Momed80
150
35,046
Kubota Diesel Engine V3800DI-T-E3B-AHFT-1 Illustrated Parts List 97898-76880 2009 EN ZH
Language: English, Chinese
Type of Machine: Diesel Engine
Type of Manual: Illustrated Parts List
Model: Kubota V3800DI-T-E3B-AHFT-1 Diesel Engine
Code No.: 1J412-26000
Part Number: 97898-76880
Publication Date: 2009
Number of Pages: 59 Pages
500000 Crankcase
501000 Oil Pan
501200 Dipstick And Guide
502000 Cylinder Head
503000 Inlet Valve And Exhaust Valve
504000 Rocker Arm Shaft
505000 Head Cover
508000 Gear Case
508200 Oil Filter
510500 Main Bearing Case
511000 Piston And Crank Shaft
512000 Camshaft And Idle Gear Shaft
515000 Flywheel
520000 Injection Pump Unit
520200 Injection Pump Housing
521000 Injection Pump
521500 Fuel Pump
522000 Fuel Camshaft
523000 Governor
524000 Fork Lever (Governor)
525000 Restriction Adjusting Bolt
531000 Fuel Filter
540000 Nozzle Holder And Glow Plug
545500 Over Flow Pipe
550500 Dynamo And Pulley
551500 Dynamo [Component Parts]
554000 Starter
555000 Starter [Component Parts]
555500 Stop Solenoid
556000 Oil Switch
560000 Water Flange And Thermostat
561000 Water Pump
561200 Water Pipe
567000 Fan And Pulley
571000 Inlet Manifold
572000 Exhaust Manifold
572300 Egr Valve
572400 Egr Cooler
572500 Boost Air Pipe
572600 Turbo Charger
580000 Oil Pipe (Turbo Charger)
580300 Oil Pipe (Mechanical Timer)
582000 Oil Cooler
588000 Accessories And Service Parts
589000 Label And Operator's Manual
594000 Piston Kit [Option]
Numerical Index
