Kubota Excavator KX018-4 50001- Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota KX018-4 Excavator
Region: Australia
Serial Number: 50001-
Number of Pages: 272 Pages
Frequently Used Items _ Frequently Used Items
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Cylinder Head
Engine _ Gear Case
Engine _ Head Cover
Engine _ Engine Bracket
Engine _ Main Bearing Case
Engine _ Piston And Crankshaft
Engine _ Flywheel
Engine _ Fuel Camshaft
Engine _ Stop Solenoid
Engine _ Injection Pump
Engine _ Governor
Engine _ Speed Control Plate
Engine _ Nozzle Holder (Component Parts)
Engine _ Alternator
Engine _ Alternator (Component Parts)
Engine _ Starter
Engine _ Starter (Component Parts)
Engine _ Water Pump
Engine _ Radiator
Engine _ Water Pipe
Engine _ Valve And Rocker Arm
Engine _ Inlet Manifold
Engine _ Exhaust Manifold
Engine _ Air Cleaner
Engine _ Muffler
Engine _ Gasket Kit (1)
Engine _ Gasket Kit (2)
Fuel System _ Accel Lever
Fuel System _ Fuel Piping
Fuel System _ Fuel Filter (Component Parts)
Fuel System _ Water Separator (Component Parts)
Fuel System _ Fuel Tank
Electrical System _ Battery
Electrical System _ Timer And Horn
Electrical System _ Switch And Meter
Electrical System _ Light
Electrical System _ Wire Harness
Electrical System _ Wire Harness ## S.No._=50126 S.No.;_=50126
Electrical System _ Wire Harness ## S.No._=50127 S.No.;_=50127
Pump_Motor System _ Piston Pump (Component Parts)
Pump_Motor System _ Drive Motor And Component Parts
Pump_Motor System _ Swivel Motor And Component Parts
Pump_Motor System _ Rotary Joint
Pump_Motor System _ Oil Tank
Control Valve _ Control Valve
Control Valve _ Section (Boom_Swing)
Control Valve _ Section (Dozer)
Control Valve _ Section (Slew)
Control Valve _ Section (Confluence)
Control Valve _ Section (Service)
Control Valve _ Section (Arm)
Control Valve _ Section (Travel,L)
Control Valve _ Section (Inlet)
Control Valve _ Section (Travel,R)
Control Valve _ Section (Boom)
Control Valve _ Section (Bucket)
Control Valve _ Section (Track)
Control Valve _ Unload Valve
Control Valve _ Unload Valve (Component Parts)
Control Valve _ Valve Tpss
Control Lever _ Control Lever (Frame)
Control Lever _ Control Lever (Lever Lh)
Control Lever _ Pilot Valve (Component Parts) Lh
Control Lever _ Control Lever (Lever Rh)
Control Lever _ Pilot Valve (Component Parts) Rh
Control Lever _ Control Lever (Travel)
Control Lever _ Control Lever (Track)
Control Lever _ Boom Swing Pedal
Control Lever _ Control Lever (Safety Lock Lever)
Control Lever _ Control Pedal (Swivel_Swing)
Control Lever _ Control Lever (Blade)
Control Lever _ Control Lever (S_P)
Oil Piping _ Oil Piping (Suction)
Oil Piping _ Oil Piping (Delivery)
Oil Piping _ Oil Piping (Return)
Oil Piping _ Oil Piping (Oil Cooler)
Oil Piping _ Oil Piping (Operation Lh)
Oil Piping _ Oil Piping (Operation Rh)
Oil Piping _ Oil Piping (Travel Lh)
Oil Piping _ Oil Piping (Travel Rh)
Oil Piping _ Oil Piping (Swivel)
Oil Piping _ Oil Piping (Swing)
Oil Piping _ Oil Piping (Boom)
Oil Piping _ Oil Piping (Arm)
Oil Piping _ Oil Piping (Bucket)
Oil Piping _ Oil Piping (Blade)
Oil Piping _ Oil Piping (Track)
Oil Piping _ Oil Piping (Clamp)
Oil Piping _ Oil Piping (S_P)
Cylinder _ Boom Cylinder And Component Parts
Cylinder _ Arm Cylinder And Component Parts
Cylinder _ Bucket Cylinder And Component Parts
Cylinder _ Blade Cylinder And Component Parts
Cylinder _ Swing Cylinder And Component Parts
Cylinder _ Track Cylinder And Component Parts
Front Attachments _ Swing Bracket
Front Attachments _ Boom
Front Attachments _ Arm
Front Attachments _ Bucket Link
Front Attachments _ Blade
Track Frame _ Track Frame
Track Frame _ Idler
Track Frame _ Crawler And Truck Roller
Swivel Frame _ Swivel Frame
Swivel Frame _ Arch Frame
Swivel Frame _ Swivel Bearing
Swivel Frame _ Seat Support
Swivel Frame _ Step
External_Upholstery _ Cover (Lh)
External_Upholstery _ Cover (Rh)
External_Upholstery _ Bonnet (Front)
External_Upholstery _ Bonnet (Lh)
External_Upholstery _ Bonnet (Rh)
External_Upholstery _ Bonnet (Rear)
External_Upholstery _ Sponge (1)
External_Upholstery _ Sponge (2)
External_Upholstery _ Sponge (3)
External_Upholstery _ Weight
External_Upholstery _ Seat
Operator's Platform _ Canopy
Labels _ Label
Accessories _ Accessories
264025-04-11 16-27-29 document
Option _ Kit Travel Pedal
Option _ Kit Gravel Guard (Canopy)
Option _ Kit Battery Isolator Switch
Option _ Buzzer(Travel)
Region: Australia
Engine _ Crankcase
Engine _ Oil Pan
Engine _ Gear Case
Engine _ Head Cover
Engine _ Flywheel
Engine _ Governor
Engine _ Alternator
Engine _ Starter
Engine _ Water Pump
Engine _ Radiator
Engine _ Water Pipe
Engine _ Muffler
Track Frame _ Idler
Swivel Frame _ Step
Labels _ Label
