702,019
Kubota Excavator K008-3 K008-3KTA Australia Parts Catalog
Type of Machine: Excavator
Model: Kubota K008-3 K008-3KTA Excavator
Region: Australia
Number of Pages: 348 Pages
Frequently Used Items _ 000001 Frequently Used Items
Engine _ 000100 Crank Case ## Note_Order By Part No.16899-0101-9 And Ref.No
Engine _ 000200 Oil Pan
Engine _ 000300 Cylinder Head ## [D722-EBH-3_S.No.;_=4z9999]
Engine _ 000301 Cylinder Head ## [D722-E2-BH-3_S.No.;_=5a0001] Note_Order By Ref.No
Engine _ 000400 Gear Case ## S.No._=8zz999 S.No.;_=8zz999
Engine _ 000401 Gear Case ## S.No._=9a0001 S.No.;_=9a0001
Engine _ 000500 Head Cover ## [D722-EBH-3_S.No.;_=4z9999]
Engine _ 000501 Head Cover ## [D722-E2-BH-3_S.No.;_=5a0001]
Engine _ 003000 Engine Bracket
Engine _ 010000 Main Bearing Case ## Note_Order By Ref.No.015 New Part
Engine _ 010100 Camshaft And Idle Gear Shaft
Engine _ 010200 Piston And Crankshaft
Engine _ 010300 Flywheel
Engine _ 010500 Fuel Camshaft And Governor Shaft
Engine _ 020100 Stop Solenoid
Engine _ 020200 Injection Pump
Engine _ 020400 Governor ## S.No._=4jkz999 S.No.;_=4jkz999
Engine _ 020401 Governor ## S.No._=4jl0001 S.No.;_=4jl0001
Engine _ 020500 Speed Control Plate
Engine _ 020600 Nozzle Holder And Glow Plug ## S.No._=9hz999 Note_Order By Fig.No.020601 Ref
Engine _ 020601 Nozzle Holder And Glow Plug ## S.No._=9j0001 S.No.;_=9j0001
Engine _ 020700 Nozzle Holder (Component Parts) ## S.No._=9hz999 Note_Order By Fig.No
Engine _ 020701 Nozzle Holder (Component Parts) ## S.No._=9j0001 To Adz999 S.No
Engine _ 020702 Nozzle Holder (Component Parts) ## S.No._=Ae0001 S.No.;_=Ae0001
Engine _ 041000 Fan And Dynamo
Engine _ 041100 Dynamo (Component Parts)
Engine _ 041600 Starter
Engine _ 041700 Starter (Component Parts)
Engine _ 050000 Water Flange And Thermostat
Engine _ 050100 Water Pump
Engine _ 051100 Radiator
Engine _ 051300 Water Pipe
Engine _ 060000 Valve And Rocker Arm ## [D722-EBH-3_S.No.;_=4z9999]
Engine _ 060001 Valve And Rocker Arm ## [D722-E2-BH-3_S.No.;_=5a0001]
Engine _ 061000 Inlet Manifold ## [D722-EBH-3_S.No.;_=4z9999]
Engine _ 061001 Inlet Manifold ## [D722-E2-BH-3_S.No.;_=5a0001]
Engine _ 061200 Exhaust Manifold
Engine _ 061400 Air Cleaner
Engine _ 061600 Muffler
Engine _ 090100 Upper Gasket Kit [Option] ## S.No._=4a0001 S.No.;_=4a0001
Engine _ 090200 Lower Gasket Kit [Option] ## S.No._=4a0001 S.No.;_=4a0001
Fuel System _ A20000 Accel Lever
Fuel System _ A30000 Fuel Piping
Fuel System _ A30100 Fuel Filter (Component Parts) ## S.No._=20063 S.No.;_=20063
Fuel System _ A30101 Fuel Filter (Component Parts) ## S.No._=20064 S.No.;_=20064
Fuel System _ A30300 Fuel Tank
Electrical System _ B40000 Battery
Electrical System _ B40200 Timer And Horn
Electrical System _ B40400 Switch And Meter
Electrical System _ B40600 Light
Electrical System _ B40800 Electrical Wiring
Hydraulic System _ C00000 Pump Housing
Hydraulic System _ C05000 Gear Pump(Component Parts)
Hydraulic System _ C30000 Drive Motor And Component Parts
Hydraulic System _ C40000 Swivel Motor And Component Parts ## S.No._=20507 S.No.;_=20507
Hydraulic System _ C50000 Rotary Joint
Hydraulic System _ C50200 Oil Tank
Pump_Motor System _ C40001 Swivel Motor And Component Parts ## S.No._=20508 S.No.;_=20508
Control Valve _ C60000 Control Valve
Control Valve _ C60102 Control Valve (Component Parts) ## [ISO TPSS]
Control Valve _ C60201 Spool Section (Over-Drive)
Control Valve _ C60202 Spool Section (Swivel)
Control Valve _ C60203 Spool Section (Arm)
Control Valve _ C60204 Spool Section (Travel LH)
Control Valve _ C60205 Spool Section (Blade)
Control Valve _ C60206 Spool Section (S_P)
Control Valve _ C60207 Spool Section (Travel RH)
Control Valve _ C60208 Spool Section (Swing)
Control Valve _ C60209 Spool Section (Bucket)
Control Valve _ C60210 Spool Section (Boom)
Control Valve _ C70400 Change Valve
Control Lever _ D00000 Control Lever (Frame) ## [Except TPSS]
Control Lever _ D00001 Control Lever (Frame) ## [TPSS]
Control Lever _ D10000 Control Lever (Lever LH)
Control Lever _ D20000 Control Lever (Lever RH)
Control Lever _ D30001 Control Lever (Travel LH)
Control Lever _ D40001 Control Lever (Travel RH)
Control Lever _ D50000 Control Travel Pedal
Control Lever _ D50201 Control Lever (Swivel_Arm) ## [Except TPSS]
Control Lever _ D50202 Control Lever (Swivel_Boom) ## [TPSS]
Control Lever _ D50401 Control Lever (Boom_Bucket) ## [Except TPSS]
Control Lever _ D50402 Control Lever (Arm_Bucket) ## [TPSS]
Control Lever _ D60000 Control Lever (Safety Lock Lever) ## Note_Order By Ref.No
Control Lever _ D70000 Control Pedal (Swing)
Control Lever _ D80000 Control Lever (Blade)
Control Lever _ D90000 Control Lever (S_P)
Oil Piping _ E00000 Oil Piping (Suction)
Oil Piping _ E00400 Oil Piping (Return)
Oil Piping _ E20000 Oil Piping (Travel LH)
Oil Piping _ E20200 Oil Piping (Travel RH)
Oil Piping _ E20600 Oil Piping (Swivel)
Oil Piping _ E30000 Oil Piping (Swing)
Oil Piping _ E30600 Oil Piping (Boom)
Oil Piping _ E40200 Oil Piping (Arm)
Oil Piping _ E50200 Oil Piping (Bucket)
Oil Piping _ E60000 Oil Piping (Blade)
Oil Piping _ E60200 Oil Piping (Track)
Oil Piping _ E80000 Oil Piping (S_P)
Cylinder _ F00000 Boom Cylinder And Component Parts
Cylinder _ F10000 Arm Cylinder And Component Parts
Cylinder _ F20000 Bucket Cylinder And Component Parts
Cylinder _ F30000 Blade Cylinder And Component Parts
Cylinder _ F40000 Swing Cylinder And Component Parts
Cylinder _ F40200 Track Cylinder And Component Parts
Front Attachments _ G00000 Swing Bracket
Front Attachments _ G10001 Boom ## Kta.Ktc
Front Attachments _ G20000 Arm
Front Attachments _ G30000 Bucket Link
Front Attachments _ G40000 Bucket
Front Attachments _ G50000 Blade
Track Frame _ H00000 Track Frame ## Note_Order By Ref.No.020,030,090 New Parts & Ref.No
Track Frame _ H10000 Idler
Track Frame _ H20000 Track Roller
Swivel Frame _ J00000 Swivel Frame
Swivel Frame _ J00300 Swivel Gear Case
Swivel Frame _ J10000 Swivel Bearing
Swivel Frame _ J30000 Step
Swivel Frame _ K00302 Cover (Front) ## [Except TPSS]
Swivel Frame _ K00304 Cover (Front) ## [TPSS]Note_Order By Ref.No
Swivel Frame _ K10000 Bonnet ## Note 1_Order By Part.No.Ra028-9141-7 Note 2_Order By Part.No
Swivel Frame _ K20000 Sponge
Swivel Frame _ K30002 Weight
Swivel Frame _ K40001 Seat
Operator's Platform _ L00001 Canopy
Operator's Platform _ L00003 Canopy
Labels _ M00001 Label
Accessories _ N00001 Accessories
Option _ P00000 Travel Buzzer Kit[Option]
