Kubota Excavator KX016-4 50001-69999 Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Excavator
Model: Kubota KX016-4 Excavator
Serial Number: 50001-69999
Number of Pages: 219 Pages
Content
Bkida5045 >> Kx016-4(S/N;50001-69999)
Art Icles Fréquemment Utilisés / Frequently Used Items
Pieces De Maintenance / Maintenance Parts
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Carter De Distribution / Gear Cas E
Couvre-Culasse / Head Cover
Console De Moteur / Engine Bracke T
Paliers De Principal / Main Beari Ng Case
Piston Et Vilebrequin / Piston An D Crankshaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carb. / Fuel Cam Shaft And Governor Shaft
Solenoide, Arrèt / Stop Solenoid
Pompe D'injection / Injection Pum P
Plaque De Limiteur De Vitesse / S Peed Control Plate
Injecteurs Et Bougies Prechauffag E / Nozzle Holder And Glow Plug
Porte-Inj. (Parties Comp.) / Nozz Le Holder (Component Parts)
Alternateur Complet / Alternator
Alternateur (Parties Comp.) / Alt Ernator (Component Parts)
Lanceur / Starter
Demarreur (Parties Comp.) / Start Er (Component Parts)
Bride A Eau Et Thermostat / Water Flange And Thermostat
Pompe A Eau / Water Pump
Radiateur / Radiator
Tuyau D'eau / Water Pipe
Collecteur D'admission / Inlet Ma Nifold
Collecteur D'echappement / Exhaus T Manifold
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints (1) / Gasket Kit (1 )
Jeu De Joints (2) / Gasket Kit (2 )
Levier D'accelera Teur / Accel Lever
Tuyautage De Carb Urant / Fuel Piping
Filtre A Carburan T (Parties Comp.) / Fuel Filter (Component Parts)
Séparateur D'eau (Parties Comp.) / Water Separator (Component Parts)
Reservoir Carb. / Fuel Tank
Batterie / Battery
Temporisa Teur, Avertisseur / Timer And Horn
Interrupt Eur, Metre / Switch And Meter
Lampe / L Ight
Lampe / L Ight
Lampe [Op Tion] / Light [Option]
Faisceau Electrique / Wire Harness
Pisto N, Pompe (Parties Comp.) / Piston Pump (Component P Arts)
Moteu R De Voyage (Parties Comp.) / Drive Motor And Compo Nent Parts
Moteu R De Bascule (Parties Comp.) / Swivel Motor And Com Ponent Parts
Joint Rotatif / Rotary Joint
Reser Voir D'huile / Oil Tank
Distributeu R Hydraulique / Control Valve
Sect (Flech E/Deport) / Section (Boom/Swing)
Section (Ch Enillette) / Section (Dozer)
Section (Os Cillation) / Section (Slew)
Section (Co Nfluence) / Section (Confluence)
Section (En Tretien) / Section (Service)
Section (Br As) / Section (Arm)
Section (De Plcmt, G) / Section (Travel,L)
Section (Ad Mission) / Section (Inlet)
Section (De Plcmt, D) / Section (Travel,R)
Section (Fl Eche) / Section (Boom)
Section (Go Det) / Section (Bucket)
Section (Ch Âssis) / Section (Track)
Soupape Dec Hargement / Unload Valve
Soupape Dec Hargement (Parties Comp.) / Unload Valve (Component Parts)
Levier De Comm Ande (Carde De Controle) / Control Lever (Frame)
Levier De Comm Ande (Levier Gauche) / Control Lever (Lever Lh)
Soupape De Pil Ote (Parties Comp.) G. / Pilot Valve (Component Par Ts) Lh
Levier De Comm Ande (Levier Droite) / Control Lever (Lever Rh)
Soupape De Pil Ote (Parties Comp.) Dr. / Pilot Valve (Component Pa Rts) Rh
Levier Decomma Nde (Deplacement) / Control Lever (Travel)
Levier Decomma Nde (Châssis) / Control Lever (Track)
Pedale Fleche Oscillation / Boom Swing Pedal
Levier De Comm Ende (Levier De Verrouillage) / Control Lever (Safe Ty Lock Lever)
Pedale De Comm Ande (Pivot/Change De Osc.) / Control Pedal (Swivel /Swing)
Levier De Comm Ande (Lame) / Control Lever (Blade)
Levier De Comm Ande (S/P) / Control Lever (S/P)
Tube (Succion) / Oil Piping (Suction)
Tube (Delivranc E) / Oil Piping (Delivery)
Tube (Retour) / Oil Piping (Return)
Tube (Refroidis Seur) / Oil Piping (Oil Cooler)
Tube (Operation G) / Oil Piping (Operation Lh)
Tube (Operation D) / Oil Piping (Operation Rh)
Tube (Deplaceme Nt Gauche) / Oil Piping (Travel Lh)
Tube (Deplacemu Nt Droite) / Oil Piping (Travel Rh)
Tube (Pivot) / Oil Piping (Swivel)
Tube (Balanceme Nt) / Oil Piping (Swing)
Tube (Flech) / Oil Piping (Boom)
Tube (Bras) / O Il Piping (Arm)
Tube (Godet) / Oil Piping (Bucket)
Tube (Lame) / O Il Piping (Blade)
Tube (Chenille) / Oil Piping (Track)
Tube (Attache) / Oil Piping (Clamp)
Tube (S/P) / Oi L Piping (S/P)
Fleche Cylindre (Parties Comp .) / Boom Cylinder And Component Parts
Bras Cylindre (Parties Comp.) / Arm Cylinder And Component Parts
Lame Cylindre (Parties Comp.) / Blade Cylinder And Component Parts
Balancement Cylindre (Parties Comp.) / Swing Cylinder And Component Parts
Châssis Cylindre (Parties Com P.) / Track Cylinder And Component Parts
Support Bal Ancement / Swing Bracket
Fleche / Bo Om
Bras / Arm
Maillon De Godet / Bucket Link
Godet / Buc Ket
Lame / Blad E
Cadre De Piste / Track Frame
Intermediaire / I Dler
Chenille Et Galet De Chenille / Crawler And Truck Roller
Chassis Pivot / Swiv El Frame
Chassis De Capote / Arch Frame
Roulement De Bascule / Swivel Bearing
Support De Siege / S Eat Support [Canopy]
Support De Siege / S Eat Support [Cabin]
Marche / Step
Couverc Le (Gauche) / Cover (Lh)
Couverc Le (Droite) / Cover (Rh)
Capot ( Avant) / Bonnet (Front) [Cabin]
Capot ( Gauche) / Bonnet (Lh)
Capot ( Droite) / Bonnet (Rh)
Capot ( Arriere) / Bonnet (Rear)
Eponge (1) / Sponge (1)
Eponge (2) / Sponge (2)
Eponge (3) / Sponge (3)
Eponge (4) / Sponge (4)
Contrep Oids / Weight
Siege / Seat
Auvent / Canopy
Cabine (Joint En Ca Outchouc) / Cabin (Seal Rubber)
Cabine / Cabin (Bod Y)
Cabine (Glace 1) / Cabin (Window 1)
Cabine (Glace 2) / Cabin (Window 2)
Cabine (Porte) / Ca Bin (Door)
Cabine (Faisceau De Cables) / Cabin (Electrical Wiring)
Cabin (Accessoires 1) / Cabin (Accessories 1)
Cabin (Accessoires 2) / Cabin (Accessories 2)
Cabine (Chauffage) / Cabin(Heater)
Etiquette / Label
Etiquette / Label
Accessoires / Accessori Es
Clapet D'ar.Aut./Fleche / Pipe-Br Eak Valve/Boom
Clapet D'ar.Aut./Bras / Pipe-Brea K Valve/Arm
Clapet D'ar.Aut./Lame / Pipe-Brea K Valve/Dozer
Kit Pédales / Kit Travel Pedal
Kit Protection Contre La Chute De Pierres (Auvent) / Kit Gravel Guard (Canopy)
Kit Protection Contre La Chute De Pierres (Cabine) / Kit Gravel Guard (Cabin)
Kit Preparation Radio (Cabine) / Kit Radio Accessory (Cabin)
Godet, Coupleur / Bucket, Quick-C Oupler
Retromatic Attache Rapide Série02 / Retromatic Qc-Series02
Palier - Km105 / Mounting Bracket S - Km105
Kit Marteau Hydraulique / Kit Hyd Raulic Breaker
Kit Boîte Noire / Kit Black Box
Kit Grappin / Clamshell Kit
Kit D'accouplements Rapides / Kit Plug-In Coupler
Kit D'accouplements A Face Plane / Kit Flat-Face Coupler
Kit D'accouplements Filetés / Kit Screw-Type Coupler
Kit Attache Rapide Hydraulique / Kit Quick Coupler Hydraulic
Attache Rapide Hydraulique / Quic K Coupler Hydraulic
