Kubota Compact Tractor BX231D5-R Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota BX231D5-R Compact Tractor
Number of Pages: 228 Pages
Itens Usados Frequentemente / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeça Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel / Dipstick
Bomba Oleo / Oil Pump
Arvore Cames E Veio / Camshaft And Idle Gear Shaf T
Volante Motor / Flywheel
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Glow Plu G
Resguardo / Cover
Bomba Agua E Termostacto / Water Flange And Therm Ostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo / Fuel Filte R
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Capa Da V Entoinha / Fan Shroud
Tubo Agua / Water Pipe
Sensor Térmico E Interrupt Or Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Stop S Olenoid
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Painel / Panel Board
Tampa Interruptor / Panel Switch
Sensor/Rele / Sensor And R Elay
Interruptor/Sensor / Switc H/Sensor
Luzes Frente / Head Light
Lâmpada De Alerta De Perig O / Hazard Light
Refletor / Reflector
Cablagem Electrica (Diante Iro) / Electrical Wiring (Front)
Estrututa Frontal / Front Frame
Suporte Da Estrutura / Frame Bracket
Diferencial Dianteiro / Front Differ Ential
Engrenagem Cónica Esquerda / Bevel G Ear Lh
Engrenagem Cónica Direita / Bevel Ge Ar Rh
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro Esquerda / Front Axle Lh
Veio Eixo / Front Wheel Drive Shaft
Tampa Da Transmissão / Transmission C Ase Cover
Hst 1 (Bloco Cilindro) / Hst 1 (Cylin Der Block)
Hst 2 (Braço) / Hst 2 (Arm)
Hst 3 (Tampa Do Bloco De Abertura) / Hst 3 (Port Block Cover)
Hst 4 (Radiador Oleo) / Hst 4 (Oil Co Oler Cover)
Veio Gamas Velocidades / Range Gear S Haft
Veio Tdf / Pto Shaft
Embraiagem Tdf / Pto Clutch
Tdf Central / Mid Pto
Diferencial Traseiro / Rear Different Ial
Wał Pośredniczący 4x4 / Fwd Idle Shaf T
Wał Pośredniczący Gp / Gp Idle Shaft
Veio Tracao Dianteira / Front Wheel P Ropeller Shaft
Forqueta Velocidades / Rang E Gear Shift Fork
Alvanca Tdf / Pto Gear Shif T Fork
Braço De Mudança De Velocid Ade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial De For Queta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Cabo Travao Mao / Parking Brake Wire
Caixa Velocidades / Speed Change Rod
Control Velocidade / Cruise Control Lever
Alavanca Velocidades / Range Gear Shift Lev Er
Alavanca Tdf / Pto Select Lever
Alavanca Da Válvula De Controlo Auxiliar / Auxiliary Control Lever
Alavamca De Controle / Hydraulic Control Le Ver
Pedal Travao / Brake Pedal
Bloqueio Diferencial Pedal / Differential L Ock Pedal
Direção Suporte / Steering Bracket
Alavanca / Tilt Lever
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico [Peça S Componentes] / Hydraulic Pump [Component Parts]
Tubo Oleo (Entrega) / Hydraulic Pipe (Delivery)
Circuito Oleo (Direcçã O 1) / Hydraulic Oil Line (Steering 1)
Circuito Oleo (Direcçã O 2) / Hydraulic Oil Line (Steering 2)
Piston Hidraulico / Br Aços / Hydraulic Piston / Lift Arm
Valvula Control / Cont Rol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Válvula De Controlo Au Xiliar / Auxiliary Control Valve
Válvula De Controlo Au Xiliar [Peças Componentes] / Auxiliary Control Valv E [Component Parts]
Veio De Ajuste Da Qued A / Fall Adjustment Shaft
Tubo Da Válvula De Con Trolo Auxiliar / Auxiliary Control Valve Pipe
Lig Acao Superior / Top Link
Lig Acao Inferior / Lower Link
Tir Ante / Lift Rod
Cor Rente Seguranca / Check Chain
Lig Ação Do Cortador De Relva Direita / Mower Rear Link Rh
Lig Ação Do Cortador De Relva Esquerda / Mower Rear Lin K Lh
Bot Ão De Controlo Do Cortador / Mower Control Dial
Bar Ra Reboque / Drawbar
Pro Teccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Capot(Inferior) / Bonnet (Lower)
Capot Aberto / Bonnet Open
Lado Do Capot / Bonnet Side
Pilar Central / Center Pillar
Tampa Painel / Panel Cover
Guia Esq / Lever Guide Lh
Guia Drt [Exceto Frente Control Posicao] / L Ever Guide Rh [Except Front Control Lever]
Guia Drt [Frente Control Posicao] / Lever Gu Ide Rh [Front Control Lever]
Guarda Lamas / Fender
Haste Do Paralama / Fender Stay
Banco (Cobo Leather) / Seat (Cobo Leather)
Banco (Sears Mechanical,Pvc) / Seat (Sears M Echanical,Pvc)
Banco (Sears Air,Pvc) / Seat (Sears Air,Pvc)
Degrau / Step
Degrau Suspensão / Step Stay
Suspensão Interruptor Velocidades / Range Ge Ar Shift Switch Stay
Arco / Rops
Roda Frente (18*8,5-10) / Front Wheel (18*8.5-10)
Roda Traseira (26*12,00-12) / Rear Wh Eel (26*12.00-12)
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Puxo Dianteiro,Kit [Opção] / Front Hitch Kit [Opt Ion]
Engate Traseiro [Opção] / Rear Hitch Kit [Option]
Kit De Peso Dianteiro [Opção] / Front Weight Kit [Option]
Resguardo Kit [Opção] / Fan Cover Kit [Option]
Valvula Control Frente (Válvula) [Opção] / Front Control Valve Kit (Valve) [Option]
Valvula Control Frente (Válvula) [Peças Component Es] [Opção] / Front Control Valve Kit (Valve) [Comp .Parts] [Option]
Valvula Control Frente (Control Posicao) [Opção] / Front Control Valve Kit (Control Lever) [Option]
Valvula Control Frente (Bloqueio Posicao) [Opção] / Front Control Valve Kit (Lock Lever) [Option]
Valvula Control Frente (Tubo/Rapido Acoplamento) [Opção] / Front Control Valve Kit (Pipe/Quick Coupl Er) [Option]
Valvula Control Frente (Tubo) [Opção] / Front Con Trol Valve Kit (Hose) [Option]
