Combustible Tubos / Fuel Piping
Alternador / Alternator
Alternador (Componente Piezas) / Alternator (Component Parts)
Motor De Arranque / Starter
Motor De Arranque (Componente Piezas) / Starter (Component Parts)
Aceite Conmutador/Sensor / Oil Switch/Thermometer
Agua Bomba / Water Pump
Agua Tubo (Cuerpo) / Water Pipe (Body)
Reserva Deposito / Reserve Tank
Ventilador / Fan
Aire Limpiador / Air Cleaner
Silenciador / Muffler
Superior Junta Kit [Opcion] / Upper Gasket Kit [Option]
Bajar Junta Kit [Opcion] / Lower Gasket Kit [Option]
Autimatico Ocioso Motor / Auto Idle Motor
Combustible Tubos / Fuel Pump And Piping
Combustible Filtro (Componente Piezas) / Fuel Filter (Component Parts)
Separador De Agua (Componente Piezas) / Water Separator (Component Parts)
Combustible Deposito [Excepto Fp] / Fuel Tank [Except Fp]
Combustible Deposito [Fp] / Fuel Tank [Fp]
Combustible Suministro Bomba [Fp] / Fuel Supply Pump [Fp]
Temporizador Y Claxon / Relay And Horn
Conmutador Y Metro / Switch And Meter
Luz / Light
Electrico Cableado / Electrical Wiring
Antirrobo Alarma Sistema / Anti-Theft Alarm System
Bomba Carcasa / Pump Housing
Piston Bomba / Piston Pump
Piston Bomba (Componente Piezas) / Piston Pump (Component Parts)
Accionar Motor / Drive Motor
Accionar Motor (Componente Piezas) / Drive Motor (Component Parts)
Girar Motor / Swivel Motor
Girar Motor (Componente Piezas) / Swivel Motor (Component Parts)
Rotativo Junta / Rotary Joint
Rotativo Junta (Componente Piezas) / Rotary Joint (Component Parts)
Tanque De Aceite (1) / Oil Tank (1)
Tanque De Aceite (2) / Oil Tank (2)
Aceite Filtro / Oil Filter
Control Valvula (1) / Control Valve (1)
Control Valvula (2) / Control Valve (2)
Control Valvula (3) / Control Valve (3)
Control Valvula (Componente Piezas) / Control Valve (Component Parts)
Corredera Seccion (Salide) / Spool Section (Outlet)
Corredera Seccion (Ax1) / Spool Section (Ax1 )
Corredera Seccion (Girar) / Spool Section (Swivel)
Corredera Seccion (Cubo) / Spool Section (Bucket)
Corredera Seccion (Brazo) / Spool Section (Arm)
Corredera Seccion (Aguilon) / Spool Section (Boom)
Corredera Seccion (Recorrido) / Spool Section (Travel Independence)
Corredera Seccion (Recorrido Derecho) / Spool Section (Travel Rh)
Corredera Seccion (Recorrido Izquierdo) / Spool Section (Travel Lh)
Corredera Seccion (Delantera) / Spool Section (Lead)
Corredera Seccion (Oscilacion) / Spool Section (Swing)
Corredera Seccion (Lamina) / Spool Section (Blade)
Corredera Seccion (Ax2) / Spool Section (Ax2)
Descargador Valvula / Unload Valve
Descargador Valvula (Componente Piezas) / Unload Valve (Component Parts)
S/P Solenoide Valvula / S/P Solenoid Valve
Control Palanca (Palanca Izquierdo) / Control Lever (Lever Lh)
Piloto Valvula (Iz) (Componente Piezas) / Pilot Valve (Lh) (Component Parts)
Control Palanca (Palanca Derecho) / Control Lever (Lever Rh)
Piloto Valvula (Dr) (Componente Piezas) / Pilot Valve (Rh) (Component Parts)
Control Palanca (Recorrido) / Control Lever (Travel)
Piloto Valvula (Recorrido) / Pilot Valve (Travel)
Piloto Valvula (Recorrido) (Componente Piezas) / Pilot Valve (Travel) (Component Parts)
Aguilon Oscilacion Pedal / Swing Pedal
Piloto Valvula (Oscilacion) / Pilot Valve (Swing)
Piloto Valvula (Oscilacion) (Componente Piezas) / Pilot Valve (Swing) (Component Parts)
Control Palanca(Seguridad Cerradura Palanca) / Control Lever (Safety Lock Lever)
Control Palanca (Lamina) / Control Lever (Blade)
Piloto Valvula (Lamina) / Pilot Valve (Blade)
Piloto Valvula (Lamina) (Componente Piezas) / Pilot Valve (Blade) (Component Parts)
Aceite Tubos (Asupiracion) / Oil Piping (Suction)
Aceite Tubos (Entrega) / Oil Piping (Delivery)
Aceite Tubos (Devolver) / Oil Piping (Return)
Aceite Tubos (Aceite Refrigerador) / Oil Piping (Oil Cooler)
Aceite Tubos (Control Izquierdo) / Oil Piping (Control Lh)
Aceite Tubos (Control Derecho) / Oil Piping (Control Rh)
Aceite Tubos (Piloto P) / Oil Piping (Pilot P)
Aceite Tubos (Piloto T) / Oil Piping (Pilot T)
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh)
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh)
Aceite Tubos (Girar) / Oil Piping (Swivel)
Aceite Tubos (Oscilacion) / Oil Piping (Swing)
Aceite Tubos (Aguilon) / Oil Piping (Boom)
Valvula De Retencion (Componentes Piezas) / Holding Valve (Component Parts)
Aceite Tubos (Brazo) / Oil Piping (Arm)
Aceite Tubos (Cubo) / Oil Piping (Bucket)
Aceite Tubos (Lamina) / Oil Piping (Blade)
Aceite Tubos (Abrazadera) / Oil Piping (Clamp)
Aceite Tubos (Servicio Piezas 1) / Oil Piping (S/P 1)
Aceite Tubos (Servicio Piezas 2) / Oil Piping (S/P 2)
Aceite Tubos (Tercera Linea Hidraulico Devolver) / Oil Piping (Third Line Hydraulic Return)
Aguilon Cilindro / Boom Cylinder
Brazo Cilindro / Arm Cylinder
Cubo Cilindro / Bucket Cylinder
Lamina Cilindro / Blade Cylinder
Oscilacion Cilindro / Swing Cylinder
Oscilacion Soporte / Swing Bracket
Aguilon / Boom
Cilindro Cubierta (Aguilon) / Cylinder Cover (Boom)
Brazo / Arm
Cubo Vinculo / Bucket Link
Lamina / Blade
Tren De Orugas Bastidor / Track Frame
Rueda Loca / Idler
Camion Rodillo / Track Roller
Tractor Sobure Orugas / Crawler
Girar Bastidor (1) / Swivel Frame (1)
Girar Bastidor (2) / Swivel Frame (2)
Arco Bastidor (1) / Arch Frame (1)
Arco Bastidor (2) [Excepto Fp] / Arch Frame (2) [Except Fp]
Arco Bastidor (2) [Fp] / Arch Frame (2) [Fp]
Girar Rodamiento / Swivel Bearing
Peldano / Step
Cubierta (Izquierdo) / Cover (Lh)
Cubierta (Derecho) / Cover (Rh)
Capo (Izquierdo) [Excepto Fp] / Bonnet (Lh) [Except Fp]
Capo (Izquierdo) [Fp] / Bonnet (Lh) [Fp]
Capo (Derecho 1) / Bonnet (Rh 1)
Capo (Derecho 2) / Bonnet (Rh 2)
Capo (Trasero) / Bonnet (Rear)
Capo (Centre) / Bonnet (Center)
Esponja (1) / Sponge (1)
Esponja (2) / Sponge (2)
Esponja (3) / Sponge (3)
Peso / Weight
Asiento / Seat
Cabina (Carroceria) / Cabin (Body)
Cabina(Puerta) / Cabin (Door)
Cabina (Ventana 1) / Cabin (Window 1)
Cabina (Ventana 2) / Cabin (Window 2)
Cabina (Cubierta Y Revestimiento) / Cabin (Cover And Trim)
Cabina (Forro) / Cabin (Lining)
Cabina (Reten Caucho) / Cabin (Seal Rubber)
Cabina (Espejo Retrovisor) / Cabin (Rearview Mirror)
Cabina (Limpiaparabrisas Motor) / Cabin (Wiper Motor)
Cabina (Electrico Cableado) / Cabin (Electrical Wiring)
Cabina(Calentador 1) / Cabin (Heater 1)
Cabina(Calentador 2) / Cabin (Heater 2)
Cabina(Calentador 3) / Cabin (Heater 3)
Etiqueta / Label
Accesorios / Accessories
Ljuego Protección Contra Caída Y Proyección De Piedras [Opcion] / Kit Gravel Guard [Option]
Vál.Antirot.Tubo/Brazo / Pipe-Break Valve/Arm
Vál.Antirot.Tubo/Cuchil / Pipe-Break Valve/Dozer
Juego Tiltmotor / Kit Tiltmotor
Juego Powertilt / Kit Powertilt
Juego De Acoplamientos Rápidos / Kit Plug-In Coupler
Juego De Acoplamientos Planos / Kit Flat-Face Coupler
Juego De Acoplamientos Filetados / Kit Screw-Type Coupler
Kit Pinza (Sin Acoplador) / Clamp Kit (Without Quick-Coupler)
Kit Luz Central / Kit Rotating Beacon
Gap-Kit 3 (Kuk)
Juego De Mordazas / Clamshell Kit
Juego Cambio Rápido Hidráulico / Kit Quick Coupler Hydraulic
Acoplador (Componentes) / Quick-Coupler (Component Parts)
Soporte - Km205 / Mounting Brackets - Km205
Kit Martillo Hidráulico / Kit Hydraulic Breaker
Juego Powertilt (Cambio Rápido Hidr.) / Kit Powertilt (Quick Coupler Hydr.)
Juego Powertilt (Cambio Rápido Mec.) / Kit Powertilt (Quick Coupler Mech.)
Juego Powertilt (Cambio Rápido Hidr.)(Brazo 1820) / Kit Powertilt (Quick Coupler Hydr.)(Arm 1820)
Juego Powertilt (Cambio Rápido Mec.)(Brazo 1820) / Kit Powertilt (Quick Coupler Mech.)(Arm 1820)
Soporte - Km305 / Mounting Brackets - Km305
Juego Powertilt (Cambio Rápido Hidr.)(Brazo 1570) / Kit Powertilt (Quick Coupler Hydr.)(Arm 1570)
Juego Powertilt (Cambio Rápido Mec.)(Brazo 1570) / Kit Powertilt (Quick Coupler Mech.)(Arm 1570)
Cazo (No Acoplador) / Bucket (No Quick-Coupler)
Kit Zumbador,Trasero / Kit Buzzer,Travel
