Kubota Compact Tractor B2530HDBC Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2530HDBC Compact Tractor
Number of Pages: 395 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gea R Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaf T And Governor Shaft
Ponto Neutro / Idle Apparatus
Vela Pre Aquecimento / Nozzle Holder And Gl Ow Plug
Suporte Bico [Peças Componentes] / Nozzle H Older [Component Parts]
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao / Inlet Pipe
Escpae / Muffler
Tubo Combustivel / Fuel Pip E
Filtro Gasoleo / Fuel Filte R
Filtro Gasoleo [Peças Compo Nentes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Tubo Agua / Water Pipe
Sensor Térmico E Interrupt Or Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Stop S Olenoid
Alternador / Alternator
Alternador [Peças Componen Tes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Comp Onentes] / Starter [Component Parts]
Interruptor / Switch
Rele / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Tampa Interruptor / Panel Switch
Farol Frente [Uk] / Head L Ight [Uk]
Farol Frente [Ec] / Head L Ight [Ec]
Luzes Frontais / Front Com Bination Lamp
Braco Traseiro / Rear Comb Ination Lamp
Farol Matricula [Uk] / Lic Ense Lamp [Uk]
Farol Matricula[Uk] / Lice Nse Lamp [Uk]
Farol Matricula [Ec] / Lic Ense Lamp [Ec]
Ficha Reboque / Trailer So Cket
Luzes Trabalho / Working L Ight
Painel Controlo Air Condic Ionado / Air-Con.Control Panel
Depósito De Lavagem / Wash Er Tank
Escova Limpa Vidros / Wipe R
Cablagem Electrica (Versao ) / Electrical Wiring (Body)
Cabalagem Eletrica(Cabine) [Uk] / Electrical Wiring (Cab) [Uk]
Cabalagem Eletrica(Cabine) [Ec] / Electrical Wiring (Cab) [Ec]
Tampa Da Caixa De Embraiagem / Clutch Housin G Cover
Hst / Hst
Hst (Bloco Do Cilindro) [Peças Compon Entes] 1 / Hst (Cylinder Block) [Component Parts] 1
Hst (Tampa Do Bloco De Abertura) [Peç As Componentes] 2 / Hst (Port Block Cover) [Compone Nt Parts] 2
Hst (Junta) [Peças Componentes] 3 / H St (Gasket) [Component Parts] 3
Hst (Fixador Do Neutro) [Peças Compon Entes] 4 / Hst (Neutral Holder) [Component Parts] 4
Primeiro Veio / First Shaft
Terceiro Veio / Third Shaft
Veio Gamas Velocidades / Range Gear S Haft
Inversor / Reverse Shaft
Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clutch S Haft
Tdf Intermédia / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Different Ial
Forqueta Velocidades / Rang E Gear Shift Fork
Braço De Mudança De Velocid Ade Tdf / Pto Gear Shift Arm
Bloqueio Diferencial Forque Ta / Differential Lock Shift Fork
Braço De Desengate Hst / Hs T Release Arm
Alavanca Velocidades / Rang E Gear Shift Lever
Alavanca Dupla Traccao / Fr Ont Wheel Drive Lever
Alavanca Tdf / Pto Gear Shi Ft Lever
Bloqueio Diferencial / Differential Lo Ck Pedal
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Pedal Travao / Brake Pedal
Tirante De Mudança De Velocidade / Speed Ch Ange Rod
Haste De Desativação Da Velocidade De Cruze Iro / Cruise Release Rod
Control Velocidade / Cruise Control Lever
Valvula Control / Remo Te Control Lever
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico [Peça S Componentes] / Hydraulic Pump [Component Parts]
Circuito Oleo (Sucção) / Hydraulic Oil Line(Suction)
Circuito Oleo (Entrega ) / Hydraulic Oil Line(Delivery)
Circuito Oleo (Direcçã O) / Hydraulic Oil Line(Steering)
Circuito Oleo (Hst) / Hydraulic Oil Line (Hst)
Circuito Oleo (Radiado R Oleo) / Hydraulic Oil Line (Oil Cooler)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Piston Hidraulico / Br Aços / Hydraulic Piston/Lift Arm
Alavanca / Feed Back L Ever
Valvula Control / Cont Rol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar [Peças Componentes] / Remote Control Valve [Compone Nt Parts]
Veio De Ajuste Da Qued A / Fall Adjustment Shaft
Valvula Descarga / Rel Ief Valve
Válvula Tdf / Pto Valv E
Válvula Tdf [Peças Com Ponentes] / Pto Valve [Component Parts]
Tirante / Lift Rod
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Suporte Eixo Frente / Front Axle Fra Me
Diferencial Dianteiro / Front Differ Ential
Engrenagem Cónica Esquerda / Bevel G Ear Lh
Engrenagem Cónica Direita / Bevel Ge Ar Rh
Carter Grupo Conico / Bevel Gear Cas E
Carter Eixo Frente Esq / Axle Case L H
Carter Eixo Frente Drt / Axle Case R H
Eixo Dianteiro Esq / Front Axle Lh
Veio Eixo / Front Drive Shaft
Alavanca / Tilt Lever
Cilindro Direcção [Peças Componentes] / Stee Ring Cylinder [Component Parts]
Ligacao Inferior / Lower L Ink
Ligacao Superior / Top Lin K
Corrente Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo / Front Hitch
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protec Tor
Grelha Frontal / Front Grille
Capot Superior / Bonnet
Painel Lateral / Side Cover
Placa / Shutter Plate
Pilar Central / Center Pillar
Estrutura Cabine / Cab
Painel Inferior / Panel Cover
Assento Por Baixo Da Cobertura / Seat Under Cover
Cobertura Do Guarda-Lamas / Fender Cover
Guarda Lamas / Fender
Cobertura / Tail Cover
Porta Esq / Door Lh
Porta Drt / Door Rh
Tejadilho Interior / Inner Roof
Tejadilho Exterior / Outer Roof
Dianteira Do Suporte Da Cabine / Cab Bracket Front
Traseira Do Suporte Da Cabine / Cab Bracket Rear
Tapete Do Piso / Floor Mat
Silenciador / Sound Absorber
Silenciador Traseiro / Sound Absorber Rear
Placa De Isolamento / Insulation Plate
Cobertura Interior / Interior Cover
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Banco (Cobo Sc74/M91) [Excepção Alemanha] / Seat (C Obo Sc74/M91) [Except Germany]
Banco (Grammer Msg83/8) [Alemanha] / Seat (Grammer Msg83/8) [Germany]
Banco (Kab Seating Xh2/P1) [Excepção Alemanha] / Se At (Kab Seating Xh2/P1) [Except Germany]
Banco (Kab Seating 11/P1) [Excepção Alemanha] / Sea T (Kab Seating 11/P1) [Except Germany]
Banco (Sears Mcs3000) [Excepção Alemanha] / Seat (S Ears Mcs3000) [Except Germany]
Vidro Frente E Traseiro / Front Glass And Rear Glas S
Lado Vidro / Side Glass
Vidro Traseiro Da Escotilha / Hatch Back Glass
Dobradiça Do Vidro Traseiro Da Escotilha / Hatch Ba Ck Glass Hinge
Air Condicionado / Air Condit Ioner
Cabo Do Ar Condicionado / Air Conditioner Cable
Tubo Dreno (Ar Condicionado) / Drain Hose(Air Conditioner)
Condesador / Condenser
Tubo Aquecimento / Heater Hos E
Compressor / Compressor
Tubo Ar Condicionado / Air-Co Nditioner Duct
Roda Frente (6,00-12) / Front Wheel (6. 00-12)
Roda Frente (24*8,50-12) / Front Wheel (24*8.50-12)
Roda Frente(6-12b) [Opção] / Front Whee L (6-12b) [Option]
Roda Frente (6-12) [Opção] / Front Whee L (6-12) [Option]
Roda Frente (22*8,50-12) [Opção] / Fron T Wheel (22*8.50-12) [Option]
Roda Traseira (9,5-18) / Rear Wheel (9 .5-18)
Roda Traseira (315/75d-15) / Rear Whee L (315/75d-15)
Roda Traseira (8-16) [Opção] / Rear Wh Eel (8-16) [Option]
Roda Traseira (9,5-16) [Opção] / Rear Wheel (9.5-16) [Option]
Roda Traseira (31*13,5-15) [Opção] / R Ear Wheel (31*13.5-15) [Option]
Etiqueta (Frente) [Excepção Italiano] / Label (Front) [Except Italian]
Etiqueta (Frente) [Italiano] / Label (Front) [Italian]
Etiqueta (Traseira) [Ingles] [Frances] / Labe L (Rear) [English] [French]
Etiqueta (Traseira) [Alemão] [Espanhol] / Lab El (Rear) [German] [Spanish]
Etiqueta (Traseira) [Italiano] / Label (Rear) [Italian]
Acess Orios E Peças Serviço / Accessories And Service Par Ts
Kit Do Alternador [Opção] / Alternator Kit [Optio N]
Alternador [Peças Componentes][Opção] / Alternato R [Component Parts] [Option]
Kit Limpa Vidro Traseiros [Opção] / Rear Wiper Ki T [Option]
Kit Cd-Rádio [Uk] [Opção] / Cd-Radio Kit [Uk] [Op Tion]
Kit Da Tdf Intermédia (Para Cortador De Relva Rck 54/Rck60-25b-Eu-F) [Opção] / Mid Pto Kit(For Rck54/ Rck60-25b-Eu-F Mower) [Option]
Cilindro Elevação (Elevação Braço) [Opção] / Mowe R Lift Cylinder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas[Opção] / Front Weight Kit [Option ]
