Kubota Compact Trencher AP-CTR1030 AP-CTR1036 AP-CTR1048 Operation Manual 350-418MK
Type of Machine: Trencher
Model: Kubota AP-CTR1030, AP-CTR1036, AP-CTR1048 Trencher
Part Number: 350-418MK
Publication Date: 2023
Number of Pages: 58 Pages
Important Safety Information
Safety at All Times
Look for the Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Compact Utility Loader Requirements
Torque Requirements
Before You Start
Compact Loader Shutdown Procedure
Lift / Transport Anchor Points
Dealer Preparation and Set-up
Check Chain Overall Width
Check Auger Offset
Check Crumber Shoe Size
Check Chain Tension
Check Crumber Arm Clearance
Attach Depth Indicator
Hook-Up Trencher
Hook-Up Trencher
Hook-Up Hydraulics
Check Equipment Clearances
Section 2: Adjustments
Adjust Chain Tension
Adjust Auger Position
Section 3: Operating Procedures
Operating Checklist
Safety Information
Equipment Inspection
Transporting
Operating Guidelines
Unhook Compact Trencher
Section 4: Options
Crumber Shoe Option
Trencher Chain Selection Options
Standard Cups, 2 Pitch Spacing
Standard Cups, 4 Pitch Spacing
Scorpion and Cup Teeth
Motor (Option)
Section 5: Maintenance & Lubrication
Maintenance
General Inspection
Chain Service in Harsh Conditions
Auger Removal
Auger Installation
Crumber Shoe Maintenance
Check Chain Tension
Check Chain and Sprocket Wear
Chain Removal and Replacement
Remove & Install Single Chain Strand
Chain Removal
Chain Installation
Remove & Install Continuous Chain Loop
Chain Removal
Chain Installation
Sprocket Replacement
General Tooth Maintenance
Cup Teeth
Scorpion Teeth
Remove & Install Front Roller
Remove Front Roller
Replace Bearing in Front Roller
Remove Old Bearing From Front Roller
Install New Bearing in Front Roller
Long-Term Storage
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque Values Chart
Section 10: Warranty & Legal Disclaimer
Safety at All Times
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Torque Requirements
Before You Start
Check Auger Offset
Check Chain Tension
Hook-Up Trencher
Hook-Up Trencher
Hook-Up Hydraulics
Operating Checklist
Safety Information
Transporting
Section 4: Options
Crumber Shoe Option
Motor (Option)
Maintenance
General Inspection
Auger Removal
Auger Installation
Check Chain Tension
Chain Removal
Chain Installation
Chain Removal
Chain Installation
Cup Teeth
Scorpion Teeth
Remove Front Roller
Long-Term Storage
Lubrication Points
