Kubota Compact Tractor LX-401C Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota LX-401C Compact Tractor
Number of Pages: 299 Pages
Itens Usados F Requentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Valvula Admissao E Escape / Inlet Valve And Exhaust Valve
Tampa Cabeça / Head Cover
Carreto / Gear Case
Filtro Oleo / Oil Filter
Vareta Nivel E Guia / Dipstick
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft And Go Vernor Shaft
Bomba De Abastecimento / Supply Pump
Eixo Inativo Da Bomba De Abastecimento / Idle Shaft Of Supply Pump
Vela Pre Aquecimento / Injector And Glow Plug
Common Rail / Common Rail
Suporte Da Cabalagem Elétrica / Wire Harness Bracke T
Bomba Agua E Termostacto / Water Flange And Thermos Tat
Tubo Agua / Water Hose
Bomba Agua / Water Pump
Flange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
Valvula Egr / Egr Valve
Refrigerador Egr / Egr Cooler
Filtro Ar / Air Cleaner
Filtro Ar [Peças Componentes] / Air Cleaner [Compon Ent Parts]
Tubo Aspiracao / Inlet Pipe
Panela Escape / Muffler Pipe
Coluna Do Panela Escape / Muffler Pillar
Silenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
Silenciador Do Filtro De Partículas Diesel [Peças C Omponentes] / Diesel Particulate Filter Muffler [Co Mponent Parts]
Sensor Escape / Muffler Sensor
Tubo Pressao / Pressure Pipe
Tubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Char Ger)
Radiador Oleo / Oil Cooler
Tubo Combustivel (Deposito) / Fuel Pipe (Tank)
Tubo Combustivel (Refrigerado R) / Fuel Pipe (Cooler)
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Compone Ntes] / Fuel Filter [Component Parts]
Separador / Separator
Bomba Gasoleo / Fuel Pump
Arrefecedor Gasoleo / Fuel Co Oler
Ventoinha / Fan
Capa Da Ven Toinha / Fan Shroud
Tubo Agua / Water Pipe
Deposito Re Serva / Reserve Tank
Alternador / Alternator
Alternador [Peças Componente S] / Alternator [Component Parts]
Motor Arranque [Peças Compon Entes] / Starter [Component Parts]
Cablagem De Bateria / Batter Y Cable
Sensor (Motor) / Sensor (Eng Ine)
Interruptor (Dianteiro) / Sw Itch (Front)
Interruptor (Traseiros) / Sw Itch (Rear)
Relé / Relay
Sensor (Corpo) / Sensor (Bod Y)
Buzina / Horn
Unidade Control Electrico / Ecu
Painel / Panel
Tampa Interruptor / Panel Sw Itch
Luzes Frente [Exceto Uk] / H Ead Light [Except Uk]
Luzes Frente [Uk] / Head Lig Ht [Uk]
Luzes Frontais / Front Combi Nation Lamp
Braco Traseiro / Rear Combin Ation Lamp
Farol Matricula / License La Mp
Ficha Reboque / Trailer Sock Et
Luzes Trabalho (Dianteiro) / Working Light (Front)
Farois Trabalho (Traseira) / Working Light (Rear)
Luz Interior / Room Light
Painel Controlo Air Condicio Nado/Relé / Air-Con.Control Panel/Relay
Antena/Coluna / Antenna/Spea Ker
Limpa-Pára-Brisas (Dianteiro ) / Wiper (Front)
Limpa-Pára-Brisas (Traseira) / Wiper (Rear)
Cablagem Electrica (Dianteir O) / Electrical Wiring (Front)
Cablagem Electrica (Traseira ) / Electrical Wiring (Rear)
Cablagem Electrica (Painel) / Electrical Wiring (Panel)
Cablagem Electrica (Cabine) / Electrical Wiring (Cab)
Caixa Da Transmissão / Transmission Cas E
Capa Da Caixa De Engrenagens Diferencia Is / Differential Gear Case Cover
Carter Eixo Traseiro Esq / Rear Axle Ca Se (Left)
Hst / Hst
Hst (Caixa) [Peças Componentes] / Hst ( Case) [Component Parts]
Hst (Bomba) [Peças Componentes] / Hst ( Pump) [Component Parts]
Hst (Tampa De Bloqueio Da Abertura) [Pe Ças Componentes] / Hst (Motor) [Component Parts]
Hst (Bloco De Abertura) [Peças Componen Tes] / Hst (Port Block) [Component Parts]
Hst (Neutro) [Peças Componentes] / Hst (Neutral) [Component Parts]
Contraveio Hidrostático / Hst Counter S Haft
Veio Tracao Dianteira / Front Wheel Pro Peller Shaft
Veio Do Pinhão Hipóide / Hypoid Pinion Shaft
Tdf / Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clutch Sha Ft
Veio Tdf / Pto Shaft
Tdf Central / Mid Pto
Carreto De Acionamento Da Tdf Intermédi A / Mid Pto Drive Gear
Diferencial Traseiro / Rear Differentia L
Veio Bi-Speed / Bi-Speed Turn Shaft
Embraiagem Bi-Speed / Bi-Speed Turn Clu Tch
Forqueta Velocidades / Range Gear Shift Fork
Bloqueio Diferencial De Forqu Eta / Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axle (Left )
Eixo Traseiro Direita / Rear Axle (Right )
Travão Esquerda / Brake (Left)
Travão Direita / Brake (Right)
Tirante Do Travão (Frente) / Brake Rod (Front)
Tirante Do Travão (Traseira) / Brake Rod (Rear)
Tirante Travão De Estacionamento / Parking Brake Ro D
Caixa Velocidades / Speed Change Rod
Gama Alavanca De Velocidades / Range Gear Shi Ft Lever
Alavanca Dupla Traccao / Front Wheel Drive Le Ver
Control Velocidade / Cruise Control Lever
Cabo De Desengate Da Velocidade De Cruzeiro / Cruise Release Cable
Alavanca Das Mudanças De Tdf Intermédia / Mid Pto Gear Shift Lever
Alavanca Control Posicao / Position Control L Ever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Loc K Pedal
Diferencial Dianteiro / Front Differen Tial
Eixo De Engrenagem Cónica (Frente) / B Evel Gear Shaft (Front)
Engrenagem Cónica Esquerda / Bevel Gea R (Left)
Engrenagem Cónica Direita / Bevel Gear (Right)
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Axle Case (Le Ft)
Eixo Dianteiro Esq / Front Axle (Left)
Eixo Frente Drt / Front Axle (Right)
Veio De Transmissão (Dianteiro) / Fron T Wheel Drive Shaft (Front)
Coluna Direcção / Steering Column
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Steeri Ng Cylinder [Component Parts]
Orbitol / Power Steering
Bomba Hidraulico / Hydra Ulic Pump
Tubo Oleo Hidraulico(Ent Rada) / Hydraulic Oil Line (Inlet)
Circuito Oleo Direcção ( Saída) / Hydraulic Oil Line (Outlet)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hydrau Lic Oil Line (Hst)
Linha De Óleo Hidráulico (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Válvula Do Carregador [P Eças Componentes] / Loader Valve [Component Parts]
Válvula De Mudança De Ca Rregador / Loader Changeover Valve
Alavanca Da Válvula Do C Arregador / Loader Valve Lever
Elo Da Válvula Do Carreg Ador / Loader Valve Link
Tubo Do Carregador Hidrá Ulico (Frente) / Loader Pipe (Front)
Tubo Do Carregador Hidrá Ulico (Traseira) / Loader Pipe (Rear)
Hidráulico Tomada Tubo / Hydraulic Outlet Pipe
Cilindro Hidraulico / Hy Draulic Cylinder
Tampa Do Cilindro Hidráu Lico / Hydraulic Cylinder Cap
Tampa Do Cilindro Hidráu Lico [Peças Componentes] / Hydraulic Cylinder Cap [ Component Parts]
Piston Hidraulico / Braç Os / Hydraulic Piston / Lift Arm
Alavanca / Feed Back Lev Er
Válvula Bi-Speed Turn / Bi-Speed Turn Valve
Válvula Bi-Speed Turn [P Eças Componentes] / Bi-Speed Turn Valve [Component Parts]
Valvula Control / Contro L Valve
Valvula Control [Peças C Omponentes] / Control Valve [Component Parts]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Tiran Te / Lift Rod
Corre Nte Seguranca / Check Chain
Ligac Ao Superior / Top Link
Puxo Dianteiro / Front Hitch
Barra Reboque / Drawbar
Prote Ccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior / Bonnet Upper
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Saia De Cobertura Lateral / Side Cover Skirt
Pilar Central / Center Pillar
Apoio Da Pilar Central / Center Plate Stay
Es Trutura Cabine / Cab Frame
Pa Inel Inferior / Panel Cover
De Grau / Step
As Sento Por Baixo Da Cobertura / Seat Under Cover
Co Bertura / Tail Cover
Po Rta Esq / Door (Left)
Po Rta Drt / Door (Right)
Tr Inco Porta Esq / Door Lock (Left)
Tr Inco Porta Drt / Door Lock (Right)
Te Jadilho Interior / Inner Roof
Co Bertura Exterior Do Tejadilho / Outer Roof
Di Anteira Do Suporte Da Cabine / Cab Bracket (Front)
Tr Aseira Do Suporte Da Cabine / Cab Bracket (Rear)
Ta Pete Do Piso / Floor Mat
Si Lenciador / Sound Absorber
Co Bertura Interior / Interior Cover
Gu Ia Esq / Lever Guide (Left)
Gu Ia Drt / Lever Guide (Right)
Ba Nco [A Tipo] / Seat [A Type]
Ba Nco [B Tipo] / Seat [B Type]
Ba Nco [C Tipo] / Seat [C Type]
Ba Nco [D Tipo] / Seat [D Type]
Ba Nco [E Tipo] / Seat [E Type]
Ba Nco [F Tipo] / Seat [F Type]
Vi Dro Frente / Front Glass
Vi Dro Traseiro / Rear Glass
Tr Ava De Vidro Traseiro / Rear Glass Lock
Es Pelho Rectrovisor / Rearview Mirror
Ar Condicionado / Air Conditione R
Ar Condicionado [Peças Component Es] / Air Conditioner [Component Parts]
Tubo Ar Condicionado / Drain Hos E (Air Conditioner)
Condesador / Capacitor
Tubo Do Ar Condicionado / Air Co Nditioner Pipe
Compressor / Compressor
Conduta Do Ar Condicionado / Air -Con.Duct
Roda Frente (7-12) / Front Wheel (7-12)
Roda Frente (24*8,50-14) / Front Wheel ( 24*8.50-14)
Roda Traseira (12,4-16) / Rear Wheel (1 2.4-16)
Roda Traseira (13,6-16) / Rear Wheel (1 3.6-16)
Decalcomania(Painel) / Label (Panel)
Kit De Cabine (Cabine) [Opção] / Cab Kit (Cab) [Opt Ion]
Kit De Cabine (Luzes Frontais) [Opção] / Cab Kit (F Ront Combination Lamp) [Option]
Kit De Cabine (Braco Traseiro) [Opção] / Cab Kit (R Ear Combination Lamp) [Option]
Kit De Cabine (Farol Matricula) [Opção] / Cab Kit ( License Lamp) [Option]
Kit De Cabine (Ficha Reboque/Saída Elétrica) [Opção ] / Cab Kit (Trailer Socket / Coupler) [Option]
Kit De Cabine (Pedal Acelarador) [Opção] / Cab Kit (Speed Change Pedal) [Option]
Kit De Cabine (Punho Volante) [Opção] / Cab Kit (St Eering Wheel) [Option]
Kit De Cabine (Elo Da Válvula Do Carregador) [Opção ] / Cab Kit (Loader Valve Link) [Option]
Kit De Cabine (Frente Do Suporte Da Cabine) [Opção] / Cab Kit (Cab Bracket Front) [Option]
Kit De Cabine (Traseira Do Suporte Da Cabine) [Opçã O] / Cab Kit (Cab Bracket Rear) [Option]
Kit Do Cilindro De Elevação Do Cortador De Relva (C Ilindro Esquerdo) [Opção] / Mower Lift Cylinder Kit (Cylinder Left) [Option]
Kit Do Cilindro De Elevação Do Cortador De Relva (C Ilindro Direito) [Opção] / Mower Lift Cylinder Kit (Cylinder Right) [Option]
Kit Do Cilindro De Elevação Do Cortador De Relva (T Ubo) [Tipo Frente De Saída Externa] [Opção] / Mower Lift Cylinder Kit (Pipe) [Front Type Of External O Utput] [Option]
Kit Do Cilindro De Elevação Do Cortador De Relva (T Ubo) [Tipo Traseira De Saída Externa] [Opção] / Mow Er Lift Cylinder Kit (Pipe) [Rear Type Of External Output] [Option]
Carreto / Gear Case
Ventoinha / Fan
Relé / Relay
Buzina / Horn
Painel / Panel
Hst / Hst
Tiran Te / Lift Rod
De Grau / Step
