Kubota Diesel Generator GL11000-STD 60HZ Spare Parts Catalog EN ES
Language: English, Spanish
Type of Machine: Diesel Generator
Model: Kubota GL11000-STD 60HZ Diesel Generator
Number of Pages: 159 Pages
Bloque Motor / Crank Case
Aceite Cacerola / Oil Pan
Culata Cubierta / Head Cover
Aceite Filtro / Oil Filter
Varilla De Nivbl Y Guia / Dipstick And Guide
Aceite Bomba / Oil Pump
Arbol De Levas Y Punto Muerto Engranaje Eje / Camshaft And Idel Gear Shaft
Volante / Flywheel
Speed Control Plate
Bifurcacion Palanca(Regulador) / Fork Lever(Governor)
Combustible Bomba(Mecanico) / Fuel Pump(Mechanical)
Motor De Arranque / Starter
Aceite Conmutador Y Termometro Y Tapon / Oil Switch
Agua Bomba / Water Pump
Agua Tubo / Water Pipe
Ventilador / Fan
Tension Polea / Tension Pulley
Refrigeracion Ventil / Cooling Fan
Generador / Generator [Old]
Generador / Generator [New]
Mando Panel / Control Panel
Terminal
Comun Base / Common Base
Centro Viga / Center Beam
Adelante Bastidor / Front Frame
Trasero Bastidor / Rear Frame
Techo / Roof
Comprobar Puerta / Check Door
Vaciar Tubo(Aceite) / Drain Pipe (Oil)
Aire Limpiador / Air Cleaner
Entrada Tubo / Inlet Pipe
Silenciador / Muffler
Combustible Filtro / Fuel Filter [Old]
Combustible Filtro / Fuel Filter [New]
Agua Manguito / Water Hose
Accesorios / Accessories
Manual Y Etiqueta / Manual And Label
