Kubota Excavator KX040-4 Parts Manual
Type of Machine: Excavator
Model: Kubota KX040-4 Excavator
Publication Date: 2024
Number of Pages: 486 Pages
000000 Filter And Fluid Capacity
000001 Frequently Used Items
000010 Useful Products
000040 Paint
500000 Crankcase
501000 Oil Pan
501200 Dipstick And Guide
502000 Cylinder Head
502001 Cylinder Head
503000 Inlet Valve And Exhaust Valve
504000 Rocker Arm Shaft
505000 Head Cover
508000 Gear Case
508200 Oil Filter
510500 Main Bearing Case
511000 Piston And Crankshaft
512000 Camshaft And Idle Gear Shaft
515000 Flywheel
521000 Injection Pump
522000 Fuel Camshaft
526500 Supply Pump
540000 Nozzle Holder And Glow Plug
545000 Injection Pipe
548000 Common Rail
550000 Alternator
551000 Alternator (Component Parts)
551001 Alternator (Component Parts)
554000 Starter
555000 Starter (Component Parts)
556000 Oil Switchthermometer
560000 Water Flange And Thermostat
561000 Water Pump
561001 Water Pump
561200 Water Pipe
561500 Water Pipe
565000 Radiator
565500 Reserve Tank
567000 Cooler Fan
571000 Inlet Manifold
572000 Exhaust Manifold
572300 Egr Valve
572400 Egr Cooler
572600 Turbo Charger
573000 Air Cleaner
574000 Diesel Particulate Filter Muffler
574200 Diesel Particulate Filter Muffler Bracket
574500 Diesel Particulate Filter Muffler Sensor
574600 Diesel Particulate Filter Differential Pressure Pipe
574700 Inlet Hose (Turbo Charger)
574900 Diesel Particulate Filter Muffler Cover
579000 Oil Separator
579100 Oil Separator (Component Parts)
579500 Oil Separator Pipe
579600 Operator Tube
580000 Oil Pipe (Turbo Charger)
582000 Oil Cooler
585000 Wire Harness Bracket
586000 Engine Bracket
589000 Operator's Manual
A30001 Fuel Pump And Piping(1)
A30002 Fuel Pump And Piping(2)
A30003 Fuel Pump And Piping(3)
A30100 Fuel Filter (Component Parts)
A30200 Water Separator (Component Parts)
A30201 Water Separator (Component Parts)
A30202 Water Separator (Component Parts)
A30203 Water Separator (Component Parts)[Option]
A30300 Fuel Tank
B40000 Battery
B40200 Horn
B40400 Switch And Meter
B40600 Lamp
B40801 Wire Harness
B40802 Wire Harness
B41001 Starter Switch
C00000 Housing,Pump
C20000 Piston Pump
C20100 Piston Pump(Component Parts)
C30000 Drive Motor
C30101 Drive Motor (Component Parts)
C30102 Drive Motor (Component Parts)
C30103 Drive Motor (Component Parts)
C30104 Drive Motor (Component Parts)
C40000 Swivel Motor
C40101 Swivel Motor (Component Parts)
C40102 Swivel Motor (Component Parts)
C50001 Rotary Joint
C50002 Rotary Joint
C50003 Rotary Joint
C50101 Rotary Joint (Component Parts)
C50102 Rotary Joint (Component Parts)
C50103 Rotary Joint (Component Parts)
C50200 Oil Tank(1)
C50300 Oil Tank (2)
C50400 Oil Filter
C60001 Control Valve(1)
C60002 Control Valve(2)
C60003 Control Valve(3)
C60004 Control Valve(4)
C60005 Control Valve(5)
C60101 Control Valve (Component Parts)
C60102 Control Valve (Component Parts)
C60103 Control Valve (Component Parts)
C60201 Spool Section (Inlet)
C60202 Spool Section (Ax1)
C60203 Spool Section (Swivel)
C60204 Spool Section (Bucket)
C60205 Spool Section (Arm)
C60206 Spool Section (Boom)
C60207 Spool Section (Travel Rh)
C60208 Spool Section (Travel Lh)
C60209 Spool Section (Swing)
C60210 Spool Section (Blade)
C60211 Spool Section (Ax2)
C60212 Spool Section (Angle)
C60213 Spool Section (6-In-1)
C70600 Unload Valve
C70700 Unload Valve (Component Parts)
C80000 Magnetic Solenoid Valve
C80100 Magnetic Solenoid Valve (Component Parts)
C80200 Magnetic Solenoid Valve (6-In-1 Blade)
C81001 S_P Solenoid Valve
C81002 S_P Solenoid Valve
C82000 Angle Change Valve
C91000 Tpss Valve
D10000 Control Lever (Lever Lh)
D10101 Pilot Valve (Lh) (Component Parts)
D10102 Pilot Valve (Lh) (Component Parts)
D20000 Control Lever (Rh)
D20100 Pilot Valve (Rh) (Component Parts)
D30000 Control Lever (Travel)
D31000 Pilot Valve (Travel)
D31100 Pilot Valve (Travel) (Component Parts)
D51000 Swing Pedal
D52000 Pilot Valve (Swing)
D52100 Pilot Valve (Swing) (Component Parts)
D60000 Control Lever (Safety Lock Lever)
D70500 Tpss Lever
D80001 Control Lever (Blade)
D80002 Control Lever (Blade)
D80003 Control Lever (Blade)
D81000 Pilot Valve (Blade)
D81100 Pilot Valve (Blade) (Component Parts)
E00000 Oil Piping (Suction)
E00201 Oil Piping (Delivery)
E00202 Oil Piping (Delivery)
E00400 Oil Piping (Return)
E00600 Oil Piping (Oil Cooler)
E10000 Oil Piping (Control Lh)
E10200 Oil Piping (Control Rh)
E10600 Oil Piping (Pilot P)
E10800 Oil Piping (Pilot T)
E11000 Oil Piping (Energy Saving)
E20001 Oil Piping (Travel Lh)
E20002 Oil Piping (Travel Lh)
E20003 Oil Piping (Travel Lh)
E20201 Oil Piping (Travel Rh)
E20202 Oil Piping (Travel Rh)
E20203 Oil Piping (Travel Rh)
E20400 Oil Piping (Swivel)
E30000 Oil Piping (Swing)
E30400 Oil Piping (Boom)
E40000 Oil Piping (Arm)
E50000 Oil Piping (Bucket)
E60001 Oil Piping (Blade)
E60002 Oil Piping (Blade)
E60003 Oil Piping (Blade)
E65000 Oil Piping (Angle Blade)
E66000 Oil Piping (6-In-1 Blade)
E70001 Oil Piping (Clamp)
E70002 Oil Piping (Clamp)
E80000 Oil Piping (S_P 1)
E80201 Oil Piping (S_P 1)
E80202 Oil Piping (S_P 2)
E82000 Oil Piping (Third Line Hydraulic Return)
F00000 Boom Cylinder
F10000 Arm Cylinder
F20000 Bucket Cylinder
F20001 Bucket Cylinder
F30000 Blade Cylinder
F30001 Blade Cylinder
F31000 Angle Blade Cylinder
F31001 Angle Blade Cylinder
F32000 6-In-1 Blade Cylinder
F32001 6-In-1 Blade Cylinder
F40000 Swing Cylinder
F40001 Swing Cylinder
G00000 Swing Bracket
G10001 Boom
G10400 Cylinder Cover (Boom)
G20000 Arm
G30000 Bucket Link
G50000 Blade
G51000 Angle Blade
G52000 6-In-1 Blade 1
G52100 6-In-1 Blade 2
H00000 Track Frame
H10000 Idler
H20000 Track Roller
H30001 Crawler
H30002 Crawler
J00001 Swivel Frame (1)
J00002 Swivel Frame (2)
J00101 Arch Frame (1)
J00200 Arch Frame (2)
J10000 Swivel Bearing
J20001 Seat Support
J30000 Step
K00001 Cover (Lh)
K00101 Cover (Rh)
K00102 Cover (Rh)
K10101 Bonnet (Lh)
K10201 Bonnet (Rh 1)
K10203 Bonnet (Rh 2)
K10301 Bonnet (Rear)
K10400 Bonnet (Center)
K20000 Sponge (1)
K20100 Sponge (2)
K30000 Weight
K40001 Seat
K40002 Seat
L00000 Canopy
L10000 Cabin (Body)
L20000 Cabin (Door)
L30001 Cabin (Window 1)
L30101 Cabin (Window 2)
L40001 Cabin (Cover And Trim)
L40100 Cabin (Lining)
L40200 Cabin (Seal Rubber)
L42000 Cabin (Rearview Mirror)
L50000 Cabin (Wiper Motor)
L50200 Cabin (Electrical Wiring)
L60000 Cabin (Heater)
L60201 Cabin (Air Conditioner 1)
L60202 Cabin (Air Conditioner 1)
L60300 Cabin (Air Conditioner 2)
L60400 Cabin (Air Conditioner 3)
M00001 Label
N00000 Accessories
P00000 Wire Harness Kit [Option]
000040 Paint
500000 Crankcase
501000 Oil Pan
505000 Head Cover
508000 Gear Case
508200 Oil Filter
515000 Flywheel
526500 Supply Pump
548000 Common Rail
550000 Alternator
554000 Starter
561000 Water Pump
561001 Water Pump
561200 Water Pipe
561500 Water Pipe
565000 Radiator
565500 Reserve Tank
567000 Cooler Fan
572300 Egr Valve
572400 Egr Cooler
573000 Air Cleaner
582000 Oil Cooler
A30300 Fuel Tank
B40000 Battery
B40200 Horn
B40600 Lamp
B40801 Wire Harness
B40802 Wire Harness
C00000 Housing,Pump
C20000 Piston Pump
C30000 Drive Motor
C40000 Swivel Motor
C50001 Rotary Joint
C50002 Rotary Joint
C50003 Rotary Joint
C50200 Oil Tank(1)
C50300 Oil Tank (2)
C50400 Oil Filter
C70600 Unload Valve
C91000 Tpss Valve
D51000 Swing Pedal
D70500 Tpss Lever
F10000 Arm Cylinder
G10001 Boom
G20000 Arm
G30000 Bucket Link
G50000 Blade
G51000 Angle Blade
H00000 Track Frame
H10000 Idler
H20000 Track Roller
H30001 Crawler
H30002 Crawler
J20001 Seat Support
J30000 Step
K00001 Cover (Lh)
K00101 Cover (Rh)
K00102 Cover (Rh)
K10101 Bonnet (Lh)
K20000 Sponge (1)
K20100 Sponge (2)
K30000 Weight
K40001 Seat
K40002 Seat
L00000 Canopy
L10000 Cabin (Body)
L20000 Cabin (Door)
M00001 Label
N00000 Accessories
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
