Kubota Compact Tractor B3030HDBC(EC) Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B3030HDBC(EC) Compact Tractor
Number of Pages: 381 Pages
Itens Uso Freque Nte / Frequently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Vareta Nivel E Guia / Dipstick And Guid E
Piston E Cambota / Piston And Crankshaf T
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Cam Shaft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Pl Ate
Vela Pre Aquecimento / Nozzle Holder An D Glow Plug
Suporte Bico [Peças Componentes] / Nozz Le Holder [Component Parts]
Bomba Agua / Water Pump
Valvula E Veio Martelos / Valve And Roc Ker Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Cleaner)
Escpae / Muffler
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel F Ilter
Filtro Gasoleo [Peças C Omponentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pu Mp
Vento Inha / Fan
Tubo Agua / Water Pipe
Radia Dor / Radiator
Depos Ito Reserva / Reserve Tank
Sensor Térmico E Inter Ruptor Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / St Op Solenoid
Alternador / Alternato R
Alternador [Peças Comp Onentes] / Alternator [Component Parts]
Motor Arranque / Start Er
Motor Arranque [Peças Componentes] / Starter [Component Parts]
Interruptor / Switch
Rele / Relay
Painel / Panel Board
Painel [Peças Componen Tes] / Panel Board [Component Parts]
Tampa Interruptor / Pa Nel Switch
Farol Frente [Uk] / He Ad Light [Uk]
Farol Frente [Ec] / He Ad Light [Ec]
Luzes Frontais / Front Combination Lamp
Braco Traseiro / Rear Combination Lamp
Farol Matricula [Uk] / License Lamp [Uk]
Farol Matricula [Ec] / License Lamp [Ec]
Ficha Reboque / Traile R Socket
Luzes Trabalho / Worki Ng Light
Painel Controlo Air Co Ndicionado / Air-Con.Control Panel
Escova Limpa Vidros / Wiper
Cablagem Electrica (Cu Erpo) / Electrical Wiring (Body)
Cabalagem Eletrica (Ca Bine) [Uk] / Electrical Wiring (Cab) [Uk]
Cabalagem Eletrica (Ca Bine) [Ec] / Electrical Wiring (Cab) [Ec]
Tampa Da Caixa De Embraiagem / Clutch Ho Using Cover
Diferencial Carreto Caixa / Diffe Rential Gear Case
Carter Eixo Traseiro Esq / Rear A Xle Case Lh
Carter Eixo Traseiro Drt / Rear A Xle Case Rh
Hst / Hst
Hst (Bloco Do Cilindro) [Peças Co Mponentes] 1 / Hst (Cylinder Block) [Component Part S] 1
Hst (Tampa Do Bloco De Abertura) [Peças Componentes] 2 / Hst (Port Block Cover) [Com Ponent Parts] 2
Hst (Junta) [Peças Componentes] 3 / Hst (Gasket) [Component Parts] 3
Hst (Fixador Do Neutro) [Peças Co Mponentes] 4 / Hst (Neutral Holder) [Component Part S] 4
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Ge Ar Shaft
Inversor / Reverse Shaft
Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clut Ch Shaft
Embraiagem Tdf / Pto Clutch
Tdf Intermédia / Mid Pto
Bkidk0152 >> B3030hdbc(Ec)
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Diffe Rential
Forqueta Velocidades / Range Gear Shift Fork
Braço De Mudança De Vel Ocidade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial Fo Rqueta / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Tirante De Mudança De Velocidade / Spee D Change Rod
Haste De Desativação Da Velocidade De C Ruzeiro / Cruise Release Rod
Braço De Desengate Hst / Hst Release Ar M
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel Dr Ive Lever
Control Velocidade / Cruise Control Lev Er
Alavanca Control Posicao / Position Con Trol Lever
Valvula Control / Remote Control Lever
Pedal Travao / Brake Pedal
Pedal Bloqueio Diferencial / Differenti Al Lock Pedal
Veio Bi-Speed Turn / Bi-Speed Turn Shaf T
Braço Bi-Speed / Bi-Speed Turn A Rm
Biela Bi-Speed / Bi-Speed Shift Rod
Diferencial Dianteiro / Front Di Fferential
Engrenagem Cónica Esquerda / Bev El Gear Lh
Engrenagem Cónica Direita / Beve L Gear Rh
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Front A Xle Case Lh
Carter Eixo Frente Drt / Front A Xle Case Rh
Eixo Dianteiro Esq / Front Axle Lh
Veio Eixo / Front Drive Shaft
Pedal Inclinacao / Tilt Pedal
Cilindro Direcção [Peças Componentes] / Steering Cylinder [Component Parts]
Bomba Hidraulico [ Peças Componentes] / Hydraulic Pump [Component Part S]
Circuito Oleo (Suc Ção) / Hydraulic Oil Line (Suction)
Circuito Oleo (Ent Rega) / Hydraulic Oil Line (Delivery)
Circuito Oleo (Dir Ecção) / Hydraulic Oil Line (Steering)
Circuito Oleo (Hst ) / Hydraulic Oil Line (Hst)
Circuito Oleo (Rad Iador Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/M ) / Hydraulic Oil Line (F/M)
Cilindro Hidraulic O / Hydraulic Cylinder
Piston Hidraulico / Braços / Hydraulic Piston/Lift Arm
Alavanca / Feed Ba Ck Lever
Valvula Control [P Eças Componentes] / Control Valve [Component Parts]
Distribuidor Auxil Iar / Remote Control Valve
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Valvula Descarga / Relief Valve
Válvula Tdf / Pto Valve
Válvula Tdf [Peças Componentes] / Pto Valve [Component Parts]
Tirante / Lift Rod
Ligacao Inferior / Low Er Link
Ligacao Superior / Top Link
Corrente Seguranca / C Heck Chain
Barra Reboque / Drawba R
Puxo Frontal / Front H Itch
Puxo Traseiro / Rear H Itch
Proteccao Tdf / Pto Pr Otector
Capot Superior / Bonnet
Painel Lateral / Side Cover
Placa / Shutter Plate
Pilar Central / Center Pillar
Cabine / Cab
Painel Inferior / Panel Cover
Degrau / Step
Assento Por Baixo Da Cobertura / Seat Under Cov Er
Cobertura Do Guarda-Lamas / Fender Cover
Guarda Lamas / Fender
Cobertura / Tail Cover
Porta Esq / Door Lh
Porta Drt / Door Rh
Tejadilho Interior / Inner Roof
Tejadilho Exterior / Outer Roof
Dianteira Do Suporte Da Cabine / Cab Bracket Fr Ont
Traseira Do Suporte Da Cabine / Cab Bracket Rea R
Tapete Do Piso / Floor Mat
Silenciador Frente / Sound Absorber Front
Silenciador Traseiro / Sound Absorber Rear
Placa De Isolamento / Insulation Plate
Cobertura Interior / Interior Cover
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Banco (Cobo Sc74/M91) [Excepção Alemanha] / Sea T (Cobo Sc74/M91) [Except Germany]
Banco (Grammer Msg83/8) [Alemanha] / Seat (Gram Mer Msg83/8) [Germany]
Banco (Kab Seating Xh2/P1) [Excepção Alemanha] / Seat (Kab Seating Xh2/P1) [Except Germany]
Banco (Kab Seating 11/P1) [Excepção Alemanha] / Seat (Kab Seating 11/P1) [Except Germany]
Banco (Sears Mcs3000) [Excepção Alemanha] / Sea T (Sears Mcs3000) [Except Germany]
Vidro Frente / Front Glass
Lado Vidro / Side Glass
Vidro Traseiro Da Escotilha / Hatch Back Glass
Dobradiça Do Vidro Traseiro Da Escotilha / Hatc H Back Glass Hinge
Air Condicionado / Air Co Nditioner
Cabo Do Ar Condicionado / Air Conditioner Cable
Tubo Dreno (Ar Condiciona Do) / Drain Hose (Air Conditioner)
Condesador / Condenser
Tubo Do Ar Condicionado / Air Conditioner Pipe
Compressor / Compressor
Tubo Ar Condicionado / Ai R-Conditioner Duct
Roda Frente (7-12) / Front Wheel (7 -12)
Roda Frente (24*8,50-12) / Front Wh Eel (24*8.50-12)
Roda Traseira (12,4-16) / Rear Whe El (12.4-16)
Roda Traseira (13,6-16) / Rear Whe El (13.6-16)
Etiqueta (Frente) [Excepção Italiano] / L Abel (Front) [Except Italian]
Etiqueta (Frente) [Italiano] / Label (Fro Nt) [Italian]
Etiqueta (Traseira) [Ingles] [Frances] / Label (Rear) [English] [French]
Etiqueta (Traseira) [Alemanha] [Espanhol] / Label (Rear) [German] [Spanish]
Etiqueta (Traseira) [Italiano] / Label (R Ear) [Italian]
A Cessorios E Peças Serviço / Accessories And Service Parts
Kit Do Alternador [Opção] / Alternator Kit [O Ption]
Alternador [Peças Componentes] [Opção] / Alte Rnator [Component Parts] [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wipe R Kit [Option]
Kit Cd-Rádio [Uk] [Opção] / Cd-Radio Kit [Uk] [Option]
Kit Da Tdf Intermédia (Para Cortador De Relva Rck60-30b-Eu-F) [Opção] / Mid Pto Kit (For Rck60-3 0b-Eu-F Mower) [Option]
Kit De Ligação 3-P 1 (Haste De Elevação) [Opç Ão] / 3-P Link Kit 1 (Lift Rod) [Option]
Kit De Ligação 3-P 2 (Ligação Inferior) [Opçã O] / 3-P Link Kit 2 (Lower Link) [Option]
Kit De Ligação 3-P 3 (Estabilizador) [Opção] / 3-P Link Kit 3 (Stabilizer) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [O Ption]
