Kubota Excavator K008-3 Parts Catalog EN DE
Language: German, English
Region: Germany, England
Type of Machine: Excavator
Model: Kubota K008-3 Excavator
Number of Pages: 428 Pages
K008-3 (S N0503-28951)
N0503-28951) Frequently Used Items Frequently Used Items Häufig Verwendete Elemente
000100 Kurbelghaeuse Crankcase ## Note Order By Part No.16899-0101-9 And Ref.No.130(15231-3396-0)Set Note
K008-3 (S N0503-28951) Motor Engine Oelwanne Oil Pan
(S N0503-28951) Motor Engine Zylinderkopf Cylinder Head ## [D722-Bh-3 S.No.; =5z9999] [D722-
Engine Zylinderkopf Cylinder Head ## [D722-E2-Bh-5 S.No.; =6a0001] [D722-E2-Bh-5 S.No.; =6a0001]
Motor Engine Getriebe Gehaeuse Gear Case ## [D722-E2-Bh-5 S.No.; =8zz999] [D722-
N0503-28951) Motor Engine Getriebe Gehaeuse Gear Case ## [D722-E3-Bh-5 S.No.; =9a0001] [D722-
(S N0503-28951) Motor Engine Ventildeckel Head Cover ## [D722-Bh-3 S.No.; =5z9999] [D722-
S N0503-28951) Motor Engine Ventildeckel Head Cover ## [D722-E2-Bh-5 S.No.; =6a0001] [D722-
K008-3 (S N0503-28951) Motor Engine Motor Traeger Engine Bracket
Engine Hauptlagergehaeuse Main Bearing Case ## Achtung Bestellen Sie Bitte Pos.015 Neue
K008-3 (S N0503-28951) Motor Engine Nockenwelle Und Freilaufgetriebewelle Camshaft And
K008-3 (S N0503-28951) Motor Engine Abstuetzung Rechts Vorne Piston And Crankshaft
K008-3 (S N0503-28951) Motor Engine Schwungrad Flywheel
K008-3 (S N0503-28951) Motor Engine Kraftstoff-Nockenwelle Und Achse Fuel Camshaft And
K008-3 (S N0503-28951) Motor Engine Abstellhubmagnet Stop Solenoid
K008-3 (S N0503-28951) Motor Engine Einspritzpumpe Injection Pump
(S N0503-28951) Motor Engine Regler Governor ## S.Nr. =4jtz999 S.No.; =4jtz999 S.No. =4jtz999
(S N0503-28951) Motor Engine Regler Governor ## S.Nr. =4ju0001 S.No.; =4ju0001 S.No. =4ju0001
K008-3 (S N0503-28951) Motor Engine Geschwindigkeitskontroll Platte Speed Control
Gluehkerze Nozzle Holder And Glow Plug ## S.Nr. =9hz999 Note Order By Fig.No. Ref.No.060 & 065 New
Motor Engine Duesenhalter Und Gluehkerze Nozzle Holder And Glow Plug ## S.Nr. =9j0001 S.
Einzel-Teil) Nozzle Holder (Component Parts) ## S.Nr. =9hz999 Note Order By Fig.No. Ref.No.060 & 065 New
020702 Duesenhalter (Einzel-Teil) Nozzle Holder (Component Parts) ## S.Nr. =9j0001 To Adz999 S.No.; =9j0001
Motor Engine Duesenhalter (Einzel-Teil) Nozzle Holder (Component Parts) ## S.Nr. =Ae0001 S.
K008-3 (S N0503-28951) Motor Engine Ventilator, Dynamo Fan And Dynamo
K008-3 (S N0503-28951) Motor Engine Dynamo (Einzel-Teil) Dynamo (Component Parts)
K008-3 (S N0503-28951) Motor Engine Anlasser Starter
K008-3 (S N0503-28951) Motor Engine Anlasser (Einzel-Teil) Starter (Component Parts)
K008-3 (S N0503-28951) Motor Engine Wasserflansch Und Thermostat Water Flange And
K008-3 (S N0503-28951) Motor Engine Wasserpumpe Water Pump
K008-3 (S N0503-28951) Motor Engine Kuehler Radiator
K008-3 (S N0503-28951) Motor Engine Wasserrohr Water Pipe
Motor Engine Ventile Und Kipphebel Valve And Rocker Arm ## [D722-Bh-3 S.No.; =5z9999]
Motor Engine Ventile Und Kipphebel Valve And Rocker Arm ## [D722-E2-Bh-5 S.No.; =6a0001]
K008-3 (S N0503-28951) Motor Engine Einlasskruemmer Inlet Manifold
K008-3 (S N0503-28951) Motor Engine Auslasskruemmer Exhaust Manifold
K008-3 (S N0503-28951) Motor Engine Luftfilter Air Cleaner
K008-3 (S N0503-28951) Motor Engine Auspufftopf Muffler
Motor Engine Oberdichtung Installationssatz Upper Gasket Kit ## [D722-Bh-3 S.No.; =
Motor Engine Oberdichtung Installationssatz Upper Gasket Kit ## [D722-E2-Bh-5 S.No.; =
Motor Engine Unterdichtung Installationssatz Lower Gasket Kit ## S.Nr. =4a0001 S.No.; =
K008-3 (S N0503-28951) Brennstoff System Fuel System Beschleunigerhebel Accelerator
K008-3 (S N0503-28951) Brennstoff System Fuel System Kraftstoffleitungen Fuel
Brennstoff System Fuel System Kraftstoffilter (Einzel-Teil) Fuel Filter (Component Parts) ## S.
K008-3 (S N0503-28951) Brennstoff System Fuel System Kraftstofftank Fuel Tank
K008-3 (S N0503-28951) Elektrisch System Electrical System Batterie Battery
K008-3 (S N0503-28951) Elektrisch System Electrical System Relais Und Hupe Relay And
K008-3 (S N0503-28951) Elektrisch System Electrical System Schalter, Zaehler Switch
K008-3 (S N0503-28951) Elektrisch System Electrical System Lampe Light
K008-3 (S N0503-28951) Elektrisch System Electrical System Elektrische Ausruestung
K008-3 (S N0503-28951) Pumpe Motor System Pump Motor System Pumpengehaeuse Pump
N0503-28951) Pumpe Motor System Pump Motor System Getriebepumpe (Einzel-Teil) Gear
Pumpe Motor System Pump Motor System Fahrmotor Und Einzel-Teile Drive Motor
System Pump Motor System Schwingungmotor Und Einzel-Teil Swivel Motor And Component
K008-3 (S N0503-28951) Pumpe Motor System Pump Motor System Drehgelenkstueck Rotary
K008-3 (S N0503-28951) Pumpe Motor System Pump Motor System Oeltank Oil Tank
K008-3 (S N0503-28951) Regelungsventil Control Valve Regelungsventil Control
S N0503-28951) Regelungsventil Control Valve Regelungsventil (Einzel-Teil) Control Valve
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Drehen) Spool Section
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Arm) Spool Section
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Fahren Ls) Spool Section
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Planierschild) Spool
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (S P) Spool Section
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Fahren Rs) Spool Section
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Schwung) Spool
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Kuebel) Spool Section
K008-3 (S N0503-28951) Regelungsventil Control Valve Spulensektion (Ausleger) Spool
K008-3 (S N0503-28951) Regelungsventil Control Valve Aenderungventil Change
(S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Rahmen, Kontroll) Control
K008-3 (S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Hebel Ls) Control
K008-3 (S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Hebel Rs) Control
K008-3 (S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Fahren Ls) Control
K008-3 (S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Fahren Rs) Control
(S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Drehen Arm) Control
S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Ausleger Kuebel) Control
Control Lever Kontrollhebel (Hebel Von Schloss) Control Lever (Safety Lock Lever)
K008-3 (S N0503-28951) Kontrollrahmen Control Lever Kontrollpedal (Schwung) Control
K008-3 (S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (Planierschild) Control
K008-3 (S N0503-28951) Kontrollrahmen Control Lever Kontrollhebel (S P) Control Lever
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Ansaugen) Oil Piping (
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Rueckstorm) Oil Piping (
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Fahren Ls) Oil Piping (Travel
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Fahren Rs) Oil Piping (Travel
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Drehen) Oil Piping (Swivel)
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Schwung) Oil Piping (Swing)
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Ausleger) Oil Piping (Boom)
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Arm) Oil Piping (Arm)
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Kuebel) Oil Piping (Bucket)
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Planierschild) Oil Piping (
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (Spur) Oil Piping (Track)
K008-3 (S N0503-28951) Oelleitungen Oil Piping Oel Leitung (S P) Oil Piping (S P)
(S N0503-28951) Zylinder Cylinder Auslegerzylinder Und Einzel-Teil Boom Cylinder And
K008-3 (S N0503-28951) Zylinder Cylinder Arm Zylinder Und Einzel-Teil Arm Cylinder And
(S N0503-28951) Zylinder Cylinder Kuebel Zylinder Und Einzel-Teil Bucket Cylinder And
(S N0503-28951) Zylinder Cylinder Planierschild Zylinder Und Einzel-Teil Blade Cylinder And
(S N0503-28951) Zylinder Cylinder Schwenkzylinder Und Einzel-Teil Swing Cylinder And
K008-3 (S N0503-28951) Zylinder Cylinder Spur Zylinder Und Einzel-Teil Track Cylinder And
K008-3 (S N0503-28951) Frontanbau Komponeten Front Attachments Schwenkblock Swing
K008-3 (S N0503-28951) Frontanbau Komponeten Front Attachments Ausleger Boom
K008-3 (S N0503-28951) Frontanbau Komponeten Front Attachments Arm Arm
K008-3 (S N0503-28951) Frontanbau Komponeten Front Attachments Loeffelverbindungsstueck
K008-3 (S N0503-28951) Frontanbau Komponeten Front Attachments Loeffel Bucket
K008-3 (S N0503-28951) Frontanbau Komponeten Front Attachments Planierschild
Frame Spurrahmen Track Frame ## Note Order By Ref.No.020,030,090 New Parts & Ref.No.210,220
K008-3 (S N0503-28951) Spurrahmen Track Frame Spannrad Idler
K008-3 (S N0503-28951) Spurrahmen Track Frame Laufrollen Track Roller
K008-3 (S N0503-28951) Rahmen Von Drehen Swivel Frame Rahmen Von Drehen Swivel
K008-3 (S N0503-28951) Rahmen Von Drehen Swivel Frame Schwing Antriebszahnrad-Gehaeuse
K008-3 (S N0503-28951) Rahmen Von Drehen Swivel Frame Drehkranz Swivel Bearing
K008-3 (S N0503-28951) Rahmen Von Drehen Swivel Frame Tritt Step ## [Except Rops] [Except
K008-3 (S N0503-28951) Rahmen Von Drehen Swivel Frame Tritt Step ## [Rops] [Rops]
Aubere Bauteile Polsterung External Upholstery Deckel (Vorne) Cover (Front) ##
S N0503-28951) Aubere Bauteile Polsterung External Upholstery Deckel (Vorne) Cover (
K008-3 (S N0503-28951) Aubere Bauteile Polsterung External Upholstery Motorhaube
K008-3 (S N0503-28951) Aubere Bauteile Polsterung External Upholstery Schaumgummi
S N0503-28951) Aubere Bauteile Polsterung External Upholstery Gewicht Weight ## [Except
K008-3 (S N0503-28951) Aubere Bauteile Polsterung External Upholstery Gewicht Weight ##
K008-3 (S N0503-28951) Aubere Bauteile Polsterung External Upholstery Sitz Seat
K008-3 (S N0503-28951) Kabinenhaube Canopy Kabinenhaube Canopy
K008-3 (S N0503-28951) Aufkleber Labels Aufkleber Label
K008-3 (S N0503-28951) Zubehoer Accessories Zubehoer Accessories
K008-3 (S N0503-28951) Option Option Kit Steckkupplung Kit Plug-In Coupler
K008-3 (S N0503-28951) Option Option Loeffel (Ohne Schnellkupplung) (Ke) Bucket (No Quick-
K008-3 (S N0503-28951) Option Option Kit-Wege-Zusatzkreis Kit Sp-Way
K008-3 (S N0503-28951) Option Option Kit Cat-Rental Kit Cat-Rental
K008-3 (S N0503-28951) Option Option Retromatic Schnellwechsler Serie01(Ke) Retromatic
K008-3 (S N0503-28951) Option Option Löffel, Schnellkupplung Bucket, Quick-Coupler
K008-3 (S N0503-28951) Option Option Löffel, Schnellkupplung(Kbd) Bucket, Quick-
K008-3 (S N0503-28951) Option Option Kit Hydraulikhammer Kit Hydraulic Breaker
K008-3 (S N0503-28951) Option Option Kit Black Box Kit Black Box
K008-3 (S N0503-28951) Option Option Kit Kabel Rundumleuchte Kit Cable Beacon Light
K008-3 (S N0503-28951) Option Option Anbauplatten - Km55 Mounting Brackets - Km55
- Kubota KX91-3 Parts Manual
- Kubota KX61-2 parts manual
