Kubota Compact Tractor B2650HDB-C Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2650HDB-C Compact Tractor
Number of Pages: 283 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Ge Ar Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camsha Ft And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And G Low Plug
Bomba Agua E Termostacto / Water Flange An D Thermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (A Ir Cleaner)
Escpae / Muffler
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Compone Ntes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinha / Fa N
Tubo Agua / Wa Ter Pipe
Radiador / Rad Iator
Deposito Reser Va / Reserve Tank
Sensor Térmico E Interrup Tor Do Óleo / Oil Switch And Thermo Sensor
Alternador / Alternator
Alternador [Peças Compone Ntes] / Alternator [Component Parts]
Motor Arranque / Starter
Comutador / Switch
Rele / Relay
Painel / Panel Board
Tampa Interruptor / Panel Switch
Farol Frente / Head Light
Luzes Frontais / Front Co Mbination Lamp
Braco Traseiro / Rear Com Bination Lamp
Ficha Reboque / Trailer S Ocket
Luzes Trabalho / Working Light
Luz Interior / Room Light
Painel Controlo Air Condi Cionado/Relé / Air-Con.Control Panel/Relay
Antena/Coluna / Antenna/S Peaker
Depósito De Lavagem / Was Her Tank
Limpa-Pára-Brisas (Diante Iro) / Wiper (Front)
Cablagem Electrica (Corpo ) / Electrical Wiring (Body)
Cabalagem Eletrica (Cabin E) / Electrical Wiring (Cab)
Tampa Da Caixa De Embraiagem / Clutch Housi Ng Cover
Suporte Eixo Frente / Front Axle Fr Ame
Carter Eixo Frente / Front Axle Cas E
Diferencial Dianteiro / Front Diffe Rential
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel G Ear Rh
Carter Grupo Conico / Bevel Gear Ca Se
Carter Eixo Frente Esq / Front Axle Case Lh
Carter Eixo Frente Drt / Front Axle Case Rh
Eixo Dianteiro / Front Axle Lh
Veio Eixo / Front Drive Shaft
Hst (Caixa) [Peças Componentes] 1 / H St (Case) [Component Parts] 1
Hst (Bomba) (Bloco Do Cilindro) [Peça S Componentes] 2 / Hst (Pumpe) [Component Parts] 2
Hst (Motor) [Peças Componentes] 3 / H St (Motor) [Component Parts] 3
Hst (Tampa Do Bloco De Abertura) [Peç As Componentes] 4 / Hst (Port Block Cover) [Compone Nt Parts] 4
Hst (Soporte Neutral) [Peças Compone Ntes] 5 / Hst (Neutral Holder) [Component Parts] 5
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Gear S Haft
Inversor / Reverse Shaft
Tdf / Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clutch S Haft
Tdf Central / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Different Ial
Forqueta Velocidades / Range G Ear Shift Fork
Braço De Mudança De Velocidade Tdf / Pto Gear Shift Arm
Alavanca / Differential Lock S Hift Fork
Pedal Acelarador / Speed Chang E Pedal
Tirante De Mudança De Velocida De / Speed Control Rod
Alavanca Velocidades / Range G Ear Shift Lever
Control Velocidade / Cruise Co Ntrol Lever
Cabo De Desengate Da Velocidad E De Cruzeiro / Cruise Release Cable
Alavanca Control Posicao / Pos Ition Control Lever
Alavanca Da Válvula Do Carrega Dor [Kdg] / Loader Valve Lever [Kdg]
Pedal Travao / Brake Pedal
Bloqueio Diferencial / Differe Ntial Lock Pedal
Biela Bi-Speed / Bi-Speed Shif T Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao (Frente) / Brake Rod (Front)
Tirante Travao (Traseira) / Brake Rod (Rear)
Braço Bi-Speed / Bi-Speed Turn Arm
Pedal Inclinacao / Tilt Pedal
Direcção / Steering Contoroller
Cilindro Direcção [Peças Componentes] / Ste Ering Cylinder [Component Parts]
Bomba Hidraulico / Hy Draulic Pump
Linha Aspiração (Sucç Ão) / Hydraulic Pipe (Suction)
Tubo Oleo (Entrega) / Hydraulic Oil Line (Delivery)
Circuito Oleo (Direcç Ão) / Hydraulic Oil Line (Steering)
Tubo Oleo (Hst) / Hyd Raulic Oil Line (Hst)
Radiador Oleo (Radiad Or Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Válvula Do Carregador / Loader Valve
Válvula Do Carregador [Peças Componentes] / Loader Valve [Component Part S]
Elo Da Válvula Do Car Regador / Loader Valve Link
Tubo Do Carregador Hi Dráulico / Hydraulic Loader Pipe
Piston Hidraulico / B Raços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Lever
Valvula Control / Con Trol Valve
Valvula Control [Peça S Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Que Da / Fall Adjustment Shaft
Válvula Tdf / Pto Val Ve
Válvula Tdf [Peças Co Mponentes] / Pto Valve [Component Parts]
Ti Rante / Lift Rod
Li Gacao Inferior / Lower Link
Li Gacao Superior / Top Link
Co Rrente Seguranca / Check Chain
Ba Rra Reboque / Drawbar
Pu Xo / Front Hitch
Pu Xo Traseiro / Rear Hitch
Pr Oteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Painel Lateral / Side Cover
Placa / Shutter Plate
Banco(Grammer Msg83/511) / Seat(Grammer Msg 83/511)
Banco(Grammer Msg93/511) / Seat(Grammer Msg 93/511)
Banco(Sears 807) / Seat(Sears 807)
Estrutura Cabine / Cab Frame
Assento Por Baixo Da Cobertura / Seat Under Cover
Guarda Lamas / Over Fender
Cobertura / Tail Cover
Porta Drt / Door Rh
Tejadilho Interior / Inner Roof
Tejadilho Exterior / Outer Roof
Dianteira Do Suporte Da Cabine / Cab Bracket Front
Traseira Do Suporte Da Cabine / Cab Bracket Rear
Tapete Do Piso / Floor Mat
Silenciador / Sound Absorber
Cobertura Interior / Interior Cover
Guia Drt / Lever Guide Rh
Vidro Frente E Traseiro / Front Glass
Vidro Traseiro Da Escotilha / Hatch Back Glass
Dobradiça Do Vidro Traseiro Da Escotilha / Hatch B Ack Glass Hinge
Air Condicionado / Air Condi Tioner
Tubo Ar Condicionado (Air Co Ndicionado) / Drain Hose (Air Conditioner)
Condesador / Condenser
Tubo Do Ar Condicionado / Ai R Conditioner Pipe
Tubo Aquecimento / Heater Ho Se
Compressor / Air Compressor
Tubo Ar Condicionado / Air-C Onditioner Duct
Roda Frente (6-12b) / Front Wheel (6- 12b)
Roda Frente (6-12) / Front Wheel (6-1 2)
Roda Frente (6,00-12) / Front Wheel ( 6.00-12)
Roda Frente (22*8,50-12) / Front Whee L (22*8.50-12)
Roda Frente (24*8,50-12) / Front Whee L (24*8.50-12)
Roda Traseira (8-16) / Rear Wheel (8 -16)
Roda Traseira (9,5-16) / Rear Wheel (9.5-16)
Roda Traseira (9,5-18) / Rear Wheel (9.5-18)
Roda Traseira (31*13,5-15) / Rear Wh Eel (31*13.5-15)
Roda Traseira (315/75d-15) / Rear Wh Eel (315/75d-15)
Aces Sorios E Peças Serviço / Accessories And Service Pa Rts
Kit Limpa Vidro Traseiros [Opcao] / Rear Wiper K It [Option]
Kit De Tubo [Option] / Tube Kit [Option]
Cilindro Elevação (Braços) [Opcao] / Mower Lift Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opcao] / Mower Lif T Cylinder Kit (Cylinder) [Option]
Frente Hidráulico Tomada Kit [Opcao] / Front Hyd Raulic Outlet Kit [Option]
Carreto / Gear Case
Escpae / Muffler
Ventoinha / Fa N
Comutador / Switch
Rele / Relay
Ti Rante / Lift Rod
Pu Xo / Front Hitch
Porta Drt / Door Rh
