Kubota Compact Tractor BX231D5-R1 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota BX231D5-R1 Compact Tractor
Number of Pages: 212 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel / Dipstick
Bomba Oleo / Oil Pump
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Pl Ug
Resguardo / Cover
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Deposito Combustivel / Fue L Tank
Tubo Combustivel / Fuel Pi Pe
Filtro Gasoleo / Fuel Filt Er
Bomba Gasoleo / Fuel Pump
Ventoinh A / Fan
Capa Da Ventoinha / Fan Shroud
Tubo Agu A / Water Pipe
Sensor Térmico E Interrup Tor Do Óleo / Oil Switch And Thermo Sensor
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Painel / Panel Board
Sensor/Rele / Sensor And Relay
Interruptor/Sensor / Swit Ch/Sensor
Luzes Frente / Head Light
Lâmpada De Alerta De Peri Go / Hazard Light
Farol Traseiro / Tail Lig Ht
Refletor / Reflector
Ficha Reboque / Trailer S Ocket
Cablagem Electrica (Diant Eiro) / Electrical Wiring (Front)
Cablagem Electrica (Trase Ira) / Electrical Wiring (Rear)
Estrututa Frontal / Front Frame
Suporte Da Estrutura / Frame Bracke T
Carter Eixo Frente / Front Axle Cas E
Diferencial Dianteiro / Front Diffe Rential
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel G Ear Rh
Carter Eixo Frente Esq / Axle Case Lh
Carter Eixo Frente Drt / Axle Case Rh
Eixo Dianteiro Esquerda / Front Axl E Lh
Veio Eixo / Front Wheel Drive Shaft
Caixa Da Transmissão / Transmission Case
Tampa Da Transmissão / Transmission Case Cover
Hst 1 (Bloco Cilindro) / Hst 1 (Cyli Nder Block)
Hst 2 (Braço) / Hst 2 (Arm)
Hst 3 (Tampa Do Bloco De Abertura) / Hst 3 (Port Block Cover)
Hst 4 (Radiador Oleo) / Hst 4 (Oil C Ooler Cover)
Veio Gamas Velocidades / Range Gear Shaft
Veio Tdf / Pto Shaft
Embraiagem Tdf / Pto Clutch
Tdf Central / Mid Pto
Diferencial Traseiro / Rear Differen Tial
Wał Pośredniczący 4x4 / Fwd Idle Sha Ft
Wał Pośredniczący Gp / Gp Idle Shaft
Veio Tracao Dianteira / Front Wheel Propeller Shaft
Forqueta Velocidades / Ran Ge Gear Shift Fork
Alvanca Tdf / Pto Gear Shi Ft Fork
Braço De Mudança De Veloci Dade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial De Fo Rqueta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Caixa Velocidades / Speed Change Rod
Control Velocidade / Cruise Control Lever
Alavanca Velocidades / Range Gear Shift Le Ver
Alavanca Tdf / Pto Select Lever
Alavanca Da Válvula De Controlo Auxiliar / Auxiliary Control Lever
Alavamca De Controle / Hydraulic Control L Ever
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential Lock Pedal
Direção Suporte / Steering Bracket
Alavanca / Tilt Lever
Distribuidor Direcção / Steering Controller
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hy Draulic Pump
Bomba Hidraulico [Peç As Componentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Circuito Oleo (Direcç Ão 1) / Hydraulic Oil Line (Steering 1)
Circuito Oleo (Direcç Ão 2) / Hydraulic Oil Line (Steering 2)
Valvula Control / Con Trol Valve
Valvula Control [Peça S Componentes] / Control Valve [Component Parts]
Válvula De Controlo A Uxiliar [Peças Componentes] / Auxiliary Control Val Ve [Component Parts]
Veio De Ajuste Da Que Da / Fall Adjustment Shaft
Tubo Da Válvula De Co Ntrolo Auxiliar / Auxiliary Control Valve Pipe
Li Gacao Superior / Top Link
Li Gacao Inferior / Lower Link
Ti Rante / Lift Rod
Co Rrente Seguranca / Check Chain
Li Gação Do Cortador De Relva Direito / Mower Rear Lin K Rh
Li Gação Do Cortador De Relva Esquerdo / Mower Rear Li Nk Lh
Bo Tão De Controlo Do Cortador / Mower Control Dial
Ba Rra Reboque / Drawbar
Pr Oteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot(Inferior) / Bonnet (Lower)
Capot Aberto / Bonnet Open
Lado Do Capot / Bonnet Side
Pilar Central / Center Pillar
Tampa Painel / Panel Cover
Guia Esq / Lever Guide Lh
Guia Drt [Exceto Frente Control Posicao] / Lever Guide Rh [Except Front Control Lever]
Guia Drt [Frente Control Posicao] / Lever G Uide Rh [Front Control Lever]
Guarda Lamas / Fender
Haste Do Paralama / Fender Stay
Banco (Cobo Leather) / Seat (Cobo Leather)
Banco (Sears Mechanical,Pvc) / Seat (Sears Mechanical,Pvc)
Banco (Sears Air,Pvc) / Seat (Sears Air,Pvc )
Degrau / Step
Degrau Suspensão / Step Stay
Suspensão Interruptor Velocidades [Exceto F Rente Control Posicao] / Range Gear Shift Switch St Ay [Except Front Control Lever]
Suspensão Interruptor Velocidades [Frente C Ontrol Posicao] / Range Gear Shift Switch Stay [Fro Nt Control Lever]
Cobertura Traseira / Rear Cover
Arco / Rops
Roda Frente (18*8,5-10) / Front Wheel (18*8.5-10)
Roda Traseira (26*12,00-12) / Rear W Heel (26*12.00-12)
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Puxo Dianteiro,Kit[Opção] / Front Hitch Kit [Opt Ion]
Engate Traseiro [Opção] / Rear Hitch Kit [Option ]
Kit De Peso Dianteiro [Opçao] / Front Weight Kit [Option]
Resguardo Kit[Opção] / Fan Cover Kit [Option]
Valvula Control Frente (Válvula) [Opção] / Front Control Valve Kit (Valve) [Option]
Valvula Control Frente (Válvula) [Peças Componen Tes] [Opção] / Front Control Valve Kit (Valve) [Com P.Parts] [Option]
Valvula Control Frente (Control Posicao) [Opção] / Front Control Valve Kit (Control Lever) [Option]
Valvula Control Frente (Bloqueio Posicao) [Opção ] / Front Control Valve Kit (Lock Lever) [Option]
Valvula Control Frente (Tubo/Rapido Acoplamento) [Opção] / Front Control Valve Kit (Pipe/Quick Coup Ler) [Option]
Valvula Control Frente (Tubo) [Opção] / Front Co Ntrol Valve Kit (Hose) [Option]
