Kubota Excavator KX019-4 70001- Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX019-4 Excavator
Serial Number: 70001-
Number of Pages: 369 Pages
Artículos Utilizados Frecuentemente / Maintenance Parts
Bloque Motor / Crankcase
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Caja De Cambio / Gear Case
Tapa De La Culata / Head Cover
Caja De Cambios Ppal / Main Bearing Case
Tapa De Balancines / Camshaft And Idle Gear Shaft
Piston Y Ciguenal / Piston And Crankshaft
Volante / Flywheel
Arbol De Levas Sist De Combustible / Fuel Camshaft
Silenciador / Stop Solenoid
Inyector (Comp.) / Nozzle Holder (Component Parts)
Alternador / Alternator
Alternador (Componentes) / Alternator (Component Parts)
Motor De Arranque / Starter
Motor Arranq. (Componentes) / Starter (Component Parts)
Brida De Agua Y Termostato / Water Flange And Thermostat
Bomba Agua / Water Pump
Manguitoagua / Water Flange
Valvulas Y Balancines / Valve And Rocker Arm
Manguito Agua / Exhaust Manifold
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Juego De Juntas (1) / Gasket Kit (1)
Juego De Juntas (2) / Gasket Kit (2)
Pal. Acel. / Accel Lever
Conductos Del Combustible / Fuel Piping
Filtro Comb. (Componentes) / Fuel Filter (Component Parts)
Colector De Agua (Componentes) / Water Separator (Component Parts)
Temp., Boc. / Timer And Horn
Interruptor Y Medidor / Switch And Meter
Luces / Light
Luces [Opcion] / Light [Option]
Cableado Elétrico / Wire Harness
Pilotaje Bomba (Componentes) / Piston Pump (Component Parts)
Motor Acc. Y Component. / Drive Motor And Component Parts
Motor De Rotac. Y Comp. / Swivel Motor And Component Parts
Junta Giratoria / Rotary Joint
Serbatoio Dell’olio / Oil Tank
Distribuidor / Control Valve
Corredera Seccion (Recorrido) / Section (Boom/Swing)
Corredera Seccion (Lamina) / Section (Dozer)
Corredera Seccion (Recorrido) / Section (Slew)
Corredera Seccion (Recorrido) / Section (Confluence)
Corredera Seccion (Servicio Piezas) / Section (Service)
Corredera Seccion (Brazo) / Section (Arm)
Corredera Seccion (Recorrido Izquierdo) / Section (Travel,L)
Corredera Seccion (Entrada) / Section (Inlet)
Corredera Seccion (Recorrido Derecho) / Section (Travel,R)
Sección (Brazo Princ.) / Section (Boom)
Corredera Seccion (Cubo) / Section (Bucket)
Corredera Seccion (Girar) / Section (Track)
Corredera Seccion (Servicio Piezas) / Unload Valve
Válvula Descarga (Componentes) / Unload Valve (Component Parts)
Válvula De Cambio / Change Valve
Válvula De Cambio (Componentes) / Change Valve (Component Parts)
Control Palanca (Bastidor) / Control Lever (Frame)
Control Palanca (Lado Izdo.) / Control Lever (Lever Lh)
Válv. Aux. (Componentes) Li / Pilot Valve (Component Parts) Lh
Control Palanca (Lado Dcho.) / Control Lever (Lever Rh)
Válv. Aux. (Componentes) Ld / Pilot Valve (Component Parts) Rh
Control Palanca (Recorrido) / Control Lever (Travel)
Pal. Ctrol (Bastidor) / Control Lever (Track)
Ped.Brazo Princ. Oscilación / Boom Swing Pedal
Palanca Control (Seguridad) / Control Lever (Safety Lock Lever)
Ped. Ctrol (Giro/Oscil.) / Control Pedal (Swivel/Swing)
Palanca De Control (Hoja) / Control Lever (Blade)
Palanca De Control (S/P) / Control Lever (S/P)
Aceite Tubos (Succión) / Oil Piping (Suction)
Aceite Tubos (Entrega) / Oil Piping (Delivery)
Aceite Tubos (Devolver) / Oil Piping (Return)
Aceite Tubos (Aceite Refrigerador) / Oil Piping (Oil Cooler)
Aceite Tubos (Control Izquierdo) / Oil Piping (Operation Lh)
Aceite Tubos (Control Derecho) / Oil Piping (Operation Rh)
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh)
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh)
Aceite Tubos (Girar) / Oil Piping (Swivel)
Aceite Tubos (Oscilacion) / Oil Piping (Swing)
Aceite Tubos (Aguilon) / Oil Piping (Boom)
Aceite Tubos (Brazo) / Oil Piping (Arm)
Aceite Tubos (Cubo) / Oil Piping (Bucket)
Aceite Tubos (Lamina) / Oil Piping (Blade)
Conductos Acaite (Chasis) / Oil Piping (Track)
Aceite Tubos (Abrazadera) / Oil Piping (Clamp)
Aceite Tubos (Servicio Piezas 1) / Oil Piping (S/P)
Aguilon Cilindro / Boom Cylinder And Component Parts
Brazo Cilindro / Arm Cylinder And Component Parts
Cubo Cilindro / Bucket Cylinder And Component Parts
Lamina Cilindro / Blade Cylinder And Component Parts
Oscilacion Cilindro / Swing Cylinder And Component Parts
Cilindro Bastidor Y Comp. / Track Cylinder And Component Parts
Oscilacion Soporte / Swing Bracket
Aguilon / Boom
Brazo / Arm
Cubo Vinculo / Bucket Link
Cubo / Bucket
Aguilon Cilindro / Blade
Brazo Cilindro / Track Frame
Cubo Cilindro / Idler
Lamina Cilindro / Crawler And Truck Roller
Oscilacion Cilindro / Swivel Frame
Oscilacion Soporte / Arch Frame
Aguilon / Swivel Bearing
Soporte Del Asiento / Seat Support
Peldano / Step
Cubierta (Izquierdo) / Cover (Lh)
Cubierta (Derecho) / Cover (Rh)
Capo (Adelante) / Bonnet (Front)
Capot (Lado Izdo.) / Bonnet (Lh)
Capot (Lado Dcho.) / Bonnet (Rh)
Capot (Posterior) / Bonnet (Rear)
Esponja (1) / Sponge (1)
Esponja (2) / Sponge (2)
Esponja (3) / Sponge (3)
Esponja (4) / Sponge (4)
Peso / Weight
Asiento / Seat
Marcotecho / Canopy
Cabina (Junta Caucho) / Cabin (Seal Rubber)
Cabina (Carroceria) / Cabin (Body)
Cabina (Ventanilla 1) / Cabin (Window 1)
Cabina (Ventanilla 2) / Cabin (Window 2)
Cabina (Puerta) / Cabin (Door)
Cabina (Cableado Elétrico) / Cabin (Electrical Wiring)
Cabina (Accesorios 1) / Cabin (Accessories 1)
Cabina (Accesorios 2) / Cabin (Accessories 2)
Cabina (Calefacción) / Cabin (Heater)
Etiqueta / Label
Accesorios 1 / Accessories 1
Accesorios 2 / Accessories 2
Vál.Antirot.Tubo/Pesc. / Pipe-Break Valve/Boom
Vál.Antirot.Tubo/Brazo / Pipe-Break Valve/Arm
Vál.Antirot.Tubo/Cuchil / Pipe-Break Valve/Dozer
Sistema De Aviso / Warning System
Juego Pedales / Kit Travel Pedal
Kit Parasassi / Kit Gravel Guard
Juego Preparación Radio / Kit Radio Accessory
Retromatic Cambio Rápido Serie02 / Retromatic Qc-Series02
Kit De Caja Negra / Kit Black Box
Juego De Mordazas / Clamshell Kit
Juego De Acoplamientos Rápidos / Kit Plug-In Coupler
Juego De Acoplamientos Rápidos / Kit Flat-Face Coupler
Juego De Acoplamientos Rápidos / Kit Screw-Type Coupler
Powertilit,Juego / Kit Powertilt W/O Load Hook
Powertilit,Juego / Kit Powertilt With Load Hook
Soporte - Km105 / Mounting Brackets - Km105
Kit Martillo Hidráulico / Kit Hydraulic Breaker
Juego Cambio Rápido Hidráulico / Kit Quick Coupler Hydraulic
Cambio Rápido Hidráulico / Quick Coupler Hydraulic
