Kubota Compact Tractor B3150HDB-F Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B3150HDB-F Compact Tractor
Number of Pages: 239 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Ge Ar Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camsha Ft And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And G Low Plug
Bomba Agua E Termostacto / Water Flange An D Thermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (A Ir Cleaner)
Escpae / Muffler
Kit De Juntas / Upper Gasket Kit
Kit De Junta Superior / Lower Gasket Kit
Deposito Combustivel / Fue L Tank
Tubo Combustivel / Fuel Pi Pe
Filtro Gasoleo / Fuel Filt Er
Filtro Gasoleo [Peças Comp Onentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinh A / Fan
Tubo Agu A / Water Pipe
Sensor Térmico E Interrup Tor Do Óleo / Oil Switch And Thermo Sensor
Alternador / Alternator
Motor Arranque / Starter
Comutador / Switch
Relé / Relay
Painel / Panel Board
Painel [Peças Componentes ] / Panel Board [Component Parts]
Tampa Interruptor / Panel Switch
Luzes Frente / Head Light
Luzes Frontais / Front Co Mbination Lamp
Braco Traseiro / Rear Com Bination Lamp
Ficha Reboque / Trailer S Ocket
Cablagem Electrica / Elec Trical Wiring
Tampa Da Caixa De Embraiagem / Clutch Housi Ng Cover
Suporte Eixo Frente / Front Axle Fr Ame
Carter Eixo Frente / Front Axle Cas E
Diferencial Dianteiro / Front Diffe Rential
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel G Ear Rh
Carter Grupo Conico / Bevel Gear Ca Se
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro / Front Axle Lh
Veio Eixo / Front Drive Shaft
Caixa Velocidades / Transmission Cas E
Hst / Hst
Hst (Caixa) [Peças Componentes] 1 / Hst (Case) [Component Parts] 1
Hst (Bomba) [Peças Componentes] 2 / Hst (Pump) [Component Parts] 2
Hst (Motor) [Peças Componentes] 3 / Hst (Motor) [Component Parts] 3
Hst (Tampa De Bloqueio Da Abertura) [Peças Componentes] 4 / Hst (Port Block Cover) [Com Ponent Parts] 4
Hst (Suporte Neutro) [Peças Componen Tes] 5 / Hst (Neutral Holder) [Component Parts] 5
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Gear Shaft
Inversor / Reverse Shaft
Tdf / Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clutch Shaft
Tdf Central / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Differen Tial
Forqueta Velocidades / Ran Ge Gear Shift Fork
Braço De Mudança De Veloci Dade Tdf / Pto Gear Shift Arm
Alavanca / Differential Lo Ck Shift Fork
Pedal Acelarador / Speed C Hange Pedal
Tirante De Mudança De Velo Cidade / Speed Change Rod
Braço De Desengate Hst / H St Release Arm
Alavanca Velocidades / Ran Ge Shift Lever
Alavanca Dupla Traccao / F Ront Wheel Drive Lever
Control Velocidade / Cruis E Control Lever
Cabo De Desengate Da Veloc Idade De Cruzeiro / Cruise Release Cable
Alavanca Tdf / Pto Gear Sh Ift Lever
Alavanca Control Posicao / Position Control Lever
Alavanca Da Válvula Do Car Regador / Loader Valve Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial / Dif Ferential Lock Pedal
Veio Bi-Speed Turn / Bi-Sp Eed Turn Shaft
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Pedal Inclinacao / Tilt Pedal
Direcção / Steering
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hy Draulic Pump
Bomba Hidraulico [Peç As Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucç Ão) / Hydraulic Pipe (Suction)
Tubo Oleo (Entrega) / Hydraulic Oil Line (Delivery)
Circuito Oleo (Direcç Ão) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hyd Raulic Oil Line (Hst)
Linha De Óleo Hidrául Ico (Radiador Oleo) / Hydraulic Oil Line (Oil Coole R)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Válvula Do Carregador / Loader Valve
Válvula Do Carregador [Peças Componentes] / Loader Valve [Component Part S]
Elo Da Válvula Do Car Regador / Loader Valve Link
Tubo Do Carregador Hi Dráulico / Hydraulic Loader Pipe
Piston Hidraulico / B Raços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lever
Valvula Control / Con Trol Valve
Valvula Control [Peça S Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Que Da / Fall Adjustment Shaft
Válvula Tdf / Pto Val Ve
Válvula Tdf [Peças Co Mponentes] / Pto Valve [Component Parts]
Ti Rante / Lift Rod
Li Gacao Inferior / Lower Link
Li Gacao Superior / Top Link
Co Rrente Seguranca / Check Chain
Ba Rra Reboque / Drawbar
Pu Xo Dianteiro / Front Hitch
Pu Xo Traseiro / Rear Hitch
Pr Oteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco (Cobo Sc74/M91) / Seat (Cobo Sc74/M91 )
Banco (Grammer Msg83/511) / Seat (Grammer M Sg83/511)
Banco (Grammer Msg93/511) / Seat (Grammer M Sg93/511)
Banco (Sears 807) / Seat (Sears 807)
Banco (Sears 830) / Seat (Sears 830)
Degrau / Step
Silenciador / Sound Absorber
Cobertura / Tail Cover
Caixa Ferramenta / Tool Box
Arco / Rops
Roda Frente (7-12) / Front Wheel (7-1 2)
Roda Frente (24*8,50-12) / Front Whee L (24*8.50-12)
Roda Traseira (12,4-16) / Rear Wheel (12.4-16)
Roda Traseira (13,6-16) / Rear Wheel (13.6-16)
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Kit Luzes Trabalho [Opçao] / Working Light Kit [ Option]
Cilindro Elevação (Braços) [Opcao] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opcao] / Mower Lif T Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opcao] / Front Weight Kit [Opti On]
