Kubota Compact Tractor BX2200E Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota BX2200E Compact Tractor
Number of Pages: 211 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Radiador / Main Bearing Case
Volante Motor / Flywheel
Veio / Fuel Camshaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Filtro Gasoleo / Stop Solenoid
Suporte Bico [Peças Componentes] / Nozzle Holder [ Component Parts]
Bomba Gasoleo / Fuel Pump(Mechanical)
Alternado E Poli / Alternator And Pulley
Alternador [Peças Componentes] / Alternator [Compo Nent Parts]
Motor Arranque / Starter
Motor Arranque [Componentes] / Starter [Component Parts]
Interruptor E Termómetro Do Óleo / Oil Switch/Ther Mometer
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Acessorios / Water Pump
Ventilador / Fan
Válvula E Veio Do Balanceiro / Valve And Rocker Ar M
Filtro Ar / Air Cleaner
Escpae / Muffler
Hydraulic Pump Cover / Hydraulic Pump Cover
Deposito Combustivel / Lower Gasket Kit
Tubo Combustivel / Fuel Pipe
Radiador / Water Pipe
Painel / Panel Board
Interruptor / Sensor (Motor) / Switch/Sensor
Farol Dianteiro / Head Light
Hazard Light/Tail Light / Ha Zard Light/Tail Light
Farol Matricula / License La Mp
Ficha Reboque / Trailer Sock Et
Cabalagem Eletrica(Cabine)[E C] [G] / Electrical Wiring
Carter Eixo / Rear Axle Case
Veio Embraiagem / Clutch Shaft/Output S Haft
Hst / Hst
Hst [Peças Componentes] / Hst [Componen T Parts]
Veio Gamas Velocidades / Range Gear Sha Ft
Veio Tdf / Pto Shaft
Tdf Central / Mid Pto
Diferencial Carter / Rear Differential
Gp Idle Shaft / Gp Idle Shaft
Forqueta Caixa / Creeper / Ra Nge Gear Shift Fork
Alvanca Tdf / Pto Gear Shift Fork
Braço De Mudança De Velocidad E Tdf / Pto Gear Shift Arm
Alavanca / Differential Lock Shift Fork
Neutral Holder Link / Neutral Holder Link
Pedal Acelarador / Speed Cont Rol Pedal
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Tdf / Pto Select Lev Er
Eixo Traseiro / Rear Axle
Travão / Brake
Cabo Travao Mao / Parking Brake Wire
Pedal Travao / Brake Pedal
Alavamca De Controle / Hydra Ulic Control Lever
Bomba Hidraulico[Peças Compo Nentes] / Hydraulic Pump [Component Parts]
Linha Aspiração / Hydraulic Oil Line(Suction)
Tubo Oleo / Hydraulic Oil Li Ne(Delivery)
Circuito Oleo (Direcção) / H Ydraulic Oil Line(Steering)
Cilindro Hidraulico / Hydrau Lic Cylinder
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm [Except [Fr] [Uk] [2wd]]
Braco Hidraulico / Control V Alve
Valvula Control / Control Va Lve [Component Parts]
Distribuidor Auxiliar / Remo Te Control Valve
Distribuidor Auxiliar[Peças Componentes] / Remote Control Valve [Component Part S]
Remote Control Valve Pipe / Remote Control Valve Pipe
Eixo Dianteiro / Front Axle
Direcção Assistida / Direção Punho / Steering Handle
Direcção / Steering Linkage
Cilindro Direcção[Peças Componentes] / Steerin G Cylinder [Component Parts]
Parte Superior / Top Link Br Acket
Mower Rear Link Rh / Mower R Ear Link Rh
Mower Rear Link Lh / Mower R Ear Link Lh
Barra Reboque / Drawbar [Exc Ept [Fr] [2wd]]
Proteccao Tdf / Pto Protecto R
Front Glille Support / Front Glille Support
Acessorios / Bonnet
Bonnet Side / Bonnet Side
Pilar Central / Center Pillar
Kit Limpa Vidro Traseiros (Opcao) / Panel Fram E
Espelho Rectrovisor / Rearview Mirror [Fr] [G]
Espelho Rectrovisor / Rearview Mirror [Uk]
Guarda Lamas / Fender
Banco / Seat [Fr] [Uk]
Banco / Seat [G]
Degrau / Step
Roda Frente / Front Wheel(18*8.50-8)
Roda Traseira / Rear Wheel(26*12.00-12)
Etiqueta Traseira / Label [French]
Etiqueta Traseira / Label [Germany]
Acessorios / Accessorie S And Service Parts
Kit De Ligação 3º Ponto (Opção) / 3-P Lift Arm Kit [Fr] [Uk] [2wd] [Option]
Kit De Ligação 3-P 1(Haste De Elevação) [Opção] / 3 -P Link Kit 1 [Option]
Kit De Ligação 3-P 2(Ligação Inferior) [Opção] / 3- P Link Kit 2 [Option]
Kit De Ligação 3-P 3(Estabilizador) [Opção] / 3-P L Ink Kit 3 [Option]
Front Hitch Kit [Option] / Front Hitch Kit [Option]
Kit Barra Reboque[Opcao] / Drawber Kit [Fr] [2wd] [ Option]
Rops Kit [Option] / Rops Kit [Option]
Carreto / Gear Case
Ventilador / Fan
Escpae / Muffler
Hst / Hst
Travão / Brake
Acessorios / Bonnet
Banco / Seat [G]
Degrau / Step
