Kubota Compact Tractor B2530D Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2530D Compact Tractor
Number of Pages: 325 Pages
Itens Uso Frequente / F Requently Used Items
Bloco Motor / Crankcase
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle Gear S Haft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camshaft A Nd Governor Shaft
Ponto Neutro / Idle Apparatus
Suporte Bico [Peças Componentes] / Nozzle Hold Er [Component Parts]
Bomba Agua E Termostacto / Water Flange And Th Ermostat
Bomba Agua / Water Pump
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe (Air C Leaner)
Escpae / Muffler
Acelarador Pedal / Accelerator Pedal
Deposito Combustivel / Fuel Ta Nk
Tubo Combustivel / Fuel Pipe
Filtro Gasoleo / Fuel Filter
Filtro Gasoleo [Peças Componen Tes] / Fuel Filter [Component Parts]
Bomba Gasoleo / Fuel Pump
Ventoinha / Fan
Tubo Agua / Water Pipe
Radiador / R Adiator
Sensor Térmico E Interruptor Do Óleo / Oil Switch And Thermo Sensor
Valvula Solenoide / Stop Sole Noid
Alternador / Alternator
Alternador [Peças Componentes ] / Alternator [Component Parts]
Motor Arranque / Starter
Comutador / Switch
Rele' / Relay
Painel / Panel Board
Painel [Peças Componentes] / Panel Board [Component Parts]
Tampa Interruptor / Panel Swi Tch
Farol Frente [Uk] / Head Ligh T [Uk]
Farol Frente [Ec] / Head Ligh T [Ec]
Luzes Frontais / Front Combin Ation Lamp
Braco Traseiro / Rear Combina Tion Lamp
Farol Matricula [Uk] / Licens E Lamp [Uk]
Farol Matricula [Ec] / Licens E Lamp [Ec]
Ficha Reboque / Trailer Socke T
Cablagem Electrica / Electric Al Wiring
Embraiagem / Clutch
Embraiagem / Clutch Rod
Diferencial Dianteiro / Front Different Ial
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Grupo Conico / Bevel Gear Case
Carter Eixo Frente Esq / Front Axle Cas E Lh
Carter Eixo Frente Drt / Front Axle Cas E Rh
Eixo Dianteiro Esq / Front Axle Lh
Veio De Transmissão (Dianteiro) / Drive Shaft (Front)
Veio De Transmissão (Traseiro) / Drive Shaft (Rear)
Carter Eixo Traseiro Esq / Rear Axle Cas E Lh
Carter Eixo Traseiro Drt / Rear Axle Cas E Rh
Engrenagem Principal / Main Gear Shaft # # Note:Order By Ref.No.010,080,110 New Parts. / Not E:Order By Ref.No.010,080,110 New Parts.
Veio Gamas Velocidades / Range Gear Shaf T
Inversor 1 / Reverse Shaft 1
Inversor 2 / Reverse Shaft 2
Veio Inversor / Shuttle Shaft
Tdf / Veio Tdf / Pto Drive Shaft
Tdf / Veio Tdf / Pto Gear Shift Shaft
Tdf Intermédia / Mid Pto
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Differential
Forqueta Mudança / Main Gear S Hift Fork
Forquilha Inversor / Shuttle S Hift Fork
Forquilha Inversor / Shuttle S Hift Rod
Forqueta Velocidades / Range G Ear Shift Fork
Alvanca Tdf / Pto Gear Shift F Ork
Braço De Mudança De Velocidade Tdf / Pto Gear Shift Arm
Alavanca / Differential Lock S Hift Fork
T Ravão Direita / Brake Rh
T Irante Travao / Brake Rod
T Ravao Parque / Parking Brake Lever
Alavanca Velocidades / Main Gear Shift Lever
Alavanca Velocidades / Range Gear Shift Lever
Alavanca Dupla Traccao / Front Wheel Drive Lev Er
Alavanca Control Posicao / Position Control Le Ver
Avalanca Control Valvula / Remote Control Leve R
Pedal Travao / Brake Pedal
Alavanca / Tilt Lever
Direcção Controlador / Steering Controller
Cilindro Direcção [Peças Componentes] / Steerin G Cylinder [Component Parts]
Bomba Hidraulico / Hydrau Lic Pump
Bomba Hidraulico [Peças C Omponentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucção) / Hydraulic Oil Line (Suction)
Circuito Oleo (Direcção) / Hydraulic Oil Line (Steering)
Cilindro Hidraulico / Hyd Raulic Cylinder
Piston Hidraulico / Braço S / Hydraulic Piston/Lift Arm
Alavanca / Feed Back Leve R
Valvula Control [Peças Co Mponentes] / Control Valve [Component Parts]
Distribuidor Auxiliar / R Emote Control Valve
Distribuidor Auxiliar [Pe Ças Componentes] / Remote Control Valve [Component Parts]
Veio De Ajuste Da Queda / Fall Adjustment Shaft
Valvula Descarga / Relief Valve
Tirante / Lift Rod
Ligacao Inferior / Lower Lin K
Corrente Seguranca / Check C Hain
Barra Reboque / Drawbar
Puxo Dianteiro / Front Hitch
Puxo Traseiro / Rear Hitch
Proteccao Tdf / Pto Protecto R
Grelha Frontal / Front Grille
Capot Superior / Bonnet (Hood)
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Placa / Shutter Plate
Espelho Rectrovisor [Uk] / Rearview Mirror [Uk]
Espelho Rectrovisor [Ec] / Rearview Mirror [Ec]
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco (Cobo Sc74/M91) [Excepção Alemanha] / Sea T (Cobo Sc74/M91) [Except Germany]
Banco (Grammer Msg83/8) [Alemanha] / Seat (Gram Mer Msg83/8) [Germany]
Banco (Kab Seating Xh2/P1) [Excepção Alemanha] / Seat (Kab Seating Xh2/P1) [Except Germany]
Banco (Kab Seating 11/P1) [Excepção Alemanha] / Seat (Kab Seating 11/P1) [Except Germany]
Banco (Sears Mcs3000) [Excepção Alemanha] / Sea T (Sears Mcs3000) [Except Germany]
Degrau / Step
Cobertura / Tail Cover
Arco / Rops
Roda Frente (6-12b) / Front Wheel (6-12b)
Roda Frente (6-12) / Front Wheel (6-12)
Roda Frente (6,00-12) / Front Wheel (6.00- 12)
Roda Frente (22*8,50-12) / Front Wheel (22 *8.50-12)
Roda Frente (24*8,50-12) / Front Wheel (24 *8.50-12)
Roda Traseira (8-16) / Rear Wheel (8-16)
Roda Traseira (9,5-16) / Rear Wheel (9.5- 16)
Roda Traseira (315/75d-15) / Rear Wheel ( 315/75d-15)
Etiqueta (Frente) [Excepção Italiano] / Label (F Ront) [Except Italian]
Etiqueta (Frente) [Italiano] / Label (Front) [It Alian]
Etiqueta (Traseira) [Ingles] [Frances] / Label ( Rear) [English] [French]
Etiqueta (Traseira) [Alemão] [Espanhol] / Label (Rear) [German] [Spanish]
Etiqueta (Traseira) [Italiano] / Label (Rear) [I Talian]
Acessori Os E Peças Serviço / Accessories And Service Parts
F Rente Suspensão [Opção] / Front Winker Stay Kit [Op Tion]
K It Luzes Trabalho [Opção] / Working Light Kit [Opti On]
K It Da Tdf Intermédia (Para Cortador De Relva Rck54/ Rck60-25b-Eu-F) [Opção] / Mid Pto Kit (For Rck54/Rc K60-25b-Eu-F Mower) [Option]
C Ilindro Elevação (Braços) [Opção] / Mower Lift Cyli Nder Kit (Lift Arm) [Option]
C Ilindro Elevação (Cilindro) [Opção] / Mower Lift Cy Linder Kit (Cylinder) [Option]
K It De Peso Dianteiro [Opção] / Front Weight Kit [Op Tion]
