Kubota Compact Tractor B2530HDB Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2530HDB Compact Tractor
Number of Pages: 347 Pages
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft And G Overnor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Holder [ Component Parts]
Bomba Agua E Termostacto / Water Flange And Thermo Stat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air Clean Er)
Escpae / Muffler
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Compon Entes] / Fuel Filter [Component Parts]
Bomba Gasoleo (Mecânica) / F Uel Pump (Mechanical)
Ventoinha / Fan
Tubo Agua / Water Pipe
Deposito R Eserva / Reserve Tank
Sensor Térmico E Interrupto R Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Stop So Lenoid
Alternador / Alternator
Motor Arranque / Starter
Motor Arranque [Peças Compo Nentes] / Starter [Component Parts]
Interruptor / Switch
Relé / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Tampa Interruptor / Panel S Witch
Farol Frente [Uk] / Head Li Ght [Uk]
Farol Frente [Ec] / Head Li Ght [Ec]
Luzes Frontais / Front Comb Ination Lamp
Braco Traseiro / Rear Combi Nation Lamp
Farol Matricula [Uk] / Lice Nse Lamp [Uk]
Farol Matricula [Ec] / Lice Nse Lamp [Ec]
Ficha Reboque / Trailer Soc Ket
Cablagem Electrica / Electr Ical Wiring
Tampa Da Caixa De Embraiagem / Clutch Housing Cover
Suporte Eixo Frente / Front Axle Fram E
Diferencial Dianteiro / Front Differe Ntial
Engrenagem Cónica Esquerda / Bevel Ge Ar Lh
Engrenagem Cónica Direita / Bevel Gea R Rh
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Front Axle C Ase Lh
Carter Eixo Frente Drt / Front Axle C Ase Rh
Veio Eixo / Front Drive Shaft
Diferencial / Differential Gear Case # # N.º De Série<=82491 S.No.;<=82491 / S.No.<=82491 S.No.;<=82491
Diferencial / Differential Gear Case # # N.º De Série>=90001 S.No.;>=90001 / S.No.>=90001 S.No.;>=90001
Carter Eixo Traseiro Esq / Rear Axle C Ase Lh
Carter Eixo Traseiro Drt / Rear Axle C Ase Rh
Hst / Hst
Hst (Bloco Do Cilindro) [Peças Compone Ntes] 1 / Hst (Cylinder Block) [Component Parts] 1
Hst (Tampa Do Bloco De Abertura) [Peça S Componentes] 2 / Hst (Port Block Cover) [Componen T Parts] 2
Hst (Junta) [Peças Componentes] 3 / Hs T (Gasket) [Component Parts] 3
Hst (Fixador Do Neutro) [Peças Compone Ntes] 4 / Hst (Neutral Holder) [Component Parts] 4
Veio Gamas Velocidades / Range Gear Sh Aft
Inversor / Reverse Shaft
Veio Tdf / Pto Drive Shaft
Veio Da Embraiagem Tdf / Pto Clutch Sh Aft
Tdf Intermédia / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Differenti Al
1 Velocidade / 1st Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
Forqueta Velocidades / Range Gear Shift Fork
Braço De Mudança De Velocida De Tdf / Pto Gear Shift Arm
Alavanca / Differential Lock Shift Fork
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Tirante De Mudança De Velocidade / Speed Cha Nge Rod
Haste De Desativação Da Velocidade De Cruzei Ro / Cruise Release Rod
Braço De Desengate Hst / Hst Release Arm
Alavanca Velocidades / Range Gear Shift Leve R
Alavanca Dupla Traccao / Front Wheel Drive L Ever
Control Velocidade / Cruise Control Lever
Alavanca Control Posicao / Position Control Lever
Valvula Control / Remote Control Lever
Pedal Travao / Brake Pedal
Bloqueio Diferencial / Differential Lock Ped Al
Braço Bi-Speed / Bi-Speed Turn Arm
Biela Bi-Speed / Bi-Speed Shift Rod
Veio Bi-Speed Turn / Bi-Speed Turn Shaft
Alavanca / Tilt Lever
Cilindro Direcção [Peças Componentes] / Steer Ing Cylinder [Component Parts]
Bomba Hidraulico / Hydr Aulic Pump
Tubo Oleo Hidraulico (F Ornecimento) / Hydraulic Oil Line (Delivery)
Tubo Oleo Hidraulico (D Irecção) / Hydraulic Oil Line (Steering)
Tubo Oleo Hidraulico (H St) / Hydraulic Oil Line (Hst)
Tubo Oleo Hidraulico (O Leo Refrigerador) / Hydraulic Oil Line (Oil Cooler)
Tubo Oleo Hidraulico (F /M) / Hydraulic Oil Line (F/M)
Cilindro Hidraulico / H Ydraulic Cylinder
Piston Hidraulico/Braço S / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Le Ver
Valvula Control / Contr Ol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Distribuidor Auxiliar / Remote Control Valve
Distribuidor Auxiliar [ Peças Componentes] / Remote Control Valve [Componen T Parts]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Valvula Descarga / Reli Ef Valve
Válvula Tdf / Pto Valve
Válvula Tdf [Peças Comp Onentes] / Pto Valve [Component Parts]
Tirante / Lift Rod
Ligacao Inferior / Lower L Ink
Ligacao Superior / Top Lin K
Corrente Seguranca / Check Chain
Barra Reboque / Drawbar
Puxo Dianteiro / Front Hit Ch
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protec Tor
Grelha Frontal / Front Grille
Capot Superior / Bonnet
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Espelho Rectrovisor [Uk] / Rearview Mirror [U K]
Espelho Rectrovisor [Ec] / Rearview Mirror [E C]
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco (Cobo Sc74/M91) [Excepção Alemanha] / S Eat (Cobo Sc74/M91) [Except Germany]
Banco (Grammer Msg83/8) [Alemanha] / Seat (Gr Ammer Msg83/8) [Germany]
Banco (Kab Seating Xh2/P1) [Excepção Alemanha ] / Seat (Kab Seating Xh2/P1) [Except Germany]
Banco (Kab Seating 11/P1) [Excepção Alemanha] / Seat (Kab Seating 11/P1) [Except Germany]
Banco (Sears Mcs3000) [Excepção Alemanha] / S Eat (Sears Mcs3000) [Except Germany]
Degrau / Step
Cobertura / Tail Cover
Arco / Rops
Roda Frente (6,00-12) / Front Wheel (6.0 0-12)
Roda Frente (24*8,50-12) / Front Wheel ( 24*8.50-12)
Roda Frente (6-12b) [Opção] / Front Whee L (6-12b) [Option]
Roda Frente (6-12) [Opção] / Front Wheel (6-12) [Option]
Roda Frente (22*8,50-12) [Opção] / Front Wheel (22*8.50-12) [Option]
Roda Traseira (9,5-18) / Rear Wheel (9. 5-18)
Roda Traseira (315/75d-15) / Rear Wheel (315/75d-15)
Roda Traseira (8-16) [Opção] / Rear Whe El (8-16) [Option]
Roda Traseira (9,5-16) [Opção] / Rear W Heel (9.5-16) [Option]
Roda Traseira (31*13,5-15) [Opção] / Re Ar Wheel (31*13.5-15) [Option]
Etiqueta (Frente) [Excepção Italiano] / Label (Front) [Except Italian]
Etiqueta (Frente) [Italiano] / Label (Front) [ Italian]
Etiqueta (Traseira) [Ingles] [Frances] / Label (Rear) [English] [French]
Etiqueta (Traseira) [Alemão] [Espanhol] / Labe L (Rear) [German] [Spanish]
Etiqueta (Traseira) [Italiano] / Label(Rear) [ Italian]
Acesso Rios E Peças Serviço / Accessories And Service Part S
Roda Intermedia [Opção] / Front Winker Stay Kit [O Ption]
Kit Luzes Trabalho [Opção] / Working Light Kit [Op Tion]
Kit Da Tdf Intermédia (Para Cortador De Relva Rck5 4/Rck60-25b-Eu-F) [Opção] / Mid Pto Kit (For Rck54/ Rck60-25b-Eu-F Mower) [Option]
Cilindro Elevação (Braços) [Opção] / Mower Lift Cy Linder Kit (Lift Arm) [Option]
Cilindro Elevação (Cilindro) [Opção] / Mower Lift Cylinder Kit (Cylinder) [Option]
Kit Pesos Rodas [Opção] / Front Weight Kit [Option ]
