Momed80
150
35,046
Kubota Engine V3800-CR-TE4B V3800-CR-TIE4B Workshop Manual
Type of Manual: Workshop Manual
Model: Kubota V3800-CR-TE4B V3800-CR-TIE4B Engine
Number of Pages: 161 Pages
V3800-CR-TE4B,V3800-CR-TIE4B(HYUNDAI)
To The Reader
I Information
Information
1. Safety First
2. Specifications
3. Performance Curves
4. Dimensions
G General
General
1. Engine Identification
[1] Model Name And Old Engine Serial Number
[2] Model Name And New Engine Serial Number
[3] E4b Engine
[4] Cylinder Number
2. Muffler Full Assembly Identification
[1] Part Number And Serial Number
3. General Precautions
4. Maintenance Check List
5. Check And Maintenance
[1] Daily Check Points
[2] Initial 50 Hours
[3] Every 50 Hours
[4] Every 250 Hours
[5] Every 500 Hours
[6] Every 1000 Hours
[7] Every 1500 Hours
[8] Every 3000 Hours
[9] Every 1 Year
[10] Every 2 Years
6. Special Tools
1 Engine
Mechanism
1. Engine
[1] Cylinder Block
[2] Cylinder Head
[3] Piston
2. Lubricating System
[1] Oil Cooler
3. Cooling System
[1] Thermostat
[2] Bottom Bypass System
4. Common Rail System (Crs)
[1] Overview
[2] Supply Pump
[3] Rail
[4] Injector
[5] Engine Control System
(1) Engine Ecu
(2) Sensor
5. Egr System
[1] Overview
[2] Egr Valve
[3] Reed Valve
6. After Treatment System
[1] After Treatment Devices
Servicing
1. Troubleshooting
2. Servicing Specifications
3. Tightening Torques
[1] Tightening Torques Of Screws, Bolts And Nuts For General Use
[2] Tightening Torques Of Screws, Bolts And Nuts For Special Use
4. Checking, Disassembling And Servicing
[1] Checking And Adjusting
(1) Engine Body
(2) Lubricating System
(3) Cooling System
(4) Electrical System
(5) Turbocharger
[2] Disassembling And Assembling
(1) Draining Engine Oil And Coolant
(2) External Components
(3) Turbocharger And Egr
(4) Common Rail
(5) Cylinder Head And Valves
(6) Thermostat
(7) Supply Pump
(8) Water Pump And Oil Cooler
(9) Gear Case And Timing Gear
(10) Piston And Connecting Rod
(11) Flywheel And Crankshaft
(12) Intake Air Heater
(13) Starter
(14) Alternator
[3] Engine Body And Servicing
(1) Cylinder Head
(2) Timing Gears
(3) Piston And Connecting Rod
(4) Crankshaft
(5) Cylinder
(6) Oil Pump
(7) Starter
(8) Alternator
