Kubota Compact Tractor B2420D-M B2420D-M2 Spare Parts Catalog EN PT
Language: English, Portuguese
Model: Kubota B2420D-M ; B2420D-M2 Compact Tractor
Number of Pages: 233 Pages
Bloco Motor / Crank Case
Carter Oleo / Oil Pan
Cabeca Motor / Cylinder Head
Carreto / Gear Case
Tampa Cabeça / Head Cover
Filtro Oleo / Oil Filter
Arvore Cames E Veio / Camshaft And Idle G Ear Shaft
Volante Motor / Flywheel
Veio Combustivel E Regulador / Fuel Camsh Aft And Governor Shaft
Ponto Neutro / Idle Apparatus
Regulador Velocidade / Speed Control Plat E
Bomba Agua E Termostacto / Water Flange A Nd Thermostat
Bomba Agua / Water Pump
Valvula E Veio Martelos / Valve And Rocke R Arm
Filtro Ar / Air Cleaner
Tubo Aspiracao (Filtro Ar) / Inlet Pipe ( Air Cleaner)
Escpae / Muffler
Deposito Combustivel / Fu El Tank
Tubo Combustivel / Fuel P Ipe
Filtro Gasoleo / Fuel Fil Ter
Filtro Gasoleo [Peças Com Ponentes] / Fuel Filter [Component Parts]
Bomba Gasoleo (Mecanico) / Fuel Pump (Mechanical)
Ventoin Ha / Fan
Tubo Ag Ua / Water Pipe
Radiado R / Radiator
Deposit O Reserva / Reserve Tank
Sensor Térmico E Interru Ptor Do Óleo / Oil Switch And Thermo Sensor
Alternador / Alternator
Alternador [Peças Compon Entes] / Alternator [Component Parts]
Motor Arranque / Starter
Motor Arranque [Peças Co Mponentes] / Starter [Component Parts]
Comutador / Switch
Rele / Relay
Painel / Panel Board
Painel [Peças Componente S] / Panel Board [Component Parts]
Tampa Interruptor / Pane L Switch
Farol Frente / Head Ligh T
Braco Traseiro / Rear Co Mbination Lamp
Lampada / Winker Lamp
Farol Matricula / Licens E Lamp
Cablagem Electrica / Ele Ctrical Wiring
Tampa Da Caixa De Embraiagem / Clutch Hous Ing Cover
Suporte Eixo Frente / Front Axle F Rame
Carter Eixo Frente / Front Axle Ca Se
Diferencial Dianteiro / Front Diff Erential
Engrenagem Cónica Esquerda / Bevel Gear Lh
Engrenagem Cónica Direita / Bevel Gear Rh
Carter Grupo Conico / Bevel Gear C Ase
Carter Eixo Frente Esq / Front Axl E Case Lh
Carter Eixo Frente Drt / Front Axl E Case Rh
Eixo Dianteiro Esq / Front Axle Lh
Caixa Velocidades / Transmission Ca Se
Diferencial / Differential Gear Cas E
Carter Eixo Traseiro Esq / Rear Axl E Case Lh
Carter Eixo Traseiro Drt / Rear Axl E Case Rh
Veio Primario / Front Shaft
Veio Tdf / Pto Shaft
Grupo Conico / Range Gear
Diferencial Traseiro / Rear Differe Ntial
Veio Tracao Dianteira / Front Wheel Propeller Shaft
2 Velocidade / 2nd Shaft
3 Velocidade / 3rd Shaft
4 Velocidade / 4th Shaft
Forqueta / Main Gear Shif T Fork
Forqueta Velocidades / Ra Nge Gear Shift Fork
Alvanca Tdf / Pto Gear Sh Ift Fork
Alavanca / Differential L Ock Shift Fork
Eixo Traseiro Esquerda / Rear Axle L H
Travão Esquerda / Brake Lh
Travão Direita / Brake Rh
Tirante Travao / Brake Rod
Alavanca Velocidades / Main Gear Shift Le Ver
Alavanca Velocidades / Range Gear Shift L Ever
Alavanca Dupla Traccao / Front Wheel Driv E Lever
Alavamca De Controle / Hydraulic Control Lever
Pedal Travao / Brake Pedal
Braço Da Articulação / Knuckle Arm
Ligação / Drag Link
Direcção Assistida / Tie Rod
Bomba Hidráulica (Ps) / Hydraulic Pump (Ps)
Bomba Hidraulico (Orbi Tol) [Peças Componentes] / Hydraulic Pump (Ps) [Com Ponent Parts]
Bomba Hidraulico / Hyd Raulic Pump
Bomba Hidraulico [Peça S Componentes] / Hydraulic Pump [Component Parts]
Linha Aspiração (Sucçã O) / Hydraulic Oil Line (Suction)
Tubo Oleo (Entrega) / Hydraulic Oil Line (Delivery)
Circuito Oleo (Direcçã O) / Hydraulic Oil Line (Steering)
Circuito Oleo (F/M) / Hydraulic Oil Line (F/M)
Piston Hidraulico/Braç Os / Hydraulic Piston/Lift Arm
Alavanca / Feed Back L Ever
Valvula Control / Cont Rol Valve
Valvula Control [Peças Componentes] / Control Valve [Component Parts]
Veio De Ajuste Da Qued A / Fall Adjustment Shaft
3 -Pont Acoplamento (Tirante) / 3-Point Linkage (Lift Rod)
L Igacao Inferior / Lower Link
3 -Pont Acoplamento (Ligacao Superior) / 3-Point Link Age (Top Link)
C Orrente Seguranca / Check Chain
B Arra Reboque / Drawbar
P Uxo / Front Hitch
P Uxo Traseiro / Rear Hitch
P Roteccao Tdf / Pto Protector
Grelha Frontal / Front Grille
Tampa Painel / Panel Cover
Painel Lateral / Side Cover
Pilar Central / Center Pillar
Guia Esq / Lever Guide Lh
Guia Drt / Lever Guide Rh
Guarda Lamas / Fender
Piso / Floor Sheet
Banco (Cobo Sc74/M91) / Seat (Cobo Sc74/M9 1)
Degrau / Step
Cobertura / Tail Cover
Arco Seguranca 1 (Medio) / Rops 1 (Mid)
Roda Frente (7-12) / Front Wheel (7- 12)
Roda Frente (6-12) [Opção] / Front W Heel (6-12) [Option]
Roda Frente (6-12b) [Opção] / Front Wheel (6-12b) [Option]
Roda Traseira (9,5-18) / Rear Wheel (9.5-18)
Roda Traseira (9,5-16) [Opção] / Re Ar Wheel (9.5-16) [Option]
Roda Traseira (8-16) [Opção] / Rear Wheel (8-16) [Option]
Ace Ssorios E Peças Serviço / Accessories And Service P Arts
Kit Luzes Trabalho [Opçao] / Working Light Kit [Option]
Pisca Kit Unit [Opção] / Flasher Unit Kit [Opti On]
