Kubota Excavator KX018-4 50001-69999 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX018-4 Excavator
Serial Number: 50001-69999
Number of Pages: 355 Pages
Bloque Motor / Crankcase
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Caja De Cambio / Gear Case
Tapa De La Culata / Head Cover
Soporte Del Motor / Engine Bracket
Caja De Cambios Ppal / Main Bearing Case
Árbol Levas Y Eje Vel. Dir. / Camshaft And Idle Gear Shaft
Piston Y Ciguenal / Piston And Crankshaft
Volante / Flywheel
Arbol De Levas Sist De Combustible / Fuel Camshaft
Solenoide, Parada / Stop Solenoid
Duesenhalter Und Gluehkerze / Nozzle Holder And Glow Plug
Inyector (Comp.) / Nozzle Holder (Component Parts)
Alternador / Alternator
Alternador (Componentes) / Alternator (Component Parts)
Motor De Arranque / Starter
Motor Arranq. (Componentes) / Starter (Component Parts)
Brida De Agua Y Termostato / Water Flange And Thermostat
Bomba Agua / Water Pump
Manguitoagua / Water Pipe
Valvulas Y Balancines / Valve And Rocker Arm
Colector De Escape / Exhaust Manifold
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Juego De Juntas (1) / Gasket Kit (1)
Juego De Juntas (2) / Gasket Kit (2)
Pal. Acel. / Accel Lever
Conductos Del Combustible / Fuel Piping
Filtro Comb. (Componentes) / Fuel Filter (Component Parts)
Colector De Agua (Componentes) / Water Separator (Component Parts)
Temp., Boc. / Timer And Horn
Interruptor Y Medidor / Switch And Meter
Luces / Light
Luces [Opcion] / Light [Option]
Cableado Elétrico / Wire Harness
Pilotaje Bomba (Componentes) / Piston Pump (Component Parts)
Motor Acc. Y Component. / Drive Motor And Component Parts
Motor De Rotac. Y Comp. / Swivel Motor And Component Parts
Junta Giratoria / Rotary Joint
Serbatoio Dell’olio / Oil Tank
Distribuidor / Control Valve
Sec. (Bra. Princ./Oscil.) / Section (Boom/Swing)
Sección (Cuch. Empuje) / Section (Dozer)
Sec. (Oscil.) / Section (Slew)
Sección (Confluencia) / Section (Confluence)
Sección (Servicio) / Section (Service)
Sección (Balancín) / Section (Arm)
Sección (Trasl.,Izda) / Section (Travel,L)
Sección (Admisión) / Section (Inlet)
Sección (Trasl.,Dcha) / Section (Travel,R)
Sección (Brazo Princ.) / Section (Boom)
Sección (Cazo) / Section (Bucket)
Sección (Bastidor) / Section (Track)
Válvula Descarga / Unload Valve
Válvula Descarga(Componentes) / Unload Valve (Component Parts)
Palanca Control / Control Lever (Frame)
Palanca Ctrol (Lado Izdo.) / Control Lever (Lh)
Válv. Aux. (Componentes) Li / Pilot Valve (Component Parts) Lh
Palanca Ctrol (Lado Dcho.) / Control Lever (Rh)
Válv. Aux. (Componentes) Ld / Pilot Valve (Component Parts) Rh
Pal. Ctrol (Trasl.) / Control Lever (Travel)
Pal. Ctrol (Bastidor) / Control Lever (Track)
Ped.Brazo Princ. Oscilación / Boom Swing Pedal
Palanca Control (Seguridad) / Control Lever (Safety Lock Lever)
Ped. Ctrol (Giro/Oscil.) / Control Pedal (Swivel/Swing)
Palanca De Control (Hoja) / Control Lever (Blade)
Palanca De Control (S/P) / Control Lever (S/P)
Conductos Aceite (Succión) / Oil Piping (Suction)
Conductos Aceite (Suminis.) / Oil Piping (Delivery)
Conductos Aceite (Retorno) / Oil Piping (Return)
Cond. Aceite (Enf) / Oil Piping (Oil Cooler)
Cond. Aceite (Func. Izdo.) / Oil Piping (Operation Lh)
Cond. Aceite (Func. Dcho.) / Oil Piping (Operation Rh)
Cond. Aceite (Trasl. Izda.) / Oil Piping (Travel Lh)
Cond. Aceite (Trasl. Dcha.) / Oil Piping (Travel Rh)
Cond. Aceite (Rotación) / Oil Piping (Swivel)
Cond. Aceite (Oscilación) / Oil Piping (Swing)
Cond. Aceite (Brazo Pr.) / Oil Piping (Boom)
Conductos Aceite (Brazo) / Oil Piping (Arm)
Conductos Aceite (Cazo) / Oil Piping (Bucket)
Conductos Acaite (Hoja) / Oil Piping (Blade)
Conductos Acaite (Chasis) / Oil Piping (Track)
Conductos Acaite (Mordaza) / Oil Piping (Clamp)
Conductos Aceite (S/P) / Oil Piping (S/P)
Cilind. Brazo Prin. Y Comp. / Boom Cylinder And Component Parts
Cilindro Brazo Y Comp. / Arm Cylinder And Component Parts
Cilind. De Cazo Y Comp. / Bucket Cylinder And Component Parts
Cilind. Hoja Y Componentes / Blade Cylinder And Component Parts
Cil. Brazo Oscil. Y Comp. / Swing Cylinder And Component Parts
Cilindro Bastidor Y Comp. / Track Cylinder And Component Parts
Soporte Brazo De Oscilación / Swing Bracket
Brazo Principal / Boom
Brazo / Arm
Loeffelverbindungsstueck / Bucket Link
Cazo / Bucket
Hoja / Blade
Chasis Del Montacargas / Track Frame
Rodillo / Idler
Oruga, Rodillo Inferior / Crawler And Truck Roller
Bastidor De Rotación / Swivel Frame
Estructura De Arco / Arch Frame
Cojinete De Rotación / Swivel Bearing
Soporte Del Asiento [Marcotecho] / Seat Support [Canopy]
Soporte Del Asiento [Cabina] / Seat Support [Cabin]
Peldaño / Step
Cubierta (Lado Izdo.) / Cover (Lh)
Cubierta (Lado Dcho.) / Cover (Rh)
Capot / Bonnet (Front) [Canopy]
Capot / Bonnet (Front) [Cabin]
Capot (Lado Izdo.) / Bonnet (Lh)
Capot (Lado Dcho.) / Bonnet (Rh)
Capot (Posterior) / Bonnet (Rear)
Esponja (1) / Sponge (1)
Esponja (2) / Sponge (2)
Esponja (3) / Sponge (3)
Esponja (4) / Sponge (4)
Peso / Weight
Asiento / Seat
Marcotecho / Canopy
Cabina (Junta Caucho) / Cabin (Seal Rubber)
Cabina / Cabin (Body)
Cabina (Ventanilla 1) / Cabin (Window 1)
Cabina (Ventanilla 2) / Cabin (Window 2)
Cabina (Puerta) / Cabin (Door)
Cabina (Cableado Elétrico) / Cabin (Electrical Wiring)
Cabina (Accesorios 1) / Cabin (Accessories 1)
Cabina (Accesorios 2) / Cabin (Accessories 2)
Cabina (Calefacción) / Cabin(Heater)
Etiqueta / Label
Accesorios / Accessories
Vál.Antirot.Tubo/Pesc. / Pipe-Break Valve/Boom
Vál.Antirot.Tubo/Brazo / Pipe-Break Valve/Arm
Vál.Antirot.Tubo/Cuchil / Pipe-Break Valve/Dozer
Sistema De Aviso / Warning System
Juego Pedales / Kit Travel Pedal
Juego Protección Contra Caída Y Proyección De Piedras (Marcot / Kit Gravel Guard (Canopy)
Kit Parasassi (Cabina) / Kit Gravel Guard (Cabin)
Juego Preparación Radio (Cabina) / Kit Radio Accessory (Cabin)
Retromatic Cambio Rápido Serie02 / Retromatic Qc-Series02
Kit De Caja Negra / Kit Black Box
Juego De Mordazas / Clamshell Kit
Juego De Acoplamientos Rápidos / Kit Plug-In Coupler
Juego De Acoplamientos Planos / Kit Flat-Face Coupler
Juego De Acoplamientos Filetados / Kit Screw-Type Coupler
Soporte - Km105 / Mounting Brackets - Km105
Kit Martillo Hidráulico / Kit Hydraulic Breaker
Juego Cambio Rápido Hidráulico / Kit Quick Coupler Hydraulic
Cambio Rápido Hidráulico / Quick Coupler Hydraulic
