Kubota Excavator KX040-4 Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX040-4 Excavator
Region: Australia
Number of Pages: 490 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crankcase ## Note _ Order By Ref.No.010 New Part And Fig.No.556000 Ref.No
Engine _ Oil Pan
Engine _ Dipstick And Guide
Engine _ Cylinder Head
Engine _ Inlet Valve And Exhaust Valve
Engine _ Rocker Arm Shaft
Engine _ Head Cover
Engine _ Gear Case
Engine _ Oil Filter
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Injection Pump
Engine _ Fuel Camshaft
Engine _ Supply Pump
Engine _ Injection Pipe
Engine _ Common Rail
Engine _ Alternator
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Oil Switch_Thermometer
Engine _ Water Pump ## S.No._=7kvz999 S.No.;_=7kvz999
Engine _ Water Pump ## S.No._=7kw0001 S.No.;_=7kw0001
Engine _ Water Pipe
Engine _ Water Pipe
Engine _ Radiator
Engine _ Reserve Tank
Engine _ Cooler Fan
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ EGR Valve
Engine _ EGR Cooler
Engine _ Turbo Charger
Engine _ Air Cleaner
Engine _ Diesel Particulate Filter Muffler
Engine _ Diesel Particulate Filter Muffler Bracket
Engine _ Diesel Particulate Filter Muffler Sensor
Engine _ Diesel Particulate Filter Differential Pressure Pipe
Engine _ Inlet Hose (Turbo Charger)
Engine _ Diesel Particulate Filter Muffler Cover
Engine _ Oil Separator
Engine _ Oil Separator (Component Parts)
Engine _ Oil Separator Pipe
Engine _ Oil Pipe (Turbo Charger)
Engine _ Oil Cooler
Engine _ Wire Harness Bracket
Engine _ Engine Bracket
Engine _ Label And Operator's Manual
Fuel System _ Fuel Pump And Piping(1)
Fuel System _ Fuel Pump And Piping(2)
Fuel System _ Fuel Pump And Piping(3)
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Water Separator (Component Parts) ## S.No._=28611 S.No.;_=28611
Fuel System _ Water Separator (Component Parts) ## S.No._=28612 S.No.;_=28612
Fuel System _ Water Separator (Component Parts)[Option]
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Travel Alarm And Horn
Electrical System _ Switch And Meter
Electrical System _ Light
Electrical System _ Wire Harness
Electrical System _ Anti-Theft Alarm System
Pump_Motor System _ Pump Housing
Pump_Motor System _ Piston Pump
Pump_Motor System _ Piston Pump(Component Parts)
Pump_Motor System _ Drive Motor
Pump_Motor System _ Drive Motor (Component Parts)
Pump_Motor System _ Swivel Motor
Pump_Motor System _ Swivel Motor (Component Parts)
Pump_Motor System _ Rotary Joint ## [Except Angle Blade]
Pump_Motor System _ Rotary Joint ## [Angle Blade]
Pump_Motor System _ Rotary Joint (Component Parts) ## [Except Angle Blade]
Pump_Motor System _ Rotary Joint (Component Parts) ## [Angle Blade]
Pump_Motor System _ Oil Tank(1)
Pump_Motor System _ Oil Tank (2)
Pump_Motor System _ Oil Filter
Control Valve _ Control Valve(1) ## Note 1_Order By Part No
Control Valve _ Control Valve(2)
Control Valve _ Control Valve(3)
Control Valve _ Control Valve(4) ## [Angle Blade]
Control Valve _ Control Valve (Component Parts) ## [Except Angle Blade]
Control Valve _ Control Valve (Component Parts) ## [Angle Blade]
Control Valve _ Spool Section (Inlet)
Control Valve _ Spool Section (Ax1)
Control Valve _ Spool Section (Swivel)
Control Valve _ Spool Section (Bucket)
Control Valve _ Spool Section (Arm)
Control Valve _ Spool Section (Boom)
Control Valve _ Spool Section (Travel Rh)
Control Valve _ Spool Section (Travel Lh)
Control Valve _ Spool Section (Swing)
Control Valve _ Spool Section (Blade)
Control Valve _ Spool Section (Ax2)
Control Valve _ Spool Section (Angle) ## [Angle Blade]
Control Valve _ Unload Valve
Control Valve _ Unload Valve (Component Parts)
Control Valve _ Magnetic Solenoid Valve
Control Valve _ Magnetic Solenoid Valve (Component Parts)
Control Valve _ S_P Solenoid Valve
Control Valve _ Angle Change Valve ## [Angle Blade]
Control Valve _ TPSS Valve
Control Lever _ Control Lever (Lever Lh)
Control Lever _ Pilot Valve (Lh) (Component Parts)
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Pilot Valve (Rh) (Component Parts)
Control Lever _ Control Lever (Travel)
Control Lever _ Pilot Valve (Travel)
Control Lever _ Pilot Valve (Travel) (Component Parts)
Control Lever _ Swing Pedal
Control Lever _ Pilot Valve (Swing)
Control Lever _ Pilot Valve (Swing) (Component Parts)
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ TPSS Lever
Control Lever _ Control Lever (Blade) ## [Except Angle Blade]
Control Lever _ Control Lever (Blade) ## [Angle Blade]
Control Lever _ Pilot Valve (Blade)
Control Lever _ Pilot Valve (Blade) (Component Parts)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Delivery)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Oil Cooler)
Oil Piping _ Oil Piping (Control Lh)
Oil Piping _ Oil Piping (Control Rh)
Oil Piping _ Oil Piping (Pilot P)
Oil Piping _ Oil Piping (Pilot T)
Oil Piping _ Oil Piping (Energy Saving)
Oil Piping _ Oil Piping (Travel Lh) ## [Except Angle Blade]
Oil Piping _ Oil Piping (Travel Lh) ## [Angle Blade]
Oil Piping _ Oil Piping (Travel Rh) ## [Except Angle Blade]
Oil Piping _ Oil Piping (Travel Rh) ## [Angle Blade]
Oil Piping _ Oil Piping (Swivel)
Oil Piping _ Oil Piping (Swing)
Oil Piping _ Oil Piping (Boom)
Oil Piping _ Oil Piping (Arm)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Blade) ## [Except Angle Blade]
Oil Piping _ Oil Piping (Blade) ## [Angle Blade]
Oil Piping _ Oil Piping (Angle Blade) ## [Angle Blade]
Oil Piping _ Oil Piping (Clamp)
Oil Piping _ Oil Piping (S_P)
Oil Piping _ Oil Piping (Third Line Hydraulic Return)
Cylinder _ Boom Cylinder
Cylinder _ Arm Cylinder
Cylinder _ Bucket Cylinder
Cylinder _ Blade Cylinder
Cylinder _ Angle Blade Cylinder ## [Angle Blade]
Cylinder _ Swing Cylinder
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Cylinder Cover (Boom)
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade ## [Except Angle Blade]
Front Attachments _ Angle Blade ## [Angle Blade]
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Track Roller
Track Frame _ Crawler
Swivel Frame _ Swivel Frame (1)
Swivel Frame _ Swivel Frame (2)
Swivel Frame _ Arch Frame (1)
Swivel Frame _ Arch Frame (2)
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
External_Upholstery _ Cover (Lh)
External_Upholstery _ Cover (Rh) ## [Canopy]Note_Order By Ref.No.010 & Ref.No
External_Upholstery _ Cover (Rh) ## [Cabin]Note_Order By Ref.No.010 & Ref.No
External_Upholstery _ Bonnet (Lh)
External_Upholstery _ Bonnet (Rh 1)
External_Upholstery _ Bonnet (Rh 2)
External_Upholstery _ Bonnet (Rear)
External_Upholstery _ Bonnet (Center)
External_Upholstery _ Sponge (1)
External_Upholstery _ Sponge (2)
External_Upholstery _ Weight
External_Upholstery _ Seat ## [Canopy]
External_Upholstery _ Seat ## [Cabin]
Operator's Platform _ Canopy
Operator's Platform _ Canopy (Electrical Wiring)
Operator's Platform _ Cabin (Body)
Operator's Platform _ Cabin (Door)
Operator's Platform _ Cabin (Window 1)
Operator's Platform _ Cabin (Window 2)
Operator's Platform _ Cabin (Sponge)
Operator's Platform _ Cabin (Lining)
Operator's Platform _ Cabin (Seal Rubber)
Operator's Platform _ Cabin (Rear View Mirror)
Operator's Platform _ Cabin (Wiper Motor)
Operator's Platform _ Cabin (Electrical Wiring)
Operator's Platform _ Cabin (Heater)
Operator's Platform _ Cabin (Air Conditioner 1)
Operator's Platform _ Cabin (Air Conditioner 2)
Operator's Platform _ Cabin (Air Conditioner 3)
Labels _ Label
Accessories _ Accessories
Region: Australia
Engine _ Oil Pan
Engine _ Head Cover
Engine _ Gear Case
Engine _ Oil Filter
Engine _ Flywheel
Engine _ Alternator
Engine _ Starter
Engine _ Water Pipe
Engine _ Water Pipe
Engine _ Radiator
Engine _ Cooler Fan
Engine _ EGR Valve
Engine _ EGR Cooler
Engine _ Oil Cooler
Track Frame _ Idler
Swivel Frame _ Step
Labels _ Label
