Kubota Excavator KX016-4 50001-69999 Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Excavator
Model: Kubota KX016-4 Excavator
Serial Number: 50001-69999
Number of Pages: 363 Pages
Artículos Utilizados Frecuentemente / Maintenance Parts
Bloque Motor / Crankcase
Carter / Oil Pan
Cilindro Ppal / Cylinder Head
Caja De Cambio / Gear Case
Arbol De Levas / Head Cover
Cilindro Ppal / Engine Bracket
Caja De Cambios Ppal / Main Bearing Case
Tapa De Balancines / Camshaft And Idle Gear Shaft
Piston Y Ciguenal / Piston And Crankshaft
Volante / Flywheel
Aire Limpiador / Fuel Camshaft And Governor Shaft
Silenciador / Stop Solenoid
Regulador / Nozzle Holder (Component Parts)
Alternador / Alternator
Bomba De Inyeccion [Componentes] / Alternator (Component Parts)
Motor De Arranque / Starter
Palanca Del Acelerador / Starter (Component Parts)
Termostatoy Tapa / Water Flange And Thermostat
Bomba Agua / Water Pump
Manguitoagua / Water Pipe
Valvulas Y Balancines / Valve And Rocker Arm
Manguito Agua / Exhaust Manifold
Filtro De Aire / Air Cleaner
Silenciador / Muffler
Dichtungen (1) / Gasket Kit (1)
Dichtungen (2) / Gasket Kit (2)
Bateria / Accel Lever
Temporizador Y Claxon / Fuel Piping
Conmutador Y Metro / Fuel Filter (Component Parts)
Luz 1[Tipo Arco] / Water Separator (Component Parts)
Hidraulico Bomba / Timer And Horn
Bomba Hidraulica / Switch And Meter
Accionar Motor / Light
Girar Motor / Light [Option]
Rotativo Junta / Wire Harness
Aceite Deposito(Placa) / Wire Harness
Distribuidor / Piston Pump (Component Parts)
Control Valvula [Componente Piezas] / Drive Motor And Component Parts
Girar Motor / Swivel Motor And Component Parts
Corredera Seccion (Cubo) / Rotary Joint
Corredera Seccion(Recorrido Derecho) / Oil Tank
Distribuidor / Control Valve
Corredera Seccion(Recorrido) / Section (Boom/Swing)
Corredera Seccion(Recorrido) / Section (Dozer)
Corredera Seccion(Recorrido) / Section (Slew)
Corredera Seccion(Recorrido) / Section (Confluence)
Corredera Seccion(Recorrido) / Section (Service)
Corredera Seccion(Recorrido) / Section (Arm)
Corredera Seccion(Recorrido) / Section (Travel,L)
Corredera Seccion(Recorrido) / Section (Inlet)
Corredera Seccion(Recorrido) / Section (Travel,R)
Corredera Seccion(Recorrido) / Section (Boom)
Corredera Seccion(Recorrido) / Section (Bucket)
Corredera Seccion(Recorrido) / Section (Track)
Corredera Seccion (Servicio Piezas) / Unload Valve
Corredera Seccion(Recorrido Izquierdo) / Unload Valve (Component Parts)
Corredera Seccion (Brazo) / Control Lever (Frame)
Corredera Seccion (Entrada) / Control Lever (Lever Lh)
Corredera Seccion (Oscilacion) / Pilot Valve (Component Parts) Lh
Corredera Seccion (Lamina) / Control Lever (Lever Rh)
Corredera Seccion (Girar) / Pilot Valve (Component Parts) Rh
Cambio Valvula / Control Lever (Travel)
Cambio Valvula(Componente Piezas) / Control Lever (Track)
Aguilon Oscilacion Pedal / Boom Swing Pedal
Cierre Con Llave La Palanca / Control Lever (Safety Lock Lever)
Control Pedal(Girar/Oscilacion Cambio) / Control Pedal (Swivel/Swing)
Control Palanca(Lamina) / Control Lever (Blade)
Control Palanca(Servicio Piezas) / Control Lever (S/P)
Aceite Tubos(Asupiracion) / Oil Piping (Suction)
Aceite Tubos (Entrega) / Oil Piping (Delivery)
Aceite Tubos (Devolver) / Oil Piping (Return)
Aceite Tubos (Aceite Refrigerador) / Oil Piping (Oil Cooler)
Aceite Tubos (Control Izquierdo) / Oil Piping (Operation Lh)
Aceite Tubos (Control Derecho) / Oil Piping (Operation Rh)
Aceite Tubos (Recorrido Izquierdo) / Oil Piping (Travel Lh)
Aceite Tubos (Recorrido Derecho) / Oil Piping (Travel Rh)
Aceite Tubos (Girar) / Oil Piping (Swivel)
Aceite Tubos (Oscilacion) / Oil Piping (Swing)
Aceite Tubos (Aguilon) / Oil Piping (Boom)
Aceite Tubos (Brazo) / Oil Piping (Arm)
Aceite Tubos (Cubo) / Oil Piping (Bucket)
Aceite Tubos (Lamina) / Oil Piping (Blade)
Aceite Tubos(Tren De Orugas)[Galga Variable] / Oil Piping (Track)
Aceite Tubos (Abrazadera) / Oil Piping (Clamp)
Aceite Tubos(Servicio Piezas 1) / Oil Piping (S/P)
Aguilon Cilindro / Boom Cylinder And Component Parts
Brazo Cilindro / Arm Cylinder And Component Parts
Cubo Cilindro / Bucket Cylinder And Component Parts
Lamina Cilindro / Blade Cylinder And Component Parts
Oscilacion Cilindro / Swing Cylinder And Component Parts
Tren De Orugas Cilindro Y Componente Pie[Galga Variable] / Track Cylinder And Component Parts
Oscilacion Soporte / Swing Bracket
Aguilon / Boom
Brazo / Arm
Cubo Vinculo / Bucket Link
Cubo / Bucket
Lamina / Blade
Tren De Orugas Bastidor / Track Frame
Aguilon Cilindro / Idler
Brazo Cilindro / Crawler And Truck Roller
Cubo Cilindro / Swivel Frame
Lamina Cilindro / Arch Frame
Oscilacion Cilindro / Swivel Bearing
Oscilacion Soporte / Seat Support [Canopy]
Aguilon / Seat Support [Cabin]
Cilindro Cubierta (Aguilon) / Step
Brazo / Cover (Lh)
Cubo Vinculo / Cover (Rh)
Cubo / Bonnet (Front) [Canopy]
Lamina / Bonnet (Front) [Cabin]
Tren De Orugas Bastidor / Bonnet (Lh)
Rueda,Rueda Loca / Bonnet (Rh)
Capo (Trasero) / Bonnet (Rear)
Oruga / Sponge (1)
Girar Bastidor / Sponge (2)
Arco Bastidor / Sponge (3)
Girar Rodamiento / Sponge (4)
Peldano / Weight
Asiento / Seat
Capo / Canopy
Cabina (Reten Caucho) / Cabin (Seal Rubber)
Cabina(Carroceria) / Cabin (Body)
Peso / Cabin (Window 1)
Asiento / Cabin (Window 2)
Techo De Lona / Cabin (Door)
Etiqueta / Cabin (Electrical Wiring)
Accesorios / Cabin (Accessories 1)
Accesorios / Cabin (Accessories 2)
Oruga / Sponge (1)
Cabina(Calentador) / Cabin(Heater)
Etiqueta / Label
Accesorios / Accessories
Accesorios Y Servicio Piezas / Pipe-Break Valve/Boom
Accesorios Y Servicio Piezas / Pipe-Break Valve/Arm
Accesorios Y Servicio Piezas / Pipe-Break Valve/Dozer
Accesorios Y Servicio Piezas / Kit Travel Pedal
Accesorios Y Servicio Piezas / Kit Gravel Guard (Canopy)
Accesorios Y Servicio Piezas / Kit Gravel Guard (Cabin)
Juego Preparación Radio (Cabina) / Kit Radio Accessory (Cabin)
Accesorios Y Servicio Piezas / Bucket, Quick-Coupler
Accesorios Y Servicio Piezas / Retromatic Qc-Series02
Soporte - Km105 / Mounting Brackets - Km105
Accesorios Y Servicio Piezas / Kit Hydraulic Breaker
Kit De Caja Negra / Kit Black Box
Accesorios Y Servicio Piezas / Clamshell Kit
Accesorios Y Servicio Piezas / Kit Plug-In Coupler
Accesorios Y Servicio Piezas / Kit Flat-Face Coupler
Accesorios Y Servicio Piezas / Kit Screw-Type Coupler
Juego Cambio Rápido Hidráulico / Kit Quick Coupler Hydraulic
Cambio Rápido Hidráulico / Quick Coupler Hydraulic
Carter / Oil Pan
Volante / Flywheel
Aguilon / Boom
Brazo / Arm
Cubo / Bucket
Lamina / Blade
Brazo / Cover (Lh)
Oruga / Sponge (1)
Peldano / Weight
Asiento / Seat
Capo / Canopy
Oruga / Sponge (1)
Etiqueta / Label
