Kubota Excavator KX015-4 70001- Spare Parts Catalog EN FR
Language: French, English
Type of Machine: Excavator
Model: Kubota KX015-4 Excavator
Serial Number: 70001-
Number of Pages: 210 Pages
Content
Bkida5187 >> Kx015-4(S/N;70001-)
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Culasse / Cylinder Head
Couvre-Culasse / Head Cover
Console De Moteur / Engine Bracket
Paliers De Principal / Main Bearing Ca Se
Piston Et Vilebrequin / Piston And Cra Nkshaft
Volant Du Moteur / Flywheel
Arbre A Cames De Carb. / Fuel Camshaft And Governor Shaft
Solenoide, Arrèt / Stop Solenoid
Plaque De Vitesse-Controle / Speed Con Trol Plate
Injecteurs Et Bougies Prechauffage / N Ozzle Holder And Glow Plug
Porte-Inj. (Parties Comp.) / Nozzle Ho Lder (Component Parts)
Alternateur / Alternator
Alternateur (Parties Comp.) / Alternat Or (Component Parts)
Demarreur / Starter
Demarreur (Parties Comp.) / Starter (C Omponent Parts)
Bride A Eau Et Thermostat / Water Flan Ge And Thermostat
Pompe A Eau / Water Pump
Radiateur / Radiator
Tuyau D'eau / Water Pipe
Soupapes Culbuteurs / Valve And Rocke R Arm
Collecteur D'admission / Inlet Manifol D
Collecteur D'echappement / Exhaust Man Ifold
Filter A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joints (1) / Gasket Kit (1)
Jeu De Joints (2) / Gasket Kit (2)
Levier D'accelerateur / Accel Lever
Tuyautage De Carburant / Fuel Piping
Filtre A Carburant (Pa Rties Comp.) / Fuel Filter (Component Parts)
Séparateur D'eau (Part Ies Comp.) / Separator (Component Parts)
Reservoir Carb. / Fuel Tank
Batterie / Bat Tery
Temporisateur Avertisseur / Timer And Horn
Interrupteur M Etre / Switch And Meter
Lampe / Light
Lampe [Option] / Light [Option]
Faisceau Elect Rique / Wire Harness
Piston Pom Pe (Parties Comp.) / Piston Pump (Component Parts)
Moteur De Voyage (Parties Comp.) / Drive Motor And Component Parts
Joint Rota Tif / Rotary Joint
Reservoir D'huile / Oil Tank
Soupape De Contr Ole / Control Valve
Section (Fleche/ Deport) / Section (Boom/Swing)
Section (Chenill Ette) / Section (Dozer)
Section (Oscilla Tion) / Section (Slew)
Section (Conflue Nce) / Section (Confluence)
Section (Entreti En) / Section (Service)
Section (Bras) / Section (Arm)
Section (Deplcmt G) / Section (Travel L)
Section (Admissi On) / Section (Inlet)
Section (Deplcmt D) / Section (Travel R)
Section (Fleche) / Section (Boom)
Section (Godet) / Section (Bucket)
Soupape Decharge Ment / Unload Valve
Section De Tiroi R (Deplacement Gauche) / Unload Valve (Component Pa Rts)
Levier De Commande (Carde De Controle) / Control Lever (Frame)
Levier De Commande (Levier Gauche) / Control Lever (Lever Lh)
Soupape De Pilote ( Parties Comp.) G. / Pilot Valve (Component Parts) L H
Levier De Commande (Levier Droite) / Control Lever (Lever Rh)
Soupape De Pilote ( Parties Comp.) Dr. / Pilot Valve (Component Parts) Rh
Levier Decommande ( Deplacement) / Control Lever (Travel)
Pedale Fleche Oscil Lation / Boom Swing Pedal
Levier De Commende (Levier De Verrouillage) / Control Lever (Safety Lo Ck Lever)
Pedale De Commande (Pivot/Change De Osc.) / Control Pedal (Swivel/Swin G)
Levier De Commande (Lame) / Control Lever (Blade)
Levier De Commande (S/P) / Control Lever (S/P)
Tube (Succion) / Oil Piping (Suction)
Tube (Delivrance) / Oil Piping (Delivery)
Tube (Retour) / Oil Piping (Return)
Tube (Refroidisseur) / Oil Piping (Oil Cooler)
Tube (Operation G) / Oil Piping (Operation Lh)
Tube (Operation D) / Oil Piping (Operation Rh)
Tube (Deplacement Ga Uche) / Oil Piping (Travel Lh)
Tube (Deplacemunt Dr Oite) / Oil Piping (Travel Rh)
Tube (Balancement) / Oil Piping (Swing)
Tube (Flech) / Oil P Iping (Boom)
Tube (Bras) / Oil Pi Ping (Arm)
Tube (Godet) / Oil P Iping (Bucket)
Tube (Lame) / Oil Pi Ping (Blade)
Tube (Attache) / Oil Piping (Clamp)
Tube (S/P) / Oil Pip Ing (S/P)
Fleche Cylindre (Parties Comp. ) / Boom Cylinder And Component Parts
Bras Cylindre (Parties Comp.) / Arm Cylinder And Component Parts
Godet Cylindre (Parties Comp.) / Bucket Cylinder And Component Parts
Lame Cylindre (Parties Comp.) / Blade Cylinder And Component Parts
Balancement Cylindre (Parties Comp.) / Swing Cylinder And Component Parts
Support Balancem Ent / Swing Bracket
Fleche / Boom
Bras / Arm
Maillon De Godet / Bucket Link
Godet / Bucket
Lame / Blade
Cadre De Piste / Track Frame
Intermediaire / Idler
Chenille Et Galet De C Henille / Crawler And Truck Roller
Chassis Pivot / Swivel Fr Ame
Chassis De Capote / Arch Frame
Roulement De Bascule / Sw Ivel Bearing
Support De Siege [Auvent] / Seat Support [Canopy]
Support De Siege [Cabine] / Seat Support [Cabin]
Marche / Step
Couvercle (G Auche) / Cover (Lh)
Couvercle (D Roite) / Cover (Rh)
Capot (Avant ) [Auvent] / Bonnet (Front) [Canopy]
Capot (Avant ) [Cabine] / Bonnet (Front) [Cabin]
Capot (Gauch E) / Bonnet (Lh)
Capot (Droit E) / Bonnet (Rh)
Capot (Arrie Re) / Bonnet (Rear)
Eponge (1) / Sponge 1
Eponge (2) / Sponge 2
Eponge (3) / Sponge 3
Eponge (4) / Sponge 4
Contrepoids / Weight
Siege / Seat
Auvent / Canopy
Cabine (Joint En Caoutch Ouc) / Cabin (Seal Rubber)
Cabine (Corps) / Cabin ( Body)
Cabine (Glace 1) / Cabin (Window 1)
Cabine (Glace 2) / Cabin (Window 2)
Cabine (Porte) / Cabin ( Door)
Cabine (Faisceau De Cabl Es) / Cabin (Electrical Wiring)
Cabin (Accessoires 1) / Cabin (Accessories 1)
Cabin (Accessoires 2) / Cabin (Accessories 2)
Etiquette / Label
Etiquette / Label
Accessoires 1 / Accessories 1
Accessoires 2 / Accessories 2
Clapet D'ar.Aut./Fleche / Pipe-Break V Alve/Boom
Clapet D'ar.Aut./Bras / Pipe-Break Val Ve/Arm
Clapet D'ar.Aut./Lame / Pipe-Break Val Ve/Dozer
Kit Pédales / Kit Travel Pedal
Kit Protection Contre La Chute De Pier Res (Auvent) / Kit Gravel Guard (Canopy)
Kit Protection Contre La Chute De Pier Res (Cabine) / Kit Gravel Guard (Cabin)
Kit Preparation Radio (Cabine) / Kit R Adio Accessory (Cabin)
Godet Coupleur / Bucket Quick-Coupler
Retromatic Attache Rapide Série02 / Re Tromatic Qc-Series02
Godet, Coupleur / Bucket Quick-Coupler
Godet, Coupleur / Bucket, Quick-Couple R
Palier - Km105 / Mounting Brackets - K M105
Kit Marteau Hydraulique / Kit Hydrauli C Breaker
Kit Boîte Noire / Kit Black Box
