Kubota Compact Tractor BX2350D 70001- Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota BX2350D Compact Tractor
Serial Number: 70001-
Number of Pages: 212 Pages
Content
Bkidk5035 >> Bx2350d(S.No.70001-)
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel E Guia / Dipstick And Gui De
Bomba Oleo / Oil Pump
Radiador / Main Bearing Case
Arvore Cames E Veio / Camshaft And Idl E Gear Shaft
Piston E Cambota / Piston And Cranksha Ft
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaf T
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control P Late
Suporte Bico [Peças Componentes] / Noz Zle Holder [Component Parts]
Resguardo / Cover
Bomba Agua E Termostacto / Water Flang E And Thermostat
Acessorios / Water Pump
Válvula E Veio Do Balanceiro / Valve A Nd Rocker Arm
Filtro Ar / Air Cleaner
Escpae / Muffler
Kit De Junta Superior / Upper Gasket K It
Deposito Combustivel / Lower Gasket Ki T
Cambota,Kit 1 [Opção] / Camshaft Kit 1 [Option]
Cambota,Kit 2 [Opção] / Camshaft Kit 2 [Option]
Deposito Combust Ivel / Fuel Tank
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Bomba Gasoleo / Fuel Pump
Ventilador / Fan
Radiador / Water Pipe
Sensor Térmico E Interruptor Do Óleo / Oil Switch And Thermo Senso R
Filtro Gasoleo / Stop Solenoid
Alternador / Al Ternator
Alternador [Peç As Componentes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Bateria / Batte Ry
Painel / Panel Board
Sensor/Rele / S Ensor And Relay
Interruptor / S Ensor (Motor) / Switch/Sensor
Farol Dianteiro / Head Light
Luzes De Aviso/ Farol Traseiro / Hazard Light/Tail Light
Reflector / Ref Lector
Cabalagem Eletr Ica(Cabine)[Ec] [G] / Electrical Wiring
Estrututa Frontal / Front Frame
Suporte Da Estrutura / Fr Ame Bracket
Suporte Motor / Engine Su Pport
Caixa Diferencial Diantei Ro / Front Differential Case
Diferencial Dianteiro / F Ront Differential
Engrenagem Cónica Esquerd A / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Eixo Frente(Esq) / Front Axle Case Lh
Carter Eixo Frente(Drt) / Front Axle Case Rh
Eixo Dianteiro / Front Ax Le Lh
Eixo Frente (Drt) / Front Axle Rh
Veio Eixo / Front Wheel D Rive Shaft
Caixa Velocidades / Transm Ission Case
Cilindro Hidraulico[Peças Componentes] / Transmission Case Cover
Carter Eixo Traseiro Drt ( Tipo Arco) / Rear Axle Case Rh
Veio Embraiagem / Clutch S Haft
Hst 1 / Hst 1 (Cylinder Bl Ock)
Hst 2 (Regulador)[Peças Co Mponentes] / Hst 2 (Arm)
Hst 3 (Veio Motor)[Peças C Omponentes] / Hst 3 (Port Block Cover)
Hst 4 / Hst 4 (Oil Cooler Cover)
Veio Gamas Velocidades / R Ange Gear Shaft
Veio Tdf / Pto Shaft
Embraiagem Tdf / Pto Clutc H
Tdf Central / Mid Pto
Diferencial Carter / Rear Differential
Wał Pośredniczący 4x4 / Fw D Idle Shaft
Wał Pośredniczący Gp / Gp Idle Shaft
Veio Tracao Dianteira / Fr Ont Wheel Propeller Shaft
Forqueta Caixa / Creeper / Range Gear Shift Fork
Alvanca Tdf / Pt O Gear Shift Fork
Braço De Mudança De Velocidade Tdf / Pto Gear Shift Arm
Alavanca / Diffe Rential Lock Shift Fork
Pedal Acelarador / Speed Control Pedal
Tirante De Mudan Ça De Velocidade / Speed Control Rod
Control Velocida De / Cruise Control Lever
Alavanca Velocid Ades / Range Gear Shift Lever
Alavanca Tdf / P To Gear Shift Lever
Valvula Control / Remote Control Valve Lever
Eixo Traseiro Esquerda / Re Ar Axle Lh
Eixo Traseiro Direita / Rea R Axle Rh
Bloqueio Diferencial / Diff Erential Lock Pedal
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Alavanca Travao Mao / Parking Brake Le Ver
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavamca De Controle / Hydraulic Control Lever
Bomba Hidrau Lico / Hydraulic Pump
Bomba Hidrau Lico[Peças Componentes] / Hydraulic Pump [Component Parts]
Linha De Óle O Hidráulico (Fornecimento) / Hydraulic Oil Line (D Elivery)
Circuito Ole O (Direcção) / Hydraulic Oil Line (Steering)
Cilindro Hid Raulico / Hydraulic Cylinder
Piston Hidra Ulico / Braços / Hydraulic Piston/Lift Arm
Braco Hidrau Lico / Control Valve
Valvula Cont Rol / Control Valve [Component Parts]
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar[Peças Componentes] / Remote Control Valve [Component Parts]
Veio De Ajus Te Da Queda / Fall Adjustment Shaft
Tubo Da Válv Ula De Controlo Auxiliar / Remote Control Valve Pip E
Cilindro Direcção / Steering Cyli Nder
Cilindro Direcção[Peças Component Es] / Steering Cylinder [Component Parts]
Ligacao Superio R / Top Link
Ligacao Inferio R / Lower Link
Tirante / Lift Rod
Corrente Segura Nca / Check Chain
Parte Superior / Top Link Bracket
Ligação Do Cort Ador De Relva (Traseira) (Lado Direito) / Mower Rea R Link Rh
Ligação Do Cort Ador De Relva (Traseira) (Lado Esquerdo) / Mower Re Ar Link Lh
Barra Reboque / Drawbar
Proteccao Tdf / Pto Protector
Acessorios / Bonnet
Lado Do Capot / Bonnet Side
Kit Limpa Vidro Traseiros (Opcao) / Panel Frame
Espelho Rectrovisor / Rearview Mi Rror [Except Uk]
Espelho Rectrovisor / Rearview Mi Rror [Uk]
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Acessorios / Seat [Except Kdg]
Degrau / Step
Degrau Suspensão / Step Stay
Alavanca Valvula Control Auxiliar 2º [Opcao] / Rops
Roda Frente / Front Wheel( 18*8.5-10)
Roda Traseira / Rear Wheel (26*12.00-12)
Roda Traseira / Rear Wheel (26*12-12)
Etiqueta Frente / Label (F Ront) [Except Uk]
Etiqueta Frente / Label (F Ront) [Uk]
Etiqueta Traseira / Label (Rear) [Except Uk]
Etiqueta Traseira / Label (Rear) [Uk]
Acessorios / Accessories And Service Parts
Puxo Dianteiro,Kit[Opção] / Front Hitc H Kit [Option]
Resguardo Kit[Opção] / Fan Cover Kit [ Option]
Valvula Control Frente / Front Control Valve Kit (Valve) [Option]
Valvula Control Frente / Front Control Valve Kit (Valve) [Comp.Parts][Option]
Valvula Control Frente / Front Control Valve Kit (Rod) [Option]
Valvula Control Frente / Front Control Valve Kit (Lever) [Option]
Valvula Control Frente / Front Control Valve Kit (Oil Line 1) [Option]
Valvula Control Frente / Front Control Valve Kit (Oil Line 2) [Option]
Hydraulic Port Kit [Option] / Hydrauli C Port Kit [Option]
