Kubota Compact Tractor LX-351 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota LX-351 Compact Tractor
Number of Pages: 245 Pages
Itens Usados Fr Equentemente / Frequently Used Items
B Loco Motor / Crankcase
C Arter Oleo / Oil Pan
C Abeça Motor / Cylinder Head
V Alvula Admissao E Escape / Inlet Valve And Exhaust Valve
V Alvula E Veio Martelos / Valve And Rocker Arm
T Ampa Cabeça / Head Cover
C Arreto / Gear Case
F Iltro Oleo / Oil Filter
V Areta Nivel E Guia / Dipstick
R Olamento Principal / Main Bearing Case
P Iston E Cambota / Piston And Crankshaft
V Olante Motor / Flywheel
V Eio Combustivel E Regulador / Fuel Camshaft And Gov Ernor Shaft
B Omba De Abastecimento / Supply Pump
E Ixo Inativo Da Bomba De Abastecimento / Idle Shaft Of Supply Pump
V Ela Pre Aquecimento / Injector And Glow Plug
C Ommon Rail / Common Rail
S Uporte Da Cabalagem Elétrica / Wire Harness Bracket
T Ubo Agua / Water Hose
B Omba Agua / Water Pump
F Lange Filtro Ar E Valvula Acelarador / Air Cleaner Flange And Throttle Valve
C Olector Escape / Exhaust Manifold
V Alvula Egr / Egr Valve
R Efrigerador Egr / Egr Cooler
T Urbo Compressor / Turbo Charger
F Iltro Ar / Air Cleaner
F Iltro Ar [Peças Componentes] / Air Cleaner [Compone Nt Parts]
T Ubo Aspiracao / Inlet Pipe
P Anela Escape / Muffler Pipe
C Oluna Do Panela Escape / Muffler Pillar
S Ilenciador Do Filtro De Partículas Diesel / Diesel Particulate Filter Muffler
S Ilenciador Do Filtro De Partículas Diesel [Peças Co Mponentes] / Diesel Particulate Filter Muffler [Com Ponent Parts]
S Ensor Escape / Muffler Sensor
T Ubo Pressao / Pressure Pipe
T Ubo Oleo (Turbo Compressor) / Oil Pipe (Turbo Charg Er)
R Adiador Oleo / Oil Cooler
K It Juntas Superior / Upper Gasket Kit
K It Juntas Inferior / Lower Gasket Kit
A Celarador Mao / Accelerator Lever
Deposito Combustivel / Fuel Ta Nk
Tubo Combustivel (Deposito) / Fuel Pipe (Tank)
Tubo Combustivel (Refrigerador ) / Fuel Pipe (Cooler)
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Separador / Separator
Bomba Gasoleo / Fuel Pump
Arrefecedor Gasoleo / Fuel Coo Ler
Ventoinha / Fan
Capa Da Vent Oinha / Fan Shroud
Tubo Agua / Water Pipe
Radiador / R Adiator
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Cablagem De Bateria / Battery Cable
Sensor (Motor) / Sensor (Engi Ne)
Interruptor (Dianteiro) / Swi Tch (Front)
Interruptor (Traseiros) / Swi Tch (Rear)
Relé / Relay
Sensor (Corpo) / Sensor (Body )
Buzina / Horn
Unidade Control Electrico / E Cu
Painel / Panel
Tampa Interruptor / Panel Swi Tch
Luzes Frente [Exceto Uk] / He Ad Light [Except Uk]
Luzes Frente [Uk] / Head Ligh T [Uk]
Luzes Frontais / Front Combin Ation Lamp
Braco Traseiro / Rear Combina Tion Lamp
Farol Matricula / License Lam P
Ficha Reboque / Trailer Socke T
Cablagem Electrica (Dianteiro ) / Electrical Wiring (Front)
Cablagem Electrica (Traseira) / Electrical Wiring (Rear)
Cablagem Electrica (Painel) / Electrical Wiring (Panel)
Caixa Da Transmissão / Transmission Case
Capa Da Caixa De Engrenagens Diferenciai S / Differential Gear Case Cover
Carter Eixo Traseiro Esq / Rear Axle Cas E (Left)
Carter Eixo Traseiro Drt / Rear Axle Cas E (Right)
Hst / Hst
Hst (Caixa) [Peças Componentes] / Hst (C Ase) [Component Parts]
Hst (Bomba) [Peças Componentes] / Hst (P Ump) [Component Parts]
Hst (Tampa De Bloqueio Da Abertura) [Peç As Componentes] / Hst (Motor) [Component Parts]
Hst (Bloco De Abertura) [Peças Component Es] / Hst (Port Block) [Component Parts]
Hst (Neutro) [Peças Componentes] / Hst ( Neutral) [Component Parts]
Contraveio Hidrostático / Hst Counter Sh Aft
Veio Tracao Dianteira / Front Wheel Prop Eller Shaft
Veio Do Pinhão Hipóide / Hypoid Pinion S Haft
Veio Da Embraiagem Tdf / Pto Clutch Shaf T
Veio Tdf / Pto Shaft
Tdf Central / Mid Pto
Carreto De Acionamento Da Tdf Intermédia / Mid Pto Drive Gear
Diferencial Traseiro / Rear Differential
Veio Bi-Speed / Bi-Speed Turn Shaft
Embraiagem Hidraulica / Hydraulic Clutch
Forqueta Velocidades / Range G Ear Shift Fork
Bloqueio Diferencial De Forque Ta / Differential Lock Shift Fork
Eixo Traseiro Esquerda / Rear Axle (Left)
Eixo Traseiro Direita / Rear Axle (Right)
T Ravão Esquerda / Brake (Left)
T Ravão Direita / Brake (Right)
T Irante Travao / Brake Rod
T Ravao Parque / Parking Brake Lever
T Irante Travão De Estacionamento / Parking Brake Rod
Caixa Velocidades / Speed Change Rod
Desativação Da Velocidade De Cruzeiro / Cruise Release
Gama Alavanca De Velocidades / Range Gear Shif T Lever
Alavanca Dupla Traccao / Front Wheel Drive Lev Er
Control Velocidade / Cruise Control Lever
Cabo De Desengate Da Velocidade De Cruzeiro / Cruise Release Cable
Alavanca Das Mudanças De Tdf Intermédia / Mid Pto Gear Shift Lever
Alavanca Control Posicao / Position Control Le Ver
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Diferencial Dianteiro / Front Different Ial
Eixo De Engrenagem Cónica (Frente) / Be Vel Gear Shaft (Front)
Engrenagem Cónica Esquerda / Bevel Gear (Left)
Engrenagem Cónica Direita / Bevel Gear (Right)
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Axle Case (Lef T)
Carter Eixo Frente Drt / Axle Case (Rig Ht)
Eixo Dianteiro Esq / Front Axle (Left)
Eixo Frente Drt / Front Axle (Right)
Veio De Transmissão (Frente) / Front Wh Eel Drive Shaft (Front)
Direção Suporte / Steering Bracket
Veio Da Direcção / Steering Shaft
Alavanca / Tilt Lever
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Orbitol / Power Steering
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Tubo Oleo Hidraulico (Ent Rada) / Hydraulic Oil Line (Inlet)
Circuito Oleo Direcção (S Aída) / Hydraulic Oil Line (Outlet)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hydraul Ic Oil Line (Hst)
Linha De Óleo Hidráulico (Radiador Oleo) / Hydraulic Oil Line (Oil Cooler)
Válvula Do Carregador / L Oader Valve
Válvula Do Carregador [Pe Ças Componentes] / Loader Valve [Component Parts]
Válvula De Mudança De Car Regador / Loader Changeover Valve
Alavanca Da Válvula Do Ca Rregador / Loader Valve Lever
Elo Da Válvula Do Carrega Dor / Loader Valve Link
Tubo Do Carregador Hidráu Lico (Frente) / Loader Pipe (Front)
Tubo Do Carregador Hidráu Lico (Traseira) / Loader Pipe (Rear)
Alavanca De Bloqueio Da V Álvula Do Carregador / Loader Valve Lock Lever
Hidráulico Tomada Tubo / Hydraulic Outlet Pipe
Cilindro Hidraulico / Hyd Raulic Cylinder
Tampa Do Cilindro Hidrául Ico / Hydraulic Cylinder Cap
Tampa Do Cilindro Hidrául Ico [Peças Componentes] / Hydraulic Cylinder Cap [C Omponent Parts]
Piston Hidraulico / Braço S / Hydraulic Piston / Lift Arm
Alavanca / Feed Back Leve R
Válvula Bi-Speed Turn / B I-Speed Turn Valve
Válvula Bi-Speed Turn [Pe Ças Componentes] / Bi-Speed Turn Valve [Component Parts]
Valvula Control [Peças Co Mponentes] / Control Valve [Component Parts]
Tirant E / Lift Rod
Ligaca O Inferior / Lower Link
Corren Te Seguranca / Check Chain
Ligaca O Superior / Top Link
Puxo D Ianteiro / Front Hitch
Barra Reboque / Drawbar
Protec Cao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot Superior / Bonnet Upper
Trico Capot / Bonnet Lock
Lado Do Capot / Bonnet Side
Saia De Cobertura Lateral / Side Cover Skirt
Pilar Central / Center Pillar
Apoio Da Pilar Central / Center Plate Stay
Painel Inferior / Panel Cover
Guia Drt / Lever Guide (Right)
Guarda Lamas / Fender
Piso / Floor Sheet
Banco [A Tipo] / Seat [A Type]
Banco [B Tipo] / Seat [B Type]
Banco [C Tipo] / Seat [C Type]
Banco [D Tipo] / Seat [D Type]
Banco [E Tipo] / Seat [E Type]
Banco [F Tipo] / Seat [F Type]
Degrau / Step
Degrau Suspensão / Step Stay
Caixa Ferramenta / Tool Box
Estrutura De Protecção (Traseira) / Rops (Lower )
Estrutura De Protecção (Frente) / Rops (Upper)
Roda Frente (7-12) / Front Wheel (7-12)
Roda Frente (24*8,50-14) / Front Wheel (2 4*8.50-14)
Roda Traseira (12,4-16) / Rear Wheel (12 .4-16)
Roda Traseira (13,6-16) / Rear Wheel (13 .6-16)
Decalcomania(Painel) / Label (Panel)
Acessori Os E Peças Serviço / Accessories And Service Parts
K It Do Cilindro De Elevação Do Cortador De Relva (Ci Lindro Esquerdo) [Opção] / Mower Lift Cylinder Kit (Cylinder Left) [Option]
K It Do Cilindro De Elevação Do Cortador De Relva (Ci Lindro Direito) [Opção] / Mower Lift Cylinder Kit ( Cylinder Right) [Option]
K It Do Cilindro De Elevação Do Cortador De Relva (Tu Bo) [Tipo Frente De Saída Externa] [Opção] / Mower Lift Cylinder Kit (Pipe) [Front Type Of External Ou Tput] [Option]
K It Do Cilindro De Elevação Do Cortador De Relva (Tu Bo) [Tipo Traseira De Saída Externa] [Opção] / Mowe R Lift Cylinder Kit (Pipe) [Rear Type Of External O Utput] [Option]
K It Espelho Rectrovisor [Opçao] / Rearview Mirror Ki T [Option]
Ventoinha / Fan
Relé / Relay
Buzina / Horn
Painel / Panel
Hst / Hst
Tirant E / Lift Rod
Piso / Floor Sheet
Degrau / Step
