Kubota Compact Tractor MK5000DW Spare Parts Catalog EN FR
Language: French, English
Model: Kubota MK5000DW Compact Tractor
Number of Pages: 229 Pages
Frequently Used Ite Ms / Frequently Used Items
Bloc Moteur / Crankcase
Carter D'huile / Oil Pan
Couvre-Culasse / Head Cover
Paliers De Vilebrequin / Main Bearing Case
Arbre A Cames Et Arbre De Pignon Fou / Camshaft A Nd Idle Gear Shaft
Piston Et Vilebrequin / Piston And Crankshaft
Arbre A Cames De Carburant / Fuel Camshaft
Compensateur / Balancer
Levier D'arret Du Moteur / Engine Stop Lever
Variateur De Vitesse [Vieux] / Speed Control Plat E [Old]
Variateur De Vitesse [Nouveau] / Speed Control Pl Ate [New]
Porte-Injecteur Et Bougie De Prechauffage / Nozzl E Holder And Glow Plug
Bride A Eau Et Thermostat / Water Flange And Ther Mostat
Pompe A Eau / Water Pump
Soupapes Et Culbuteurs / Valve And Rocker Arm
Filtre A Air / Air Cleaner
Silencieux / Muffler
Jeu De Joint Superieur / Upper Gasket Kit
Jeu De Joint Inferieur / Lower Gasket Kit
Tringle D'accelerateur / Accelerator Linkage
Support De Reservoir A Carburant / Fuel Tank Support
Tuyau A Carburant/Filtre A Carbur Ant / Fuel Pipe/Fuel Filter
Filtre A Carburant [Parties Compo Santes] / Fuel Filter [Component Parts]
Ventilateur / Fan
Tuyau D'eau / Water Pipe
Radiateur / Radiator
Reservoir Du Radiate Ur / Reserve Tank
Alternateur / Alternator
Alternateur [Parties Comp Osantes] / Alternator [Component Parts]
Demarreur / Starter
Demarreur [Parties Compos Antes] / Starter [Component Parts]
Batterie / Battery
Commutateur/Detector (Mot Eur) / Switch/Sensor (Engine)
Commutateur/Relais / Swit Ch/Relay
Commutateur/Detecteur / S Witch/Sensor
Tableau De Bord / Panel B Oard
Tableau De Bord [Parties Composantes] / Panel Board [Component Parts]
Phare [Ec] [Tur] / Head L Ight [Ec] [Tur]
Phare [Parties Composante S] [Ec] [Tur] [Vieux] / Head Light [Component Parts ] [Ec] [Tur] [Old]
Phare [Parties Composante S] [Ec] [Tur] [Nouveau] / Head Light [Component Par Ts] [Ec] [Tur] [New]
Feux De Clignotant / Wink Er Lamp
Feux Arriere / Rear Lamp
Lamp Et Plaque D'immatric Ulation [W] / License Lamp [W]
Prise De Remorque [W] / T Railer Socket [W]
Faisceau Electrique (Avan T) / Electrical Wiring (Front)
Faisceau Electrique (Arri Ere) / Electrical Wiring (Rear)
Embrayage / Clutch
Embrayage / Clutch
Levier D'embrayage / Clutch Lever
Pedale D'embrayage / Clutch Pedal
Carter Intermediaire / Mid Case
Soupape D'embrayage Pdf / Pto Clutch Valve
Soupape D'embrayage Pdf [Parties Composantes] / Pto Clutch Valve [Compo Nent Parts]
Carter De Transmissi On / Transmission Case
Arbre Principal / Ma In Shaft
Arbre De Renvoi / Co Unter Shaft
Pignon Conique / Spi Ral Bevel Pinion
Arbre Pdf Interm / P To Countershaft
Embrayage Pdf / Pto Clutch
Arbre D'entrainement Pdf / Pto Drive Shaft
Arbre De Pdf / Pto S Haft
Fourchette De Change Ment De Vitesses Principal / Main Gear Shift Fork
Fourchette D'inverse Ur / Shuttle Shift Fork
Fourchette De Change Ment De Gamme / Range Gear Shift Fork
Fourchette De Blocag E Differentiel / Differential Lock Shift Fork
Levier De Changement De Vitesses Principal / Main Gear Shift Lever
Levier D'inverseur / Shuttle Shift Lever
Levier De Changement De Gamme / Range Gear Shift Lever
Tige De Changement D E Vitesses Et Inverseur / Range Gear Shift And Shut Tle Shift Rod
Levier De Traction A Vant / Front Wheel Drive Lever
Essieu Arriere Gauche / Rear Axle(Left)
Essieu Arriere Droite / Rear Axle(Right)
Frein Gauche / Brake Lh
Frein Droite / Brake Rh
Tige De Frein 1 (Pedal De Fr Ein) / Brake Rod 1 (Brake Pedal)
Tige De Frein 2 (Came De Fre In) / Brake Rod 2 (Brake Cam)
Frein De Stationnement 2 (Le Vier) / Hand Brake 2 (Lever)
Pedale De Frein / Brake Peda L
Chassis Avant / Front Axl E Frame
Arbre De Entrainement Ava Nt / Front Drive Shaft
Arbre De Transmission (Ar Riere) / Propeller Shaft (Rear)
Arbre De Transmission (Av Ant) / Propeller Shaft (Front)
Avant Carter De Different Iel / Front Differential Case
Differentiel (Avant) / Di Fferential (Front)
Demi Arbre Pont / Differe Ntial Gear Shaft
Volant De Direction [W] / Steering Handle [W ]
Support De Direction / Steering Support
Pompe Hydraulique [Parties Composantes] / Hydraulic Pump [Component Parts]
Soupape De Regulateur / Re Gulator Valve
Circuit D'huile Hydrauliqu E (Crique) / Hydraulic Oil Line (Inlet)
Circuit D'huile Hydrauliqu E(Refoulement) / Hydraulic Oil Line (Delivery)
Circuit D'huile Hydrauliqu E (Direction) / Hydraulic Oil Line (Steering)
Circuit D'huile Hydrauliqu E Pdf / Pto Hydraulic Pipe
Bloc De Prise Hydraulique / Hydraulic Outlet Block
Cylindre Hydraulique / Hyd Raulic Cylinder
Bras De Relevage [Ec] [Uk] / Lift Arm [Ec] [Uk]
Levier De Revenue [Ec] [Uk ] / Feed Back Lever [Ec] [Uk]
Distributeur / Control Val Ve
Levier De Controle De Posi Tion [Ec] [Uk] / Position Control Lever [Ec] [Uk]
Tirant Superieur [Ec] [Uk] / Top Link [E C] [Uk]
Demarreur / Starter
Stabilisateur / Stabilizer
Barre De Relevage [Ec] [Uk] / Lift Rod [ Ec] [Uk]
Barre D'attelage / Drawbar
Attelage Avant / Front Hitch
Protection Pdf [Ec] [Uk] / Pto Protector [Ec] [Uk]
Phale De Travail [Nouveau] / Front Grille [Ne W]
Support De Capot Avant / Hood (Bonnet) Front Support
Capot / Hood (Bonnet)
Damper De Capot / Hood(Bonnet) Damper
Retroviseur [Ec] [Tur] [Se] / Rearview Mirror [Ec] [Tur] [Se]
Aile / Fender
Aile / Fender
Aile / Fender
Aile / Fender
Support D'aile [W] / Fender Support [W]
Couvercle De Plancher / Floor Sheet Cover
Siege [W] / Seat [W]
Marchepied / Step
Cadre Anti-Renversment [W] / Rops [ W]
Roue Avant (8-16) / Front Wh Eel (8-16)
Roue Arriere (12,4-28-4pr) / Rear Wheel (12.4-28-4pr)
Roue Arriere (13,6-28) / Rea R Wheel (13.6-28)
Etiquette 1 (Avant) / Label 1 (Front)
Etiquette 2 (Arriere) / Label 2 (Rear)
Phale De Travail [Option] / Working Light Kit [Op Tion]
Poids Avant [Option] / Front Bumper Kit [Option]
Volant De Direction [W] [Option] / Steering Handl E Kit [W] [Option]
Levier De Controle De Position (Avec Type D'effor T)[Ec][Uk] [Option] / Position Control Lever Kit (W Ith Draft) [Ec] [Uk] [Option]
Maillon De Controle De Position (Avec Type D'effo Rt)[Ec][Uk][Option] / Position Control Link (With D Raft) [Ec][Uk] [Option]
Levier De Controle D'effort (Avec Type D'effort) [Ec][Uk] [Option] / Draft Control Lever (With Draft ) [Ec][Uk] [Option]
Controle De La Valve Auxiliare [Option] / Auxilia Ry Control Valve [Option]
Controle De La Valve Auxiliare (Flottage)[Option] / Auxiliary Control Valve (Floating) [Option]
Controle De La Valve Auxiliaire (Seul) [Option] / Auxiliary Control Valve (Single) [Option]
Levier De Controle De La Valve Auxiliaire (1eme) [Option] / Auxiliary Control Valve Lever (1st) [Opt Ion]
Levier De Controle De La Valve Auxiliaire (2eme) [Option] / Auxiliary Control Valve Lever (2nd) [Opt Ion]
Levier De Controle De La Valve Auxiliaire (3eme) [Option] / Auxiliary Control Valve Lever (3rd) [Opt Ion]
Accouplement De La Valve Auxiliaire (1eme) [W] [O Ption] / Auxiliary Control Valve Coupler (1st) [W] [Option]
Accouplement De La Valve Auxiliaire (2eme) [W] [O Ption] / Auxiliary Control Valve Coupler (2nd) [W] [Option]
Accouplement De La Valve Auxiliaire (3eme) [W] [O Ption] / Auxiliary Control Valve Coupler (3rd) [W] [Option]
Barre De Traction Oscillante/Barre D'attelage [Op Tion] / Swinging Drawbar/Clevis Drawbar [Option]
